Old 02-19-2013, 10:51 AM   #17506
Tropic-Of-Canada
Thread Derailleur
Tropic-Of-Canada's Avatar
Oddometer: 864
Originally Posted by Jack Rabbit View Post
Show us your chain tensioner. Typically if its adjusted all the way in, your chain is stretched too far and needs to be replaced. I'm no expert but its very hard to tell from pics of the cams.
It's an ACCT, and it's an 04. Never did pop that out, I guess I should!
Tropic-Of-Canada is offline   Reply With Quote
Old 02-19-2013, 11:36 AM   #17507
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
[QUOTE=DualSportDad;20761196]
Originally Posted by buls4evr View Post
I've been using Jessie's products for years. Started with my dr350. I also know viton isn't cheap. Either way is ask before I bought it. I don't care if it's the right size and is only $0.50 or not. ... I'd rather pay $10 and not smoke my engine because it filed full of fuel one day.
Sent from my Galaxy Note 2 using tapatalk 2
Exactly why I use the Raptor petcock and shut it off each night after use............. Nothing says Viton won't fail over time also though so I would not trust it totally either. Ethanol is nasty stuff.
buls4evr is offline   Reply With Quote
Old 02-19-2013, 02:18 PM   #17508
59DEN
59DEN's Avatar
Oddometer: 879
Thumb
Originally Posted by DualSportDad View Post
Ussually the valves wear cause of sand injestiin. Maybe the coating was thinner than some on the valves? Either way the coating is thin and once they move to the point that you notice, they are done.
I have my old valves in my till box. ..ill take a picture of them and and if I remember layer I'll post them up to help give a better idea of what had happened.
Thanks for that DSD,
59DEN is offline   Reply With Quote
Old 02-19-2013, 02:44 PM   #17509
150ron
150ron's Avatar
Oddometer: 1,405
Great trail ride yesterday,
was really nice out
Then i dropped it...
Just some dude...
150ron is offline   Reply With Quote
Old 02-19-2013, 03:41 PM   #17510
Fantastic Mister Fox
Fantastic Mister Fox's Avatar
Oddometer: 25
Originally Posted by mark1150 View Post
Hi there Mrs F,
Firstly I've used your quote as it's the last thing written on behalf yourself and Mr F.
It only occurred to me today, I couldn't help but wonder if your bikes are OK in the armour dept, I.E. Engine cases and Radiators?
The cases are sorted out with easily fitted CFC / TT (Thumper Talk) guards,and the latter with Unabiker rad guards.
Both of these have come highly recommended , and both are of great quality to which I have no doubt that should the worst happen they will perform as they are supposed to.
Both have the potential to delay or stop you in your travels, so I thought it worth a mention.
Thanks mark, we have the CFCs for the engine cases. and the CCM comes with a stock radiator protector it's not great but it will stop a stone being flung up of the road and I've collided with a rock while trail riding in wales and it's done its job.
In addition Gabe at Zen Overland (www.zenoverland.com) fabricated a protector for a sideways impact on the radiator as we thought the radiator was a little exposed.
www.mudandknobblies.co.uk - Going round the world on CCM SR40 motorcycles.
Fantastic Mister Fox is offline   Reply With Quote
Old 02-19-2013, 04:08 PM   #17511
DualSportDad
DualSportDad's Avatar
Oddometer: 2,440
I forgot to take pics. I'll try to remember tomorrow while at work.
Sent from my Nexus 7 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-19-2013, 04:13 PM   #17512
DualSportDad
Oddometer: 2,440
[QUOTE=buls4evr;20762038]
I agree. When I had the fcr on I never turned my fuel valve off... I did replace the o ring once cause it was leaking tho. That was a long time ago. But the fcr has the overflow tube. I wonder how hard it would be to add one into a bsr float bowl. For now I just have a Vinton o ring on there and turn the fuel off to be safe.
If I could find a cheap or near free bsr I'd try to drill a hole in the float bowl and stick and tube in it.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
Old 02-20-2013, 01:05 AM   #17513
59DEN
59DEN's Avatar
Oddometer: 879
Originally Posted by 955616846 View Post
Is there something to suggest that you have a problem?
Hi numbers, no problems, the old bike is running well, just interested for future reference. Cheers for the heads up on the Toppeak digital tyre guage, works a treat.
Old 02-20-2013, 05:16 AM   #17514
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 538
Originally Posted by Tropic-Of-Canada View Post
Tropic-Of-Canada, looking at the picture/s looks to be a lot of small dirt/dust on the wiring harness and frame. If this is then the dirt/dust could fall into your engine while you are working on it, If there is dirt/dust then I would suggest that you close up the engine and wash off the dirt/dust to be safe. You may have already done that but not sure from the looking at the pictures.
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is offline   Reply With Quote
Old 02-20-2013, 06:51 AM   #17515
inroads
Wimberley,Texas
Oddometer: 261
80/100-21
Could you guys tell me if I am ok with a 2.75x21 front tire or should I be running a 3.00-21?
my manual says 80/100-21.
inroads is offline   Reply With Quote
Old 02-20-2013, 06:54 AM   #17516
wingam00
wingam00's Avatar
Oddometer: 538
Belive that both will work, but I prefer the 3.00 x 21 or 3.25
Mark
Old 02-20-2013, 08:12 AM   #17517
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
If you want to put a DOT tire on it you are pretty much stuck with a 90/90 X21. A 3.00 is very similar in circ. They come with an 80/100 but that circ varies a lot depending on whether an E or S type tire. The Deathwings are tiny in circ. Either way your speedo/odo combo will be off about 10% anyway(optimistic).
Old 02-20-2013, 08:41 AM   #17518
150ron
150ron's Avatar
Oddometer: 1,405
Im running a 2.75-21 up front, i like it.
Just some dude...
Old 02-20-2013, 09:44 AM   #17519
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,002
Not really they have variety out there of dot approved tire of different sizes 80/100-21 and 90/100-21. like this one : Pirelli MXMH provide with both sizes
or this one: Pirelli MXH
They are both DOT. Also Kenda Parker DT have them DOT in both sizes (80/100-21 & 90/100-21) the 90/100-21 is a bad ass tire (Kenda Parker) it worked great in mud, sand or loose gravel.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 02-20-2013, 10:18 AM   #17520
Tropic-Of-Canada
Thread Derailleur
Oddometer: 864
Yea, I hear ya, I gave it a good wipe in the critical areas and anywhere I was going to bumb, but you're right, I should be more thorough.
Times are GMT -7.   It's 02:43 PM.
