11-04-2012, 07:27 PM
#16816 | |
Oddometer: 60
11-05-2012, 08:11 AM
#16817 | |
Oddometer: 744
also, did you keep the axle and snail ? I'm interested in any other drz bits you don't like !
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
11-05-2012, 08:35 AM
#16818 | |
On A Mission
Oddometer: 27
Feel free to email me about it- ikabaud22 at yahoo dot com. That would be great.... I am digging the white/blue on your bike and viper's! SuperTimmy
2006 DR-Z400S |
11-05-2012, 09:44 AM
#16819 | |
Oddometer: 2,113
Sent from my Galaxy Nexus using Tapatalk 2
Alex Cape Coral, Fl. 2003 KLX400R tagged
11-05-2012, 10:24 AM
#16820 | |
Oddometer: 817
Just some dude... |
11-05-2012, 10:25 AM
#16821 |
Oddometer: 817
So all was fine, i then put in a 147.5mj instead of the stock 142.5, and a extended fuel screw from the TT store, also put in a 25 pilot jet, 3x3 mod done, uni air filter, stock exhaust un corked.
Bike pulled better at top speeds, but the idle was way off, could not get it to idle right no matter what i did, and i noticed a little fuel coming out of the overflow of the carb (not the carb drain screw exit, the other one on the bottom, that has a tube going to the bottom of the bike), so i then replaced the 25pj with the stock 22.5pj, and the idle was great again, but now i do not know why, the carb is leaking gas from that overflow spot, over night i left the fuel petcock to ON and it mustve dripped dropped like 20-30 drops of gas onto the garage floor, and when i go to start the bike, it wont start, like the starter is stuck or something, i have to drain out the gas from the carb drain screw, and then eventually it will start. why is the carb letting in too much fuel to where its flooding the bike? the floats move up and down just fine, and the carb is spotless, no dirt at all, could it be cause maybe my jet needle is shimmed too much and needs to be lowered down a bit? please help me get this sorted, as ive taken out and reinstalled the carb like 4 times in this past weekend, the jetting seems to be spot on, bike runs great, its just this flooding problem.
Just some dude... |
11-05-2012, 10:49 AM
#16822 | |
Oddometer: 9,700
Also, I hope your "stuck starter" issue after sitting overnight isn't being caused by hydrolock from excess fuel in your cylinder - if it is, then you're risking major engine damage trying to start it. - Mark |
11-05-2012, 11:01 AM
#16823 | |
Oddometer: 2,113
oh and your needle is leaking for the float and possibly the o-ring around the seat. also your petcock should be stopping fuel flow once the bike turns off so incase you have a failure like this it doesn't fill your engine full of fuel.
11-05-2012, 11:19 AM
#16824 | ||
Oddometer: 817
so what should i be looking at according to this chart? https://www.thumpertalk.com/shop/oem...007&model=5203 i do not know much about carbs, just pretty much how to change out the jets, and the carb is spotless, no dirt or debris at all, and the float easily moves up and down, so its not stuck.
Just some dude... |
11-05-2012, 11:41 AM
#16825 |
Oddometer: 817
so im guessing this half stripped screw has to come off so i can remove the flaoting thing?
![]() its allready half stripped and wont come out, when i try to remove it with pliers, it feels like im just going to break the top off,
Just some dude... |
11-05-2012, 12:29 PM
#16826 |
Oddometer: 817
got it all off
![]() cleaned it up and back it back together, have the tank connected to the carb on the bench, so i can test it out and see if it still leaks, before i put it back in the bike.
Just some dude... |
11-05-2012, 01:38 PM
#16827 | |
Oddometer: 253
One is I find them to be a pain as it always seems one side likes to move a notch on me when I tighten the nut down. The other reason is they are not aesthetically pleasing
02 drz 400s/m 09 Husky wr150 |
11-05-2012, 02:16 PM
#16828 | |
Oddometer: 777
Have you ever noticed that when you're out on the bike, nothing else matters? http://www.advrider.com/forums/showthread.php?t=709292 |
11-05-2012, 02:21 PM
#16829 | |
Oddometer: 2,113
If I were you I think I'd change that o-ring on the seat. I had mine leak on my FCR a few years ago. Also if your petcock is working properly the fuel shouldn't over flow like that. Maybe check your float height? Sent from my Nexus 7 using Tapatalk 2
11-05-2012, 02:31 PM
#16830 |
Oddometer: 817
Thanks, i just came back from orielly's and got a new oring, got it all set up on the bench right now with the fuel open to the carb, im hoping its not gonna leak anymore and that was the problem (crossing fingers)
the 147.4 i orderd from my local bike shop, it was $4.99, seems to run really well up on top, i see some go to 150-160mj's, but he suggested going 2 steps above stock, so the 147.5 it was. the 25pj did not work well for me at all, took it out and the 22.5pj with the extended fuel screw at 2 1/2 turns out works really well.
Just some dude... |
