Old 02-28-2013, 08:23 PM   #17641
Jon B.
Oddometer: 584
Originally Posted by focallength View Post
Theyre plastic for a reason, or do you honestly think suzuki just got lazy and said, hey lets just make some of the gears plastic.
Fyi its not a load bearing gear, it just spins a pump.
If the pump fails it breaks a plastic gear, if the pump fails (or the gear fails)and the plastic gear dosent break you wont know it until your engine seizes. But good luck with your revelation...
Head on over to thumpertalk youll make billions and that will be the latest and greatest "must do, or babies will spontaneously combust" fixe.
And, you KLR guys, better get a new 'doohickey' and a ThermoBob, or you're doomed. Doomed, I say.
Jon
Hey - if it ain't an adventure, it's just a ride!
'05 DRZ 400E Titled/Plated
Jon B. is offline   Reply With Quote
Old 02-28-2013, 08:28 PM   #17642
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 636
I'm getting around to changing the countershaft sprocket on my '05 DRZ that's been in my possession for 10 months. Yes the sprocket was toast so the bike gets a new chain and rear sprocket also. The nut that holds the countershaft sprocket on came off using only my fingers. The Clymer manual specs out the torque at 81 lbs ft. That's a lot of torque. My good friend tells me the Suzuki manual specs out the torque at 105 lbs ft. Holy cow that's really a lot of torque. What amount of torque have you fellas been using?
coarsegoldkid is offline   Reply With Quote
Old 02-28-2013, 09:04 PM   #17643
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,720
That's hard to explain...cuz I just make it tight and ride with wreck less abandon. Ignorance is bliss!
Sent from my fat thumbs on a small touch screen.
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 02-28-2013, 09:04 PM   #17644
SaharaJp99
Oddometer: 681
I always thought it was 90. That's what I always torque mine to.
SaharaJp99 is offline   Reply With Quote
Old 02-28-2013, 09:31 PM   #17645
oldmanb777
Just say NO to socialism!
oldmanb777's Avatar
Oddometer: 4,075
Chain & sprockets
I need a new chain. About 8K on the OEM's, almost all dirt miles. Mine is an "S" and came with the horiible 15-44 sprockets. I treid a 12 for a while, but with the close ratio gearbox, that didn't work. So i have been running a 13-44 setup. So now its time for a new chain. So I'm thinking of a 14-49 might be a good all around gearing for my 95% dirt riding. Will the stock length chain work with those sprockets? Anyone got a good deal on sprockets and chain recently?
oldmanb777 is offline   Reply With Quote
Old 02-28-2013, 09:53 PM   #17646
DualSportDad
DualSportDad's Avatar
Oddometer: 2,455
I'd like to know why you think putting a metal one in there would hurt. I'm not trying to argue, just wondering. I have heard that the oil pump gear turns out like this because when a repair is done caution isn't used to make Sure the gears line up before torquing down.... The clutch basket I think it was..... Not sure. I did my cam chain and tjhe lock tight mods about 20,000 miles ago and all is good so far.
I do have a new plastic gear here in case I ever have to go back in for any repairs. I like the idea of a metal one. It my understanding that Suzuki just used a plastic gear to save money cause the gear never really saw any hard force on it.
Sent from my Nexus 7 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 02-28-2013, 10:35 PM   #17647
59DEN
59DEN's Avatar
Oddometer: 972
Question
I would be interested to know as well,
Cheers
59DEN is offline   Reply With Quote
Old 03-01-2013, 05:11 AM   #17648
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,796
14-49 will work with a 112 link chain. If your dirt riding is tight single-track, then that combo will work well. But if you want to spend much time at 55 mph or more, you'll probably wish you had 14-47.
threadkiller is offline   Reply With Quote
Old 03-01-2013, 06:18 AM   #17649
SquadraCorse
SquadraCorse's Avatar
Oddometer: 133
Spring is in the air and the bike is almost finished. Too bad I don't want to get it dirty now....
2013 RallyMoto Overall/Dakar Champ
http://styleperpound.blogspot.com/
BMW R1100S Light | KLX 400
SquadraCorse is offline   Reply With Quote
Old 03-01-2013, 06:29 AM   #17650
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,217
Theyre designed to be a "weak" link, I use the term weak loosely as they are very strong. how it was explained to me is that if the pump fails the plastic gear will fail thus saving the engine. Which is most likely what happened in that engine, except the rider didnt notice the engine overheating. Theres one on the water and oil pump, its sort of like a blow off valve. If the pump goes bad, the plastic gear may save the engine.
lots of bikes, have plastic pump gears for the water and oil pumps. iirc more have them than do not.
i questioned it, with my tear down, so I asked around, I asked several very knowledgable motorcycle professionals. WORCS bikes, custom one off rally bikes, bikes designed to be ridden WFO for thousands of miles,run plastic pump gears.
do as you will.
Why do meteors, always land in craters?
focallength screwed with this post 03-01-2013 at 06:47 AM
focallength is offline   Reply With Quote
Old 03-01-2013, 07:55 AM   #17651
bobfab
bobfab's Avatar
Oddometer: 1,500
Wow, graphics look great. As does the use of the T-bolts for the headlight mount, very clever!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 03-01-2013, 08:04 AM   #17652
Jon B.
Oddometer: 584
do as you will.
Yabbut... If the gear fails, how will I know? Won't the first indication be that the engine seizes tight, and my piston looks like the one in the earlier post?
I don't have any indication of low/no oil pressure.
Jon
Old 03-01-2013, 08:23 AM   #17653
bikeslut
bikeslut's Avatar
Oddometer: 1,800
agreed... I'm running 15-49, and it runs 60 (speedo indicated; more like 54) ok for a while
you're asking HERE?!
bikeslut is online now   Reply With Quote
Old 03-01-2013, 08:35 AM   #17654
motolab
motolab's Avatar
Oddometer: 2,851
Originally Posted by ol'dan View Post
I agree but it seems every parts source only sells them as a set. The o-ring should be easy to find. Do you know where to get just the needle?
What is the needle's OD and length?
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-01-2013, 08:54 AM   #17655
motolab
motolab's Avatar
Oddometer: 2,851
Before asking for needle dimensions, I should have said that there's no need to replace the needle unless the tip has a witness line where it's been contacting the seat.
Regards,
Derek
Times are GMT -7.   It's 03:10 PM.
