Old 05-11-2013, 08:54 PM   #18736
Bad Daddy
Oddometer: 110
Originally Posted by 150ron View Post
Got the Zeta's on, install was very easy, everything fit on the stock bars just fine, cleard the clutch and the brake lever.
I do not know why tho, the resistors wires i bought, so that the LED blinkers wont blink super fast, do nothing, the LED'S still blink fast with or without the resistor wires, i wonder if its got anything to do with the fact that in the rear i have some NON LED bulb type mini turn signals, which take less energy then the stock bulb i assume, since its a smaller bulb, dammit, definately do not want it flashing fast like it is now.
Hope i did not waste $15 bucks on those resistor wires.
TST industries makes an OEM flasher for LEDs. Plugs right in, and no dicking around with resistors.
What is the red switch on your left hand side grip for?
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 05-11-2013, 09:19 PM   #18737
150ron
150ron's Avatar
Oddometer: 1,459
Originally Posted by Muddler View Post
Nice blinker/mirror integration Ron, looks very tidy
Thank you.
Originally Posted by Psycho18th View Post
I got the tusk version of those from Rocky Mountain. I really like the integrated signals. I figured they'd be toast quick, but have hung on for several years and many a slide down a rocky trail without missing a blink. Not sure about the quick flashing...sorry.
Psycho
Cool, i had the Tusk D-flex on a prior bike, great stuff for sure, very tough.
yeah, looks like i will have to now go that route, have a link by any chance?
Just some dude...
150ron is offline   Reply With Quote
Old 05-11-2013, 10:30 PM   #18738
Bad Daddy
Oddometer: 110
LED flasher for plug-in installation
[QUOTE=150ron;21388805]Thank you.
http://tstindustries.com/product.php...cat=261&page=1
Old 05-11-2013, 10:36 PM   #18739
150ron
150ron's Avatar
Oddometer: 1,459
[QUOTE=Bad Daddy;21389050]
Thank you.
Thanks, i should've just went that route
The Resistor wires i got do work now, but i need to put BOTH wires to one side for it to work properly, as i guess they do not offer much resistance, but if you connect them together, then it works fine, so ill be needing another set, 4 wires and all... will probably just grab that relay sooner or later, as that is the proper way to do this LED set up imho.
Just some dude...
Old 05-12-2013, 07:04 AM   #18740
mtbbker
MtbBiker
mtbbker's Avatar
Oddometer: 89
Thumb
Originally Posted by EOD3MC View Post
Since Blaster did most of the work, I got to take pictures ....
Got the bike up on the lift and started taking off the things that would just be in the way...seat, tank, exhaust, skidplate, carb....
Blaster had already drained the oil but we still had to drain the cooling system.
Then we started tearing down the top end...so far everything has gone fairly smooth...
(Took the below picture before pulling the cams so there would be no doubt the as to the cam positions when we put things back together)
Top end and cylinder removed...only the piston head left to swap.
The cylinder head slid right off the piston when we pulled it...no resitance there at all
Just a little side by side comparison before installing
new cylinder slid nicely into place...much tighter fit then the old one
Head assembly back in place...
and...after we got the cams and cam chain back in place...
that was it for the day...we needed an allen head socket for the torque wrench which we couldn't find.
All in all to get to this point was about 6 hours for the two of us. Nothing too difficult and we certainly weren't in any hurry. Having a second pair of hands made dealing with the cam chain much easier...
Hopefully have it all back together tomorrow...But that's back in Blaster's hands...I get to enjoy father's day with my daughters
CAnt wait for the rest, super
mtbbker is offline   Reply With Quote
Old 05-12-2013, 07:35 AM   #18741
Vzuke
Vzuke's Avatar
Oddometer: 152
Turn signal hyper flash fix.
I ordered one of these DRC IC relays from Wheeling for my turn signal problem.
https://www.wheelingcyclesupply.com/...rc-ic-relay/51
The thing is I installed some Buell turn signals on my 08 DRZ. They were still incandescent bulbs but I guess they had a lower wattage than the turn signal relay liked so they had hyper flash.
The turn signals were an homage to the Buell I used to own, plus they had a smaller profile, DOT approved, with smoked lenses, looked good with the Edge 2 light.
Guess I better take it easy out there, finding exact replacements maybe near impossible now.
I also installed the Zeta "turn signal" hand guards but I use those as running lights.
Vzuke screwed with this post 05-12-2013 at 07:38 AM Reason: text addition
Vzuke is offline   Reply With Quote
Old 05-12-2013, 08:10 AM   #18742
150ron
150ron's Avatar
Oddometer: 1,459
Nice, good price too, got any pics of your set up? id like to see those buell turn signals.
Just some dude...
Old 05-12-2013, 08:16 AM   #18743
blaster11
Go Rflagg42!
blaster11's Avatar
Oddometer: 7,174
and...after we got the cams and cam chain back in place...that was it for the day...we needed an allen head socket for the torque wrench which we couldn't find.
EOD...the help was/is greatly appreciated!!!! I had to pull the intake cam back out this morning as it was off by one tooth, all good now! I got all the tough stuff reinstalled so now just the hair that is left.
If everything continues to go well I should have it back running and doing the break in today.
blaster11 is offline   Reply With Quote
Old 05-12-2013, 09:06 AM   #18744
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,893
Was that before you closed it all up??
EOD3MC is offline   Reply With Quote
Old 05-12-2013, 09:21 AM   #18745
LSGiant
LSGiant's Avatar
Oddometer: 1,126
Thanks for all the pics
I have a 2000 that I bought used, just curios if it was still stock would the castings from the bottom, cylinder, and head match in patina? My do not so is it safe to say parts have been replaced?
"Keep it rural, don't over water"
2010 Concours, 2000 DRZ400E
COG 7524, IBA 46513, GLMC 214
LSGiant is offline   Reply With Quote
Old 05-12-2013, 12:46 PM   #18746
blaster11
Go Rflagg42!
blaster11's Avatar
Oddometer: 7,174
Yep.
It lives!!! Haven't ridden it yet but it does run and no funny sounds are emanating from it. I just need to get it reassembled and go for a ride now.
Old 05-12-2013, 12:58 PM   #18747
blaster11
Go Rflagg42!
blaster11's Avatar
Oddometer: 7,174
LED bulbs for UFO turn signals
So while I was at the parts store getting some oil I found these LED's to replace the crappy bulbs in my UFO fender, still not the perfect solution but better than they were by a long shot. I will try to get some video tonight as well.
Stock bulb
LED replacement
Old 05-12-2013, 02:16 PM   #18748
Vzuke
Vzuke's Avatar
Oddometer: 152
DRZ mods
150ron now you did it. You made me drag out the backup hard drive with all the DRZ stuff on it.
Buell turn signals with Edge2 tail light.
Since we still had the behemoth tags in 08 I had to extend the mounting points.
Backing is a truck mud flap. You can heat it with a heat gun and bend it. Use a nice straight edge and wait for it to cool.
Vzuke screwed with this post 05-12-2013 at 02:29 PM Reason: Finish post.
Old 05-12-2013, 02:30 PM   #18749
blaster11
Go Rflagg42!
blaster11's Avatar
Oddometer: 7,174
Mine did not match.
Old 05-12-2013, 02:32 PM   #18750
150ron
150ron's Avatar
Oddometer: 1,459
Great looking bike vzuke, really liking the ''SM'' these days,
got any info on your bigger rear fender pack?
Just some dude...
Times are GMT -7.   It's 04:32 AM.
