Old 12-01-2012, 03:00 PM   #16606
Rwelch360
Oddometer: 336
Originally Posted by DR650SEDDY View Post
Basic stand riding:
Shoulder over bars, slightly bend ur body forward, legs fully extended (with occassional knee bend), elbows out or so, shoulders relaxed.
Always stand on center foot never on the ball of ur foot.
When hitting turns at medium to hi-speed u must lean even further forward to aplly ur weight on da front end so it won't give away, steering bars slightly steered the opposite direction.
In sand or soft terrains that is, slightly move ur butt to the backseat hi-throttle it and let the front ent float over, avoinding it from sink in.
Hope this was helpfull.
Thank you, this helps a lot. I think I will have to prop my bike on a stand and and have a helper take some measurements. I may be able to mimic my riding position and a proper comfortable position and see where my equipment should be. Thanks again.
I didn't want to quote all the pictures over again, but they were really cool pictures too!
Rwelch360 is offline   Reply With Quote
Old 12-02-2012, 04:49 AM   #16607
Muddler
Muddler's Avatar
Oddometer: 751
What's the logic behind this? I must admit to riding on the ball of my foot at times
Muddler is offline   Reply With Quote
Old 12-02-2012, 04:55 AM   #16608
Gadget678
Gadget678's Avatar
Oddometer: 1,174
More secure with less effort. Quicker responses to the gear or brake levers.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 12-02-2012, 05:07 AM   #16609
Muddler
Muddler's Avatar
Oddometer: 751
Fair enough. I think I tend to slide my feet back so there less exposed to getting hit by sticks etc.
Old 12-02-2012, 11:27 AM   #16610
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
If u hit some hoops big enough to get u airborn when u land if ur on the ball of ur foot 2 things can happen,
1- ur foot can slip away off the peg (u loose control and crash)
2- giving the weight of ur body (& whatever ur backpackin') ur ankle will strech down gravely. U can injure it or break it.
A friend of mine is a motocross racer, he borke it that way, he showed me his vid 2 years ago on youtube (i'll try to dig out this vid and post it).
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY screwed with this post 12-02-2012 at 11:34 AM
DR650SEDDY is offline   Reply With Quote
Old 12-02-2012, 11:59 AM   #16611
blaster11
Ramping up fast!
blaster11's Avatar
Oddometer: 6,767
Noise from frontend?
So I have a weird noise come from the front end area of the bike which I am not sure about. I thought it was the front wheel bearings so I checked them and one was a little rough so I replaced them but recently I had a friend take the bike for a spin and the noise still seems to be there. It starts at about 10 to 15 MPH and gets louder with speed...my next guess is speedometer related (wheel drive unit, cable, speedo itself). Have you guys ever had a problem with the speedo, cable, or drive unit and if so what were the symptoms and the fixes?
blaster11 is offline   Reply With Quote
Old 12-02-2012, 12:28 PM   #16612
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
I suggest u remove da cable completely off the bike and ride it, next check front brake system ( pads, rotor etc...)...
Old 12-02-2012, 04:44 PM   #16613
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
Originally Posted by 955616846 View Post
I thing i justified my point based on long time experience as well as other rider's experiences and that's your best reponse wow tell us ur opinion then "Mr. i know it all" on the other hand forget it we know ur opinion is full of this(... ...) Just keep riding anyway u WANT, like i give a single solitary F*%# if u break ur ankle or not.
Just try be helpfull .
Old 12-02-2012, 04:56 PM   #16614
blaster11
Ramping up fast!
blaster11's Avatar
Oddometer: 6,767
I pulled the wheel tonight and the speedometer drive seems smooth and I pulled the drive cable out of the sheath and it seems to have grease. I guess I will just disconnect the cable and have my buddy come over and test ride it (recovering from a broke foot). I recently replaced pads after a fork seal trashed them but the noise was there before that so changing the pads didn't help or hurt the situation.
Old 12-02-2012, 05:23 PM   #16615
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
I pulled the wheel tonight and the speedometer drive .
I don't know if it's same part we're talking about here, check the box assy of the speedo (end speedo cable right side of wheel) part # is 54600-29F00 it also contain moving parts that can cause it.
Old 12-02-2012, 05:33 PM   #16616
blaster11
Ramping up fast!
blaster11's Avatar
Oddometer: 6,767
Yep, we are talking the same part.
Old 12-02-2012, 09:43 PM   #16617
150ron
150ron's Avatar
Oddometer: 1,301
Some fun in the mud
Just some dude...
150ron is offline   Reply With Quote
Old 12-03-2012, 04:44 AM   #16618
Muddler
Muddler's Avatar
Oddometer: 751
Thanks for the advice
Old 12-03-2012, 06:13 AM   #16619
Wlfman
Wlfman's Avatar
Oddometer: 1,288
I found this in the vendor section and it looks really well made....if you are in the market it may be worth a look.
http://advrider.com/forums/showthread.php?t=807903
I use this one which is also made by a fellow Inmate.
advrider.com/forums/showthread.php?t=807214
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 12-03-2012, 11:18 AM   #16620
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
U welcome ...
Times are GMT -7.   It's 09:52 PM.
