Old 01-07-2013, 10:27 AM   #16996
ohgood
ohgood's Avatar
Oddometer: 2,731
Originally Posted by 150ron View Post
No test ride = no sale, thats just me tho.
It ain't just you.
17000 miles might mean:
Clutch
Both sets wheel bearings
Stator
Swingarm bearings
Stem bearings
Chain
Cogs
Rings
Piston
Or any manner of worn out / broken stuff. Stuff that costs a lot to fix.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 01-07-2013, 12:01 PM   #16997
MushNB
Oddometer: 39
Wow, lots of great info right there guys - really appreciate it! I might give the stand thing a try, but will most likely put the purchase on hold until a can get a better look at things in the spring. If it doesn't work out, there will always be another bike for sale!
MushNB is offline   Reply With Quote
Old 01-07-2013, 02:47 PM   #16998
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 605
There will be others.
coarsegoldkid is offline   Reply With Quote
Old 01-07-2013, 03:07 PM   #16999
Bobby Ginger
Cat Herder
Bobby Ginger's Avatar
Oddometer: 974
That is always the hardest part, isnt it?
2009 GSA 2008 Husky TE450 2013 Husky Terra 2006 KTM 950 SM
IBA 50407
Bobby Ginger is offline   Reply With Quote
Old 01-07-2013, 04:18 PM   #17000
hizzo3
Oddometer: 95
Originally Posted by oldcodger View Post
Are you in Australia? The use of the words "Law Enforcement" suggests American.
There are several threads in the Oz forum covering this subject.
American... sorry just showing my ignorance... I will need to read up on this for I would love to ride down with you Aussies sometime (if I could get a business trip lined up).
Sent from my Galaxy Nexus using Tapatalk 2
hizzo3 is offline   Reply With Quote
Old 01-07-2013, 07:21 PM   #17001
Plane Dr
Plane Dr's Avatar
Oddometer: 857
Originally Posted by ohgood View Post
It ain't just you.
Clutch
Both sets wheel bearings (cheap)
Stator (no that is random)
Swingarm bearings (likely)
Stem bearings (likely)
Chain (so?)
Cogs (so?)
Rings (remote)
Piston (again remote)
Define cheap? Have a leak down test done, pop the valve cover and check the valves. If it is otherwise well maintained your odds are the same as a new one. These engines stand up well if maintained. There are lots out there with way more miles lots with less. Read the FAQs at TT and bear that in mind.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 01-07-2013, 07:43 PM   #17002
dasvis
dasvis's Avatar
Oddometer: 536
.... the waaaaiting is the hardest part... (Tom Petty)
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 01-08-2013, 06:29 AM   #17003
Muddler
Muddler's Avatar
Oddometer: 767
I'm not inclined to overstate the benefits of a seat because one man's perfection could be another's torture device. It is entirely subjective. I've had good results with the Seat Concepts seat, but the only way for you to know for certain is to try one yourself.
Quite right. I'll report back with my views once I have something sorted.
Muddler is online now   Reply With Quote
Old 01-08-2013, 02:56 PM   #17004
ginslung
It'll take.
ginslung's Avatar
Oddometer: 226
Good thinking. Your bike is out there, and it's worth waiting for it.
I bought one a month ago that was a good price, and I'm learning it's a mild basket case as I slowly tear it apart (missing fasteners/some 'creative' wiring solutions, etc, etc, etc). I'm too impetuous sometimes.
On the other hand it helps to know that any/everything you need to know is here or on TT...and in my case I'm used to working on a KTM 950 so anything in comparison is straightforward, logical and the manuals aren't written in Germanglish.
ginslung is offline   Reply With Quote
Old 01-08-2013, 07:48 PM   #17005
Psycho18th
Oddometer: 401
http://www.advrider.com/forums/showt...5#post20432015
Ride report from a great Arizona ride I took on my DRZ yesterday. Here's a couple teasers.
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Old 01-08-2013, 11:19 PM   #17006
Adrian V
Oddometer: 495
Springs and valving
I have a 400E and I am trying to decide what rate springs to get. I weigh close to 100kg (220lbs), have a 28l tank and want to use the bike for fanging through the bush and Oz desert trips, when I will need to carry extra fuel and water as well as my gear (though I pack light). I tried the Racetech calculator, but the categories seem somewhat arbitrary, and I am getting a range of different results.
I am thinking 0.50 or 0.52 kg/mm front fork springs and a 0.57 kg/mm rear shock spring might be the go, but I would welcome thoughts on this and what rates other people are using in similar situations.
Previously I have always sent my forks off to be revalved, but I am also wondering how good the Type 1 and G2R Gold Valve fork kits and the G3-LD Shock Gold Valve kits are?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 01-09-2013, 04:27 AM   #17007
Muddler
Muddler's Avatar
Oddometer: 767
Cheers,
Adrian
I am 95kg and a steady rider. Like you I have a 28l tank and carry panniers etc for trips out along the Holland Track etc. I found the decision on rate tricky, I ended up using the Racetech vs the Procycle calculater for alternate ends (can't remember which way around). I ended up going for 0.5/5.7, the intent being to err on the side of soft as I didn't want it to be too harsh when going slower and my back ain't what it used to be.... I'm happy with the outcome, should I have gone stiffer? I'll never know!
PS. You doing the Bremer ride? (SoEx)
Old 01-09-2013, 07:55 PM   #17008
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,673
[QUOTE=Psycho18th;20432039]http://www.advrider.com/forums/showt...5#post20432015
That's some gnarly stuff! Looking forward to reading the ride report.
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
http://www.moto-racks.com
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Old 01-09-2013, 08:35 PM   #17009
Dirtnadvil
Dirtnadvil's Avatar
Oddometer: 821
Michelin Deserts, who uses them
I have a Baja ride coming up and I was thinking about trying these out. I am going to be riding alot of beaches on the gulf side, pebbles, rocks, deep sand. I am sure they will work on trails and dirt roads. aslo Will a 140 80 18 fit?
Dirtnadvil is offline   Reply With Quote
Old 01-10-2013, 05:51 AM   #17010
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 921
DRZ owners, a quick question: when did they upgrade the DRZ? Is there a big difference between a 2001 and a 2006?
I was checking into a 2001, but don't want to get an older model if it's not worth it...
thanks for the information!
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
