Old 06-05-2013, 11:35 PM   #19051
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 599
Originally Posted by GypsyWriter View Post
Hmm, also something to look at. The chain seems to be in decent shape as does the rear sprocket; haven't looked at the front yet. How much play should the chain have, either laden or unladen?
Thing is though, the bike surges just at idle too, so I'm leaning toward the carbs. I guess we'll see once the JD kit gets here, I may ask the Dude for help on the carbs. I've been reading up on them and they don't seem too difficult but I'm worried about screwing something up.
The carb is simple to work on and hard to get off and on the bike. When you do have the carb in hand for disassembly for the needle notice how much tension is required to pull on the black plastic keeper over the needle. You will remember this because it also snaps back into place upon reassembly. It it isn't on properly it will run at idle but just off idle it will be terrible. To jet for Hanford which is essentially sea level select the 0-4000 ft settings. I live in the foothills at 1400 ft and ride in the mountains at 4K-9K most of the time so I run a compromise setting per JD. The bike runs much better at 4K and above than at home altitude.
coarsegoldkid is offline   Reply With Quote
Old 06-06-2013, 12:22 AM   #19052
150ron
150ron's Avatar
Oddometer: 1,301
Originally Posted by drizzt View Post
just thought i would share, on my ride home from work today:
liked!!
Just some dude...
150ron is offline   Reply With Quote
Old 06-06-2013, 05:14 AM   #19053
Every Miles A Memory
Oddometer: 87
Originally Posted by Drizzt View Post
Just thought I would share, on my ride home from work today:
You're my Hero!!
Pat Bonish
www.everymilesamemory.com
www.lowkeyhideaway.com - Come for a Visit!
Every Miles A Memory is offline   Reply With Quote
Old 06-06-2013, 05:15 AM   #19054
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 950
Cool any maintenance issues? Have you had to do a top end yet?
Achtung is offline   Reply With Quote
Old 06-06-2013, 06:14 AM   #19055
dasvis
dasvis's Avatar
Oddometer: 536
How many stators?
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 06-06-2013, 09:01 AM   #19056
Drizzt
Ranger
Drizzt's Avatar
Oddometer: 1,035
I've mostly been doing standard maintenance (oil changes, air filter, etc.) I just had to replace some seals because i had a mystery leak (now seams solved). No head work, but I should probably check the valves pretty soon, last was sometime at 20k. I'm on my second stator. I need to do the front brakes and fork seals at the moment too(second time for both), as well as desperately needing to do the swingarm maintenance (I've never done it). Had an odo cable go out a while ago, and I'm on my 3rd clutch cable. And I think I'm on my 4th or 5th battery, second starter motor (bought a used one when mine locked up). I think those are the only maintence items, everything else I broke being stupid or was aftermarket. Oh, and lots of tires
2000 Suzuki DR-Z400S
And what is good, Phaedrus, and what is not good- Need we ask anyone to tell us these things? Pirsig
Drizzt is offline   Reply With Quote
Old 06-06-2013, 10:37 AM   #19057
twizzler
Oddometer: 34
SuperMoto mode on my 2013 DRZ400S. Everthing fit great and I will be able to go back and forth between knobbies and the SM tires very easily! Cool.
twizzler is offline   Reply With Quote
Old 06-06-2013, 01:12 PM   #19058
150ron
150ron's Avatar
Oddometer: 1,301
VERY NICE!! Only thing missing imo is are the SM front forks and plastic guards they come with, they look so much better then the S forks with the accordians on em, lol
Just some dude...
Old 06-06-2013, 03:45 PM   #19059
Achtung
Achtung's Avatar
Oddometer: 950
What wheels are you using? Do you retain the stick speedo drive? Very nice!
Old 06-06-2013, 06:46 PM   #19060
twizzler
Oddometer: 34
Thanks, they are the RAD MFG wheels and the front hub is compatible with the stock speedo drive unit so I did keep the stock instrument cluster/speedometer. I prefer the look of the stock speedo over the Vapor one in particular even though the speedometer is off by 5-15 mph with the 17" wheels it's not a fast bike but extremely grin inducing.
Old 06-07-2013, 12:41 AM   #19061
Vzuke
Vzuke's Avatar
Oddometer: 145
Got a birthday present for my 08 DRZ.
Just hit the 20,000 mile mark also.
Also trying out some new tires, Conti Trail Attack. I went from a wore out 150/60 rear tire to a 150/70 and it is TALL. It feels like an inch taller! Luckily I have some long legs.
Vzuke screwed with this post 06-07-2013 at 12:44 AM Reason: edit text
Vzuke is offline   Reply With Quote
Old 06-07-2013, 08:31 AM   #19062
GypsyWriter
Sarah
GypsyWriter's Avatar
Oddometer: 1,439
Damn but these bikes look GOOD in white!!!
2012 R1200GS Rallye - Gypsy
2003 R1150GSA with DMC sidecar
Ask A Self-Publisher
Originally Posted by FotoTEX View Post
Life is dangerous. Not doing what you love makes life even more dangerous...
GypsyWriter is offline   Reply With Quote
Old 06-07-2013, 08:45 AM   #19063
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 338
I like the bike, but am curious why you have Zeta's with marker lights AND the stock blinkers? Or are those just reflectors?
THRASHED is offline   Reply With Quote
Old 06-07-2013, 02:19 PM   #19064
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,146
Headlight-octomy
I finally got around to doing the headlight swap I've been wanting to do.
Below are the results.
It still needs a little tweaking but much better light and IMO much better looking (opinions may vary)
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 06-07-2013, 04:05 PM   #19065
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,641
-Brian
Info please and thank you!
Falcon86 is online now   Reply With Quote
Times are GMT -7.   It's 01:37 PM.
