Old 05-24-2013, 01:50 PM   #18901
dyslexiccaveman
Oddometer: 11
Starting and Idling problems
So, unfortunately I left the drz sitting over the winter without doing the proper winterizing and what do you know, it starts up with a lot of throttle but will not idle.
Thinking the idle jet must be clogged with old ethanol gas, I cleaned the carb and still no luck. I even had the mechanic clean it, and no luck. So I finally took the whole bike in and the mechanic thinks its an electrical problem but can't figure out the exact source of the problem. He suggested a sensor in the carb may be fried or the cdi box may be broken.
Has anyone else had this happen to them? Any help would be awesome
dyslexiccaveman screwed with this post 05-24-2013 at 01:54 PM Reason: adding detail
dyslexiccaveman is offline   Reply With Quote
Old 05-24-2013, 02:02 PM   #18902
CatfishRacing
Just a rider.
CatfishRacing's Avatar
Oddometer: 633
Change the pilot get.
Its so small that even when it's a little clogged it won't function properly.
I added a Pingel petcock to each of my DRZ's so I have an "off" that actually won't let fuel flow.
Unlike my eBay petcock that still flows gas even in the off position.
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
CatfishRacing is offline   Reply With Quote
Old 05-24-2013, 02:25 PM   #18903
dyslexiccaveman
Oddometer: 11
I have the cheap petcock and indeed it is a piece of junk, but how would that add to the problem?
Old 05-24-2013, 02:30 PM   #18904
tdrrally
tdrrally's Avatar
Oddometer: 3,452
i favor the raptor valve my self, less money and works as well
the stock pilot jet is way to small for a 125
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 05-24-2013, 03:25 PM   #18905
CatfishRacing
Just a rider.
Oddometer: 633
If you run Sta-Bil treated fuel on your last run of the season (if you have a last run of the season) and shut the fuel off and allow it to run dry you should be good to go on your first ride of the season.
As long as you address the battery issue.
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
Old 05-24-2013, 09:22 PM   #18906
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,720
I fully intended to put Sta-bil in last fall....and didn't. Would've been the first time I had ever used it.
SEA FOAM is great stuff. I just dump about a 1/4 of a can in and top off the gas. Get on and ride it like hell. Never had a problem with any of my bikes/mowers/weed eaters/etc...
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 05-25-2013, 12:41 AM   #18907
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,689
Best bang for your buck lighting solution.
Ideas?
Need to get the DRZ Rally Moto ready, or at least better than it is now, and the lighting situation stock definitely needs improvement.
Falcon86 is offline   Reply With Quote
Old 05-25-2013, 12:47 AM   #18908
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,689
Edit/double post.
Old 05-25-2013, 03:59 AM   #18909
Gadget678
Gadget678's Avatar
Oddometer: 1,206
Ideas?
I used the Trailtech X2 HID (had an extension cable tied to it to cover the nav gear)
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 05-25-2013, 05:28 AM   #18910
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,689
That looks awesome!
What'd you do to elongate the fairing like that?
Old 05-25-2013, 07:57 AM   #18911
Plane Dr
Plane Dr's Avatar
Oddometer: 888
Ideas?
HID from ddm. Cheap easy and stand up well
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 05-25-2013, 10:32 AM   #18912
Creeker747
Creeker747's Avatar
Oddometer: 281
That looks awesome!
+1
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!"
Creeker747 is offline   Reply With Quote
Old 05-25-2013, 11:48 AM   #18913
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
That fits DRZ400 too.
15W CREE LED Head light Lamp KTM Dirt Bike Dual Sport mx Enduro Off Road (Fits: DRZ400)
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 05-25-2013, 01:54 PM   #18914
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,690
That looks awesome!
Originally Posted by Creeker747 View Post
+1
In his sig is the link, it's a great thread I've been following and well worth the read
Te Hopo is offline   Reply With Quote
Old 05-25-2013, 03:19 PM   #18915
Gadget678
Gadget678's Avatar
Oddometer: 1,206
That looks awesome!
Trailtech X2 HID image (from: http://trailtech.net/light_comparison.html )
Basically it's a piece of 2mm thick plastic. What I ended up doing was building the nav tower to be free- standing, mounted the headlight, then 'filled the gap'. I went through a few different versions before deciding to attach at the widest point of the headlight, and cut a hole with the circular saw for the top light. All held in place with cable ties so that if I needed to get to the electrics of my nav tower in a hurry, I could.
Times are GMT -7.   It's 12:31 AM.
