Old 12-23-2012, 03:42 PM   #16861
dasvis
dasvis's Avatar
Oddometer: 536
Happy Festivus all!
http://www.youtube.com/watch?v=F73sM...e_gdata_player
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 12-23-2012, 05:17 PM   #16862
carbon_unit
carbon_unit's Avatar
Oddometer: 43
Originally Posted by 150ron View Post
I got 2 questions for you guys, my bike has like 25 pounds of dry mud/dirt on it, id like to wash it for the firs time,
1), is it ok to use a pressure washer? my neighbor has one of those electric 1800 psi that i can use when ever i want.
2) does the bike need to be on and idling while i either hose it down, or pressure wash it?
Reason i ask, is my previous bike always gave me problems after washing it, it would almost not start back up, dont want to fuck anything up with water, i rather leave it filthy then mess something up.
The mud usually comes off easier if you wash it as soon as you get home. The sooner the better.
I always use a tire brush and just a garden hose after each ride and it comes right off. I never need to use my pressure washer on the bike.
If you let the mud dry overnight it is considerably harder to clean off.
If you keep it clean all the time it isn't such a big job either.
My bike has been muddy enough that it more than half filled a 5 gallon bucket when I cleaned up the driveway after washing it but you would never know it by looking at it.
carbon_unit is offline   Reply With Quote
Old 12-23-2012, 05:48 PM   #16863
okietrailboss
okietrailboss's Avatar
Oddometer: 285
cold start
anybody have starting issues under 50deg fahrenheit
okietrailboss is online now   Reply With Quote
Old 12-23-2012, 08:07 PM   #16864
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,086
Just be ready to grease and check, the engine mounting bolts, swing arm bolt, bearings on a regular basis, but you do that anyway right? Id avoid any direct pressure, just pressure wash from 6 or more feet away. Personally ive only needed to pressure was out dried caked on mud and still a constant stream from 6 feet away worked fine.
On another note, being as the.bike is new to you, you have pulled the swing arm rod and greased the crap out of it right...right...
what was the greatest thing, before sliced bread?
focallength is offline   Reply With Quote
Old 12-23-2012, 09:06 PM   #16865
150ron
150ron's Avatar
Oddometer: 1,433
Thanks for the tips guys, the mud is dried up, on top of other dried up mud, on top of ... you get the point its so thick i gotta stab it with a flat head screwdriver to get it to knock off, lol
As far as greasing, guilty as charged, havent done a thing.
Just some dude...
150ron is offline   Reply With Quote
Old 12-23-2012, 09:22 PM   #16866
Bad Daddy
Oddometer: 104
Nope. At altitude, 3500 ft, before jetting it took a bit of cranking. Now at 36F sea level and altitude it fires up quite easily.
Which carb, jetting, needle position and pilot are you using?
Altitude?
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 12-24-2012, 06:39 PM   #16867
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,976
Bar risers and 12v socket
Fitted my bar risers and waterproof 12v socket today
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 12-24-2012, 07:25 PM   #16868
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Wow, all that crap in that carb is something else.
Added a piece of Silicone heater hose around my new pipe, to protect it for when i drop it on the trails.
Redneck engineering at its best! Good idea ya done got there yup.
Cobain is offline   Reply With Quote
Old 12-24-2012, 11:14 PM   #16869
150ron
150ron's Avatar
Oddometer: 1,433
Glad you like it, not my idea, lots of guys do it over on thumpertalk, as can be seen here.
http://www.youtube.com/watch?feature...&v=de6i_02PnDg
Cheerio.
Just some dude...
Old 12-25-2012, 03:23 AM   #16870
ohgood
ohgood's Avatar
Oddometer: 3,043
pressure washer - twenty feet away is OK
brush n hose if you have to put your beer down, you're washing too much
remember, its a dirt bike, not a piece of ass
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 12-25-2012, 03:19 PM   #16871
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 734
Im a pressure washing guy. Some say don't but if your into your annual maintenance I don't think there is a problem. The chassis lube is important though. Check your wheel bearings, swing arm, shock connections, steerer tube and fork seals annually and hose away.
effensteve is offline   Reply With Quote
Old 12-25-2012, 03:33 PM   #16872
ohgood
ohgood's Avatar
Oddometer: 3,043
Originally Posted by 955616846 View Post
I suppose you'd also condone what 150ron did spannering a dirty bike.
make it more fun, link what he or she did here :-)
Old 12-25-2012, 03:45 PM   #16873
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
Replaced fork boots with KTM guards
So right after I bought my bike I started going through it and figuring out what needed to be done, fixed, or upgraded. I quickly realized that the PO had neglected to tell me a fork seal was leaking and that that fork had a gouge in it which he tried to buff out. Of course the leaking seal also took out the brake pads. So off I went to find a new set of forks, I quickly found a set on eBay for a decent price...done. So I bought some new oil/dust seals and some new springs and commenced to taking it apart. Little did I know that taking it apart and riding my 200 2 stroke would change my life for a while. http://www.advrider.com/forums/showthread.php?t=830324 So since I was out of commission and needed to get the bike back together and out of the garage I elected to send the forks off to Cogent Dynamics with my parts for a full upgrade to include revalving. I got the forks back several weeks later and noticed that the fork boots were quite torn up and needed replacing. After searching several places I found I would be out about $80.00, not that $80.00 is a lot but I find the boots kind of ugly. Having a lot of time on my hands now I found a link over on Thumper Talk http://www.thumpertalk.com/topic/751...-s-or-e-model/ which talked about using hard plastic covers or blades which are similar to the same things used on USD forks. I figured what the Hell I will give those a try. So I began sourcing parts only to find out that a key component, plastic fork clamp, was no longer available but only after buying all the other pieces. I called several KTM parts guys and everyone had the same story....out of stock and will not be replenished. So I went to the secondary market, used, and found a set...again on eBay. I got the parts in and the one part I really needed which was the clamp was damaged. I made it work and just finished getting them installed yesterday. I still can't ride but at least the bike is back operational again. Here are a few pictures of my install.
Shows the blade guide and clamp (clamp is discontinued)
Just showing how the brake line feeds up behind the blade through a hole so that it can move freely during compression and rebound.
Because the clamp is slightly too big for the fork I added a few turns of electrical tape to give the clamp something to bite on.
This shows how the brake line gets pinched between the two clamps to keep it in place
and the last picture just shows my dash configuration with GPS mount, SPOT mount, and fold away mirrors, I would like to upgrade the complete dash area with some type of rally setup someday so I can get all the crap off the bars....maybe some day!
I just want to thank my good buddy Dave, EOD3MC, who helped me get the bike back together and test the new suspension. Thanks Dave!!! The good news is because he helped me, the DRZ bug bit him and he now is the proud owner of a DRZ as well.
Merry Christmas!
blaster11 is offline   Reply With Quote
Old 12-25-2012, 04:10 PM   #16874
150ron
150ron's Avatar
Oddometer: 1,433
Spannering
Any form of mechanical work on a vehicle, be it a bicycle, motorcycle, car or even a lawnmower.
"What did you do at the weekend?"
"I spent all weekend in the garage spannering, got the car running again by Sunday"
Had to look that one up.
Just some dude...
Old 12-25-2012, 10:06 PM   #16875
p0diabl0
Oddometer: 563
Spannering
Them strange folk that we rebelled against a few hundred years ago still don't know what a wrench should be called.
p0diabl0 is online now   Reply With Quote
Times are GMT -7.   It's 09:29 AM.
