Old 05-23-2013, 04:14 AM   #18871
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,688
Originally Posted by LittleRedToyota View Post
Best looking one and super easy install, IMO.
Falcon86 is offline   Reply With Quote
Old 05-23-2013, 04:38 AM   #18872
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,792
If you get the Edge taillight, do yourself a favor and seal the lense and the holes where the wiring goes through the housing with silicon caulk. My two year old taillight just had to have a new resistor soldered to it because the taillight quit working. The brake light never failed though.
threadkiller is offline   Reply With Quote
Old 05-23-2013, 06:04 AM   #18873
Alacrity
Semi Pro Bar Vaulter
Alacrity's Avatar
Oddometer: 468
Originally Posted by See-Three View Post
I really like the look and functionality of the UFO tail light.
Sent from my ADR6410LVW using Tapatalk 2
Agreed
If you're out in stuff like this - skip the Edge. As threadkiller notes, sealing issues. Imagine it can be sealed, but water finds a way - I prefer simple. Lotta slop here, regularly, couple riders have had problems with the Edge. May not be its intended use tho. Plate mod was free
4 years no issues with a full Trick Dualsport kit the UFO. Replaced the bulbs with LEDs - per Blaster11 post - we'll see how they hold up. Brighter tho.
The greatest pleasure in life is doing what people say you can't. So far...its working. The bars low
Alacrity screwed with this post 05-23-2013 at 06:11 AM
Alacrity is offline   Reply With Quote
Old 05-23-2013, 06:29 AM   #18874
tdrrally
tdrrally's Avatar
Oddometer: 3,397
"Replaced the bulbs with LEDs - per Blaster11 post - we'll see how they hold up. Brighter tho."
what led is used ?
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 05-23-2013, 06:58 AM   #18875
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,839
Originally Posted by blaster11 View Post
So while I was at the parts store getting some oil I found these LED's to replace the crappy bulbs in my UFO fender, still not the perfect solution but better than they were by a long shot. I will try to get some video tonight as well.
Stock bulb
LED replacement
I did the same to mine...big difference
EOD3MC is offline   Reply With Quote
Old 05-23-2013, 07:11 AM   #18876
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 368
That's what I'm running with Zeta integrated flashers up front. So far I haven't slowed the blink rate. It seems more noticable when they are flashing faster than the rest of the blinkers around me (not that most people in SoCal actually use blinkers, but you know what I mean)
THRASHED is offline   Reply With Quote
Old 05-23-2013, 07:52 AM   #18877
Alacrity
Alacrity's Avatar
Oddometer: 468
Those are them - I ordered from a local Advanced Auto IIRC - get the big box autoparts store confused. Figure most can get them.
Anyone swapped out the 1157 with an LED? Hows it throw?
Thinking something like this after a few false starts
http://www.superbrightleds.com/morei...ycle-bulb/170/
Old 05-23-2013, 08:07 AM   #18878
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
Originally Posted by axia View Post
Is there a page somewhere of these 1300 that discusses sprocket sizes? I am due for a replacement, and I straight up don't get all the options. I mean, I guess I like the stock sizes but maybe I'm missing something glorious?
stock S gearing: 15/44
stock E gearing: 14/47
stock SM gearing: 15/41 (which, with the smaller SM wheel works out to about the same as 15/44 on the S)
for trail riding, imho, dropping the stock S gearing to 14/47 (like the E) is much, much better. 15/44 is too high for tight trails. i also like 14/47 better around the city (where speeds are generally under 50mph and you are doing lots of accelerating at lower speeds).
14/47 does mean you'll be revving higher at highway speeds, though, so there is a trade-off. (i do still cruise at 65 with mine at 14/47, but the engine is up in the RPM range.)
a lot of people seem to like to compromise at 15/47 or 14/44 which are about equivalent (1 tooth on the front is about equal to 3 teeth on the back) and puts you in between the stock S and stock E gearing.
LittleRedToyota is offline   Reply With Quote
Old 05-23-2013, 08:29 AM   #18879
kioti
Cruzinonline
Oddometer: 187
I threw this rack together last night for my newly acquired Zuke.
kioti screwed with this post 05-23-2013 at 08:35 AM
kioti is offline   Reply With Quote
Old 05-23-2013, 09:08 AM   #18880
revmaaatin
Sioux Empire Iron Horse
revmaaatin's Avatar
Oddometer: 447
Nice post.
On my DRZ 400S
I am running the 13/44; moral equivelant of the 14/47.
The new sprockets sitting on the bench are the 47 Rear, moving back and forth from 15 to 13.
this will require a 114link chain.
m.
revmaaatin.
Methodist Circuit Rider
Iron Horse in the Sioux Empire
...fine is the line between foolishness and daring....Paul Vasey Rivers of America
revmaaatin is offline   Reply With Quote
Old 05-23-2013, 09:36 AM   #18881
150ron
150ron's Avatar
Oddometer: 1,422
+2, GREAT POST.
i like 15/44 on my S, still climbs anything out on the trails, and hits 95+ mph on the way home.
Just some dude...
150ron is offline   Reply With Quote
Old 05-23-2013, 10:47 AM   #18882
twizzler
Oddometer: 34
Nice!
twizzler is offline   Reply With Quote
Old 05-23-2013, 11:15 AM   #18883
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,014
a lot of people seem to like to compromise at 15/47 .
I got 15/48 on my E, it seems perfect to do it all, from climbing any rocky uphill with ease to freeway ride at ~78 mph.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is online now   Reply With Quote
Old 05-23-2013, 01:38 PM   #18884
yosso
yosso's Avatar
Oddometer: 977
Originally Posted by 150ron View Post
+2, GREAT POST.
GPS verified?
Honda ST1300/2000 Suzuki DRZ400E/Ducati 750 Monster re-work Blog
yosso is offline   Reply With Quote
Old 05-23-2013, 02:39 PM   #18885
bobfab
bobfab's Avatar
Oddometer: 1,483
Im at 15/47 and i personally think the revs are too high to sustain cruising at 78-80mph.
Currrently trying to find a chain to go 15/41 for street duty
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Times are GMT -7.   It's 10:25 AM.
