02-03-2013, 06:05 PM
#17791 |
Oddometer: 1,690
Don't be such a killjoy!
![]() Seriously though... if wheel changes are being made on a regular basis then there will be a lot of wear and tear on the caliper mounts.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
02-03-2013, 06:34 PM
#17792 | |
Butler Maps
Oddometer: 14,427
he is the master.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
02-03-2013, 06:44 PM
#17793 |
Meanderthal
Oddometer: 1,391
I'm a believer in the James Dean Jetting kits. They are designed to work with the 3x3 mod, which is to remove the snorkle in your airbox and enlarge the hole to 3"x3". This gives more air to go along with the increase in fuel that the jetting kit provides. The kit comes with very good instructions, but they forget to mention to buy the Kientech extended fuel screw and use the stock pilot jet when re-jetting. The Kientech richens up the pilot circuit, which eliminates the need for the larger pilot jet. I did this mod to three DRZ-S's and they all turned out great. I ride in 14f degree temps (-10c) and the bike runs very well.
Tom - '07 DR-Z400S, '05 DL650 Dual Sport Luggage Racks: DRZ400, DR650, KLR650: http://www.moto-racks.com "I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott |
02-03-2013, 07:17 PM
#17794 | |
Oddometer: 1,110
Regards, Derek motolab screwed with this post 02-03-2013 at 07:58 PM |
02-03-2013, 08:40 PM
#17795 | |||
Wannabe
Oddometer: 1,242
Thanks for all the replies!
2008 Suzuki DRZ400S |
02-04-2013, 02:06 AM
#17796 | |
Oddometer: 9,698
- Mark |
02-04-2013, 06:17 AM
#17797 | |
Oddometer: 432
Try that first its reversible with no ill effect
A good time to keep your mouth shut is when you’re in deep water! DRZ400S BMW R100/7 BMW1150GS Yamaha TY 175 trials KLR650sold |
02-04-2013, 10:12 AM
#17798 |
full metal jock-itch
opps
Wednesday before leaving for 2 weeks of work in -72'c temps in the yukon i did a brewery tour at 11am then went to blackfoot moto in calgary and bought this bad boy. feels good to have a bike again
ahhh, yeah i told you that would happen.... quick run |
02-04-2013, 12:20 PM
#17799 | |
Beer Knurd
Oddometer: 4,561
Pic isn't showing up for me??
I get the jest though. I get the same way after drinking a pile of good beer. Loose wallet straps!
02-04-2013, 12:21 PM
#17800 |
Oddometer: 230
02-04-2013, 12:35 PM
#17801 |
Butler Maps
Oddometer: 14,427
ok. so you're stepping up to the plate and so then people can contact you and you'll have the proper free jetting advice for the different carbs (fcr & cv) and with and w/o pipes. i know one of eddie's right hand man and he tuned with a dynojet tuner w/ all the scenarios. it's always good to have several opinions as it's a fuzzy science.
02-04-2013, 01:55 PM
#17802 |
Oddometer: 818
stock drz400s gas tank question.
So im thinking about throwing on the stock tank that came on my 2007 DRZ400S, (i bought the bike with a IMS 3.2 gallons tank allready installed on the bike with a aftermarket ON/OFF/RESERVE petcock)
to go about doing this 1. I remove the ON/OFF/RESERVE petcock from the IMS tank and put it on the stock tank instead of the stock petcock? 2. i see what appers to be like a little vent line coming out of the stock metal tank, it is right by where the 2 mounting holes are at the seat location, what do i do with that? is it a vent line, or was it something to do with the california charcoal smog crap (all the ca smog crap has been removed by the PO). ( i can take a pic of this little ''vent line'' if needed) 3. does the stock gas tank vent at the locking cap? 4. the stocker is 2.6 gallons? any and all help will be appreciated, thanks Ron
Just some dude... |
02-04-2013, 02:09 PM
#17803 |
Huh?
Oddometer: 508
If you want to keep the On/Off/Reserve fuel cock, otherwise use the stock fuel cock. 2. i see what appers to be like a little vent line coming out of the stock metal tank, it is right by where the 2 mounting holes are at the seat location, what do i do with that? is it a vent line, or was it something to do with the california charcoal smog crap (all the ca smog crap has been removed by the PO). ( i can take a pic of this little ''vent line'' if needed) That is the tank vent. Attach a line and mount it high up on the frame or under the tank somewhere. 3. does the stock gas tank vent at the locking cap? No. 4. the stocker is 2.6 gallons? Yes.
Pauly '06 DR-Z400S |
02-04-2013, 02:33 PM
#17804 |
Oddometer: 818
Thanks ptgarcia!!
Where does the stock tanks vent's line usually go?
Just some dude... |
02-04-2013, 02:43 PM
#17805 | ||||
ride2discover
Oddometer: 3,177
This one does have the vacuum pulse switch valve ass. Mostly use on SM models. I hope this helped...
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". |
