Old 01-04-2013, 10:36 AM   #16951
211john
Oddometer: 224
Originally Posted by TIGERRIDER007 View Post
Thanks to those who kind of swayed me to the DRZ side of the equation!
As I read a billion articles on this topic, I guess the summation is the DR is basically for the road, and the DRZ is basically for off road...
Is there a way to stiffen up the back suspension on each, like an off road spring or something? It seems both need suspension work if you are taking it off road, but how much and how expensive is this endeavor?
Thanks DRZ folks!
If you go to the racetech website they have a spring calculator that will tell you what weight springs you need for your bike with you on it. Just changing the springs and adjusting the shock/fork is adequate and will cost you a little over $100 per end for the springs. If you want it to be ideal the forks and shock can be revalved too. Not sure what that would cost.
Suspension work is the most cost effective performance modification you can make. Getting the springs right and the sag set right is the 1st step. Having it set up right will make the bike handle better on and off road.
211john is offline   Reply With Quote
Old 01-04-2013, 11:10 AM   #16952
motolab
motolab's Avatar
Oddometer: 2,631
I would advise caution with the calculator on RaceTech's site. I've had it make recommendations that turned out to be several spring rate increments too stiff, and therefore don't use it anymore.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-04-2013, 11:14 AM   #16953
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 985
Originally Posted by TDR400 View Post
Sorry if this has been answered before. I am new to the list and am struggling with the search feature .........
Looking for a bolt on cover for the muffler that keeps my Gears bag from resting against the exhaust.
TIA
Jim
This is probably the best thing you'll find for the money. Can't beat $55.
http://www.ebay.com/itm/Suzuki-DRZ40...e1ebfc&vxp=mtr
Starchamp is offline   Reply With Quote
Old 01-04-2013, 11:20 AM   #16954
ohgood
ohgood's Avatar
Oddometer: 2,812
TIA
Jim
Wrap an old tag in chicken wire and bolt it to the muffler, under the plastics. It will reduce the meltage and heat on your leg a ton. Then put racks on
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 01-04-2013, 01:57 PM   #16955
TDR400
Noisy Cricket
Oddometer: 10
Indeed that is a deal! Even at $84 at the website it is a good price. And should I want to go to hard panniers - I have something to mount to. Thanks a ton.
TDR400 is offline   Reply With Quote
Old 01-04-2013, 03:48 PM   #16956
dazz
dazz's Avatar
Oddometer: 178
DRZ 400 S plastic.
Good evening. Replacement plastic is available everywhere. BUT, what I want to do is just replace the front and rear fender from yellow to white and have a totally white bike. Specifically where is the best place to buy quality plastic that will be the same as OEM. Or should I just bite the bullet and go to the Suzuki store? I'll prolly replace the signals at the same time. All suggestions welcome. Or should I buy one of those kits that have all the plastic?
Thanks,
Don
Triumph Bonneville T100
1971 R50/5, BMW G650GS
DRZ400S, KTM 250 XC-W
XR200, 1947 James ML
dazz is offline   Reply With Quote
Old 01-04-2013, 04:24 PM   #16957
Muddler
Muddler's Avatar
Oddometer: 773
Regards,
Derek
Agree
Procycle also have a guide. I considered both guides to develop an understanding of how the rates vary with load and riding style. As the range i was considering was going up a several notches from standard anyway, within this range i erred on the side of soft, figuring i would have an improved ride anyway. In the end I just made my best guess, but have been happy with the outcome.
Muddler is offline   Reply With Quote
Old 01-04-2013, 05:07 PM   #16958
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
I have these and they are brilliant, mine arrived and got fitted in 20 minutes with NO adjustment needed. The guy that makes them does a Good Job.
Also they do the job their made for with minimum weight, I have a Giant Loop bag installed on mine.
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 01-04-2013, 05:30 PM   #16959
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Regards,
Derek
Worked spot on for my rear springs, and missed the mark on my fork springs. ???? Go figure
bobbed06 is offline   Reply With Quote
Old 01-04-2013, 06:02 PM   #16960
dasvis
dasvis's Avatar
Oddometer: 536
TIA
Jim
http://www.robinsonsfoundry.co.uk/bu...-29f00-068.htm
Link above is for a European spec DRZ400SM optional muffler guard. I bought one of these & put it on my 2009 DRZ400S. Took a little dremel work to get it to fit, but it was worth the effort. Looks factory stock....
Dasvis
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis screwed with this post 01-04-2013 at 08:14 PM
dasvis is offline   Reply With Quote
Old 01-04-2013, 06:06 PM   #16961
Daithi
Destination Unknown.
Daithi's Avatar
Oddometer: 176
* The wiring for the speedo changed to 3 wires in 2005, so it'll depend on what year cluster you got.
Amazing the amount of info on here, I've just fitted a 4 wire speedo to a three wire loom and was baffled by the missing wire. Just ignore the Gray one.
The diagram was handy, thanks!
CCM404 & DRz1000
Daithi screwed with this post 01-05-2013 at 07:49 AM
Daithi is offline   Reply With Quote
Old 01-04-2013, 06:38 PM   #16962
Leoffensive
Oddometer: 34
figured id leave these here
Leoffensive is offline   Reply With Quote
Old 01-04-2013, 07:46 PM   #16963
motolab
motolab's Avatar
Oddometer: 2,631
My guess is that the RaceTech calculator fails to take into account differences in rake angle. I think it assumes some "average" rake angle, so that two different bikes that had the same laden weight would get the same fork spring recommendation, even if their rake angles were different.
Regards,
Derek
Old 01-04-2013, 08:02 PM   #16964
Viper210
Viper210's Avatar
Oddometer: 35
Installed new blue fork gators and riser.
'11 DRZ400S Acerbis Handguards,TT Case Savers,Unibiker Radiator Guards,Hyde Skid Plate,Kenda 270,HEL Braided Lines,IMMIX Cargo Rack,3X3 Mod,JD Jet Kit,Yoshi Fender Eliminator Kit,Moose Headlight Cowl Bag,Moose Cross Bar Pad,Swing Arm Decals,Gripper Seat Cover,ASV F3 Brake & Clutch Levers,Yoshi RS-2 Full Exhaust CF,Zeta Brake Clevis,Anodized Check Plugs,Mishimoto Hoses
Viper210 is offline   Reply With Quote
Old 01-05-2013, 07:40 AM   #16965
150ron
150ron's Avatar
Oddometer: 1,364
Nice bike, where can i get that TOOL TUBE you have on there? i have seen a few of them, but cant seem to find one.
Just some dude...
150ron is offline   Reply With Quote
Times are GMT -7.   It's 11:03 PM.
