01-27-2013, 10:55 AM
#17716 | |
Are you a Sheeple?
On another note, a buddy came over and we pulled the swing arm and cleaned and lubed all the bearings. The swing arm bolt came out without much effort, I was a bit worried from all the horror stories I had read. The swing arm bearings showed a little sign of water intrusion but everything cleaned up and felt fine. Other than the wheel bearings, which I was going to replace anyway, everything looks good and went back together smoothly. |
01-27-2013, 11:25 AM
#17717 |
Lil' RC!
Oddometer: 336
BRAAAAAAAAAAAAAAAAAAAAAP!!!
Lucky Strike wrap done by the guys at www.StickyBros.com!!! Can't wait to rip around on it come spring time!
2001 Suzuki DRZ400s/sumo - The Daily...BRAAAP!!!! 2000 Honda RC51 - Traded 1978 Garelli Gran Sport LTD - Sold 1986 Honda Goldwing Aspencade - Sold 2004 Kawasaki Ninja 250 - Sold |
01-27-2013, 02:00 PM
#17718 |
Oddometer: 229
01-27-2013, 04:48 PM
#17719 |
Oddometer: 818
Ran the MRD/SSW pipe today with only the spark arrestor (removed quiet core), tis louder for sure, but definately gained some power.
Just some dude... |
01-27-2013, 06:08 PM
#17720 | |
Oddometer: 1,690
You're probably feeling a more abrupt change in power as it climbs out of the bottom end / mid-range hole created by that pipe. It really needs at least cams and carb before it starts to work properly.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
01-27-2013, 06:23 PM
#17721 | |
patty cake champion
Oddometer: 3,396
Id go the fcr-mx route first though, that really makes a difference you can feel, prob more than any other single upgrade. even on a stock pipe and stock engine, if your gonna spend $600 get the pumper carb.
Unregistered destructive device. |
01-27-2013, 10:28 PM
#17722 | |
Oddometer: 1,690
I was trying not to piss on 150ron's parade too much. I have been assuming ever since this exhaust was fitted that he would also be doing the cams, carb and BB as money permits. You're right though... FCR + 3x3 with stock cams and exhaust is worth about twice the gain of a jetted BSR + 3x3 so it is clear that the stock engine is initially carb limited. There is a night and day difference in response. An appropriately sized and tuned pipe will help a little... but at the end of the day it is about the full combination of parts. FWIW, the MRD is too much for my strokers which are running low to mid 50's... Bearing in mind that I have been tuning for 6k torque and 8k power peaks (so not a race engine - MRD is a race pipe) I've achieved better all round results with longer tapers and a smaller final pipe diameter.
01-28-2013, 07:26 AM
#17723 | |
Oddometer: 1,690
![]() http://www.advrider.com/forums/showthread.php?t=718131 http://advrider.com/forums/showthread.php?p=18914987
01-28-2013, 08:11 AM
#17724 | ||
Beer Knurd
Oddometer: 4,561
01-28-2013, 12:10 PM
#17725 | |
pining 4 the fjords?
Oddometer: 527
What Rumble Strip??? http://www.advrider.com/forums/showthread.php?t=734616 http://www.advrider.com/forums/showthread.php?t=723302 |
01-28-2013, 12:32 PM
#17726 |
Oddometer: 482
Kick-start installation
I installed the kick-starter on my E yesterday. It went surprisingly well, in spite of the way the instructions read.
I didn't have the special tool for holding the clutch, so I put the transmission in 5th gear, stuck a big screwdriver in the rear sprocket, against the swing arm, and loosened the nut. Put it on the same way. A 1 1/16 socket fits the nut (27mm) perfectly. Technically, it's 4/10,000 inch small (1.0625" vs. 1.0629") but neither nut nor socket noticed. The parts kit is somewhat strangely packaged, with unrelated parts in several plastic bags. For example, I thought the starter shaft seal was missing but it turned up inside the compression release lever cover. Those two parts were in one of the bags. Other weird combinations made me scratch my head. Everything was there, though, including a new cotter key for the rear master cylinder linkage. With the Unabiker radiator guards in place, the compression release assembly gets ugly. Installing the cable is a trick. Possible, but tricky. Finding room on the left handle bar is tough, as mine has a horn switch and mirror, for road-legal riding. Had to pull off a brand new grip, as well. The lever mount is one piece, and slides on the end of the bar. Put the new Tonn's skid plate on, too. They're very nice. I went with the bare aluminum version. The steel one is less money but I haven't ever seen one, so was skeptical. Jon
Hey - if it ain't an adventure, it's just a ride! '04 KLR 650 '05 DRZ 400E Titled/Plated |
01-28-2013, 01:25 PM
#17727 |
projects > time alloted
Oddometer: 79
I was just wandering around over in the wr250r forum which I was once a usual poster when suddenly I became grateful that I did not need to put a big bore and change all kinds of shit on the DRZ to make it feel like a real motorcycle. I was doubtful when I went back to the DRZ cause of the sixth gear, fuel injection thing... but all in all I am much happier on my DRZ... that is all, just felt like sharing :) torque is nice...real nice!
01-28-2013, 06:15 PM
#17728 |
lone rider
Oddometer: 841
drz shock wanted. Recommendations?
I have a wtb in the FM but I would like a little input from drz owners. I have an 02 DRZ400 that I just recently bought. The rear shock is worn out. Can I rebuild it or anything. I weigh 225 and need a good one. Not in the ohlins price category either. Any suggestions or anybody got one they would sell me reaonably that is in good shape and not used up?
When I'm dead, I sure don't want people thinking I never really lived. Hell with that. Set tall in the saddle, hold your head up high...Keep your eyes fixed where the trail meets the sky....Live like you aint afraid to die. And don't be scared, just enjoy the ride. "Chris Ledoux" superdutyGS screwed with this post 01-28-2013 at 06:39 PM |
01-28-2013, 07:04 PM
#17729 | |
Oddometer: 1,690
For your weight I'd suggest a 6.0kg/mm rear spring matched to 0.50kg/mm front springs. Add Racetech valves (front and rear) if you have the coin... Highly recommended and they come with DVD howtos clearly explaining every step of the process. As the rear is shagged I'd also have a very close look at the front and renew all of the wear parts. It gets very expensive if suspension is allowed to wear beyond its limits for the sake of a few bucks in small parts.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 01-28-2013 at 07:10 PM |
#17730 |
lone rider
Oddometer: 841
shock fit
will a shock from a 07 SM fit an 02 S model? I don't find a chart or cross reference anywhere.
When I'm dead, I sure don't want people thinking I never really lived. Hell with that. Set tall in the saddle, hold your head up high...Keep your eyes fixed where the trail meets the sky....Live like you aint afraid to die. And don't be scared, just enjoy the ride. "Chris Ledoux" |
