Old 12-10-2012, 11:11 AM   #16696
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by RideWithMe View Post
That's a great looking bike, I love the look of the tank compared to the safari 17 ltr on my DRZ400E, which tank is that one.
3.2 IMS tank, The guys at IMS were really helpful and its a great tank.
Thanks for the compliment, the bike was fresh off a full build so it was new.
bobbed06 is offline   Reply With Quote
Old 12-10-2012, 11:19 AM   #16697
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,882
What forks are they
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 12-10-2012, 11:20 AM   #16698
Plane Dr
Plane Dr's Avatar
Oddometer: 868
Nice looking E! Mine hasn't been that perty since the second day i had it. I've done and changed stuff but never a complete clean up.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 12-10-2012, 11:36 AM   #16699
bobbed06
Oddometer: 1,236
What forks are they
They are a set of 46mm Kayabas from a 2003 RM 250. A fella had bought out a Suzuki dealer years ago and these were new and never used so I bought them from him. The triple clamps were also designed for that model of bike and required me to mill 3mm off of the top bearing preload nut. I also welded on a better steering stop because the stock DRZ stop is kinda cheaply done.
They use the stock DRZ/RM 250 neck bearings and of course required Trailtech and Baja Designs items to mount the Vapor Dash, and Headlight. The fork guards are from UFO and required the plastic guard guides to be bored out because UFO missed the mark on a properly fitting guide. ( They designed the guide to fit the 47mm Showas found on the RM 125) which mounted above the flange rather than around the flange like the 46mm Kayabas used.
The brakes all bolt on, a Zeta gear canceller was used to replace speedo gear assy, Zeta brake line holder, and axle /wheel bolts up properly as is.
Stock steer stop VS mine after mods.
Old 12-10-2012, 11:39 AM   #16700
bobbed06
Oddometer: 1,236
I also had the machine shop rework the factory oil tank weld job because they were sloppy from the factory.
Old 12-10-2012, 11:43 AM   #16701
bobbed06
Oddometer: 1,236
Thats a modded S, I wanted a street legal full subframe bike to start with.
Old 12-10-2012, 01:12 PM   #16702
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Originally Posted by mwalker View Post
So how much weight can you shed off this bike if you really try? Can you get it under 300lbs?
Motor and frame are lumps. You could spend a fortune and still be in the 295 range.... Unfortunate.
buls4evr is offline   Reply With Quote
Old 12-10-2012, 02:42 PM   #16703
ohgood
ohgood's Avatar
Oddometer: 2,930
all of it ! get a lighter bike ! the drz ain't, won't, ne'r be it !
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 12-10-2012, 05:51 PM   #16704
BEEF706
King of the dumb dab
BEEF706's Avatar
Oddometer: 738
So... I have issues (I know, this is not Dr. Phil) with my DRZ. Went out to start her up this weekeknd and she tried to turn over, but stopped abruptly. I assumed the battery had atrophied, which was why I went to start her in the first place. but after charging she didi the same thing, so I did a little research, and I think I have had a fuel petock leak, and that maybe the cylinder is full of gas. I already have a plan i place to replace the petcock, and check the floats in the carb, but I have a dumb question, (the main kind I seem to ask ) how do I get the top end drained to get her started again? Thanks for the help.
NMOHVA Member NMTA Member
07 CRF450x, 04 Beta Rev3 270, I like red bikes
A good friend will take you trail riding, an ADV friend will double back and say, "how did you get down there?"
BEEF706 is offline   Reply With Quote
Old 12-10-2012, 05:54 PM   #16705
Gadget678
Gadget678's Avatar
Oddometer: 1,198
Originally Posted by BEEF706 View Post
So... I have issues (I know, this is not Dr. Phil) with my DRZ. Went out to start her up this weekeknd and she tried to turn over, but stopped abruptly. I assumed the battery had atrophied, which was why I went to start her in the first place. but after charging she didi the same thing, so I did a little research, and I think I have had a fuel petock leak, and that maybe the cylinder is full of gas. I already have a plan i place to replace the petcock, and check the floats in the carb, bu I have a dumb question, (the main kind I seem to ask ) how do I get the top end drained to get her started again? Thanks for the help.
In the absence of a decomp ...pull the spark plug out & turn it over.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 12-10-2012, 06:00 PM   #16706
BEEF706
BEEF706's Avatar
Oddometer: 738
In the words of Homer J Simpson, DOH! Thanks mate, I really should have known!
Old 12-10-2012, 07:51 PM   #16707
DR-Zamboni
DR-Zamboni's Avatar
Oddometer: 101
Ive been in that boat... I wouldnt use the electric start to clear the cylinder. Pull the plug, put her in 3rd maybe 4th, and push her up and down the driveway a few times. Get ready for a fuel geyser. You are going to have fuel in the case too, so drain it and put some fresh oil in there while you are at it. This happened to me over the summer, i also mistook the situation for a weak/dead battery. I ended up cranking the thing so many times that i hydraulically bent an intake valve. I felt like an idiot, but it gave me an excuse to order a 440 kit while I had the head off, and install the thinner base gasket (as the E model is built) for higher compression.
Let us know how it goes, if you still cant get it to start after everything send me a PM. The whole ordeal is still fresh in my mind and I can probably help you diagnose any issue.
DR-Zamboni is offline   Reply With Quote
Old 12-11-2012, 05:27 AM   #16708
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Then replace your petcock with one from a Yamaha 660 Raptor ATV....manual so you can turn it off.
Old 12-11-2012, 06:29 AM   #16709
BEEF706
BEEF706's Avatar
Oddometer: 738
Thanks guys, I have a weekend project now
Old 12-11-2012, 12:36 PM   #16710
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,844
I'd like to try and avoid an issue like BEEF706. I have a 2011, so would the Raptor 660 petcock work as well on my bike.
I'm new to the DRZ world, as you can see by my avatar a KLR, now gone.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
