11-03-2012, 05:26 PM
#16801 |
Oddometer: 60
License plate bracket mount
Just picked up a 2001 400E that I am setting up to be road legal. How are you guy mounting your brake light and license bracket to your rear fender? Just drilling a couple of holes? Is the rear fender sturdy enough to take the weight with no modifications? If anybody has a pic or tip, I would appreciate it!
Thanks, Fred |
11-03-2012, 08:05 PM
#16802 |
Oddometer: 818
Nice looking bike viper210, i like that exhaust, thanks for the pic.
SuperTimmy, i was very interested in the shinko 700 series, i even started a thread to see which one was more off roadish, the 244's or 700 series, i think next tire set will be the 700's, thanks for the input. Got the bike all back together today, 25pj, 147.5 mj, needle in 4th clip positon, stock exhaust uncorked, extended fuel screw, unabiker rad guards, TT case savers, uni air filter, trail tech engine temp meter, handlebar risers, edge taillight, small turn signals.. think the only thing my bike really NEEDS now is a aftermarket pipe some pics of the new shinkos i just put on, rear went on fine, front i pinched the tube TWICE, ![]() , had to put on 2 patches at 2 seperate spots, lets hope it holds, been fine since the afternoon.![]() ![]() ![]() im actually glad i got the skinny front and fat rear tire, looks good imo.
Just some dude... |
11-03-2012, 08:22 PM
#16803 | |
Oddometer: 784
I have since swapped in a DRZ-S sub-frame and DRZ-S plastic and was able to reuse the DRC tail light w/o the home-made bracket. If you want I'll try to take some pictures of the bracket and how it was attached to the DRZE rear fender tomorrow. Regards, Mike |
11-04-2012, 02:09 AM
#16804 | |
Oddometer: 60
Thanks, Fred |
11-04-2012, 07:23 AM
#16805 |
Tundra Thumper
Oddometer: 2,229
What size risers did you put on? Are you using the stock cables?
DONATE TO ADVRider sidestandup.com ridedualsport.com motoboss-terlingua-bound.blogspot.com MSF Rider Coach-Rider's Edge Instructor-Track Coach |
11-04-2012, 07:49 AM
#16806 |
Oddometer: 1,710
I'm considering buying a used DRZ. I want the DRZs setup but a friend has a SM for sale that is in super condition. My question is what is the difference between the two specifically: rear shock- rear wheel travel, obviously front fork, is the swing arm the same and are the front and rear axles the same so that I could mount up the S type wheels on the SM. Is there any difference in motors- like cam differences or compression ratios?
Thanks for any info I can get.
Chrome and noise are no reason to ride a motorcycle! :2002 KTM 640 DS :2003 Suzuki GSXR1000 :2005.5 KTM 950 :2007 VStrom 1000 :2008 DR650 :2009 Aprilia DorsoDuro :2009 KLR 650 :more to come |
11-04-2012, 08:27 AM
#16807 | |
b00b
Oddometer: 361
11-04-2012, 09:01 AM
#16808 | |
Oddometer: 818
http://www.rockymountainatvmc.com/p/...ebar-Riser-Kit make it great for when you stand up.
Just some dude... |
11-04-2012, 09:32 AM
#16809 | |
Oddometer: 1,710
Thanks...
11-04-2012, 09:50 AM
#16810 | |
Oddometer: 747
found a nearly new geomax fr and rr in a garbage can at the ohv park yestrday, so ill rock them for the next asskicker offroad ride. tire changes are less than an hour for me now. finally :-) http://www.youtube.com/watch?v=N04oDfqQLq4 http://www.youtube.com/watch?v=xGptXJ9j5dA
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
11-04-2012, 10:16 AM
#16811 | |
Oddometer: 253
SM has a larger rear disk than an S and the calipers/brackets are not interchangeable. SM has axle blocks with the little bolt to adjust tension. The S uses the clam shell style adjusters. I have an S but also have an SM swinger sitting in the corner I'll be swapping on once the snow starts flying.
02 drz 400s/m 09 Husky wr150 |
11-04-2012, 11:36 AM
#16812 | |
Oddometer: 1,710
11-04-2012, 03:53 PM
#16813 |
Oddometer: 1,692
I bought an SM swing arm for my S... I got sick of the snail cam adjusters. As far as bolting an S wheel in it is dimensionally identical.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
11-04-2012, 04:36 PM
#16814 | |
Oddometer: 784
![]() ![]() The DRC taillight comes with some "L" brackets and a triangular mounting plate. I used the "U" bracket that I "fabbed" to bolt the front of the triangle plate while the rear of the triangular plate was bolted to the two rear plastic tabs on the fender with the "L" brackets. The rear fender is an Acerbis part, so I don't know if the stock DRZE rear fender has something similar. Good luck. |
11-04-2012, 06:34 PM
#16815 |
Oddometer: 818
Anybody wanna trade a 14T front sprocket for a 16T front sprocket? i have a 14 in like new shape id like to trade for a 16T front sprocket.
Just some dude... |
