Old 02-19-2013, 04:13 PM   #18076
DualSportDad
DualSportDad's Avatar
Oddometer: 2,123
[QUOTE=buls4evr;20762038]
Originally Posted by DualSportDad View Post
Exactly why I use the Raptor petcock and shut it off each night after use............. Nothing says Viton won't fail over time also though so I would not trust it totally either. Ethanol is nasty stuff.
I agree. When I had the fcr on I never turned my fuel valve off... I did replace the o ring once cause it was leaking tho. That was a long time ago. But the fcr has the overflow tube. I wonder how hard it would be to add one into a bsr float bowl. For now I just have a Vinton o ring on there and turn the fuel off to be safe.
If I could find a cheap or near free bsr I'd try to drill a hole in the float bowl and stick and tube in it.
Sent from my Nexus 7 using Tapatalk 2
Alex
Cape Coral, Fl.
2003 KLX400R tagged
DualSportDad is offline   Reply With Quote
Old 02-19-2013, 04:32 PM   #18077
955616846
Oddometer: 1,722
Originally Posted by 59DEN View Post
Is there something to suggest that you have a problem?
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800, 13 FXST
Founding member Longtails SC
My Bike Pages
955616846 is online now   Reply With Quote
Old 02-20-2013, 01:05 AM   #18078
59DEN
59DEN's Avatar
Oddometer: 482
Hi numbers, no problems, the old bike is running well, just interested for future reference. Cheers for the heads up on the Toppeak digital tyre guage, works a treat.
59DEN is offline   Reply With Quote
Old 02-20-2013, 05:16 AM   #18079
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 461
Originally Posted by Tropic-Of-Canada View Post
Tropic-Of-Canada, looking at the picture/s looks to be a lot of small dirt/dust on the wiring harness and frame. If this is then the dirt/dust could fall into your engine while you are working on it, If there is dirt/dust then I would suggest that you close up the engine and wash off the dirt/dust to be safe. You may have already done that but not sure from the looking at the pictures.
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is online now   Reply With Quote
Old 02-20-2013, 06:51 AM   #18080
inroads
Wimberley,Texas
Oddometer: 79
80/100-21
Could you guys tell me if I am ok with a 2.75x21 front tire or should I be running a 3.00-21?
my manual says 80/100-21.
inroads is offline   Reply With Quote
Old 02-20-2013, 06:54 AM   #18081
wingam00
wingam00's Avatar
Oddometer: 461
Belive that both will work, but I prefer the 3.00 x 21 or 3.25
Mark
Old 02-20-2013, 07:04 AM   #18082
955616846
Oddometer: 1,722
I thought as much, but with all of the questions you did have me wondering for a while.
No worries... I am glad that gauge is working for you.
Cheers, Numbers
My Bike Pages
Old 02-20-2013, 08:12 AM   #18083
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 1,646
If you want to put a DOT tire on it you are pretty much stuck with a 90/90 X21. A 3.00 is very similar in circ. They come with an 80/100 but that circ varies a lot depending on whether an E or S type tire. The Deathwings are tiny in circ. Either way your speedo/odo combo will be off about 10% anyway(optimistic).
buls4evr is offline   Reply With Quote
Old 02-20-2013, 08:41 AM   #18084
150ron
150ron's Avatar
Oddometer: 869
Im running a 2.75-21 up front, i like it.
Just some dude...
150ron is offline   Reply With Quote
Old 02-20-2013, 09:44 AM   #18085
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,203
Not really they have variety out there of dot approved tire of different sizes 80/100-21 and 90/100-21. like this one : Pirelli MXMH provide with both sizes
or this one: Pirelli MXH
They are both DOT. Also Kenda Parker DT have them DOT in both sizes (80/100-21 & 90/100-21) the 90/100-21 is a bad ass tire (Kenda Parker) it worked great in mud, sand or loose gravel.
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is online now   Reply With Quote
Old 02-20-2013, 10:18 AM   #18086
Tropic-Of-Canada
pining 4 the fjords?
Tropic-Of-Canada's Avatar
Oddometer: 553
Yea, I hear ya, I gave it a good wipe in the critical areas and anywhere I was going to bumb, but you're right, I should be more thorough.
Tropic-Of-Canada is offline   Reply With Quote
Old 02-20-2013, 11:55 AM   #18087
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 1,646
I couldn't really tell what Inroads was concerned about as all these tires fit a DRZ just fine as you indicate. Lots of room up there to mount any of them. Perhaps he believes that he needs the exact same size that the factory put on.He doesn't as we know.Lots of choices.
Old 02-20-2013, 12:39 PM   #18088
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,203
Try this one it's an agressive Enduro tire and dot as well.
http://www.motoz.com.au/shop_proddetails.asp?prodID=137
I got the Tractionator 120/90-18 ready to be on soon as burn the hell out my Maxxis desert I/T.
Old 02-20-2013, 01:17 PM   #18089
MuddySump
MuddySump's Avatar
Oddometer: 88
Originally Posted by 150ron View Post
Great trail ride yesterday,
was really nice out
Then i dropped it...
Must of been all the budweiser :)
Tiger 800XC
DRZ 400E
www.youtube.com/muddysump
MuddySump is online now   Reply With Quote
Old 02-20-2013, 01:33 PM   #18090
MuddySump
MuddySump's Avatar
Oddometer: 88
Changed my fork oil at the weekend, made a 'how to' video of it, hope it can help people
http://www.youtube.com/watch?v=LZwpWQQ01aQ
Tiger 800XC
DRZ 400E
Times are GMT -7.   It's 06:46 PM.
