Old 06-14-2013, 02:12 PM   #19171
Abelha
Oddometer: 20
Have just stumbled into some info, here in Brazil, we apparently only have the E model, since the S would be the street model and we never had that one.
I also read that the E model has inferior electrics and it doesn't have a subframe on the tail, is there ANY way to setup a trunk on an E model and is it true about the bad electrics?
Abelha is offline   Reply With Quote
Old 06-14-2013, 02:14 PM   #19172
groop
So much to ponder
groop's Avatar
Oddometer: 3,286
Originally Posted by tt100 View Post
Anybody have a Clymers or Haynes they want to part with? ...and while I'm at it, any opinions on one over the other? Thanks
One in the FM. Better hurry.
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 06-14-2013, 02:40 PM   #19173
tallpaul63
Oddometer: 496
Information please
I spent some time cleaning the carb on my DRZ, including opening the float bowl drain, which may have been shut for a long time. Now reassembled, the carb leaks fuel from said drain. Is there a gasket or washer there that may have failed? Any thoughts? Replace it after ordering one from Suzuki, or are there any other options to get me running quicker?
Thanks in advance,
Paul
tallpaul63 is offline   Reply With Quote
Old 06-14-2013, 04:42 PM   #19174
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,979
Thanks in advance,
Paul
FCR-MX...if you only do one upgrade...this is it.
focallength is online now   Reply With Quote
Old 06-14-2013, 04:53 PM   #19175
ohgood
ohgood's Avatar
Oddometer: 2,878
Thanks in advance,
Paul
clean the seat and the tapered end of the screw well. scotchbright should do it. then it will seat again.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 06-14-2013, 06:16 PM   #19176
tdrrally
tdrrally's Avatar
Oddometer: 3,378
its my understanding that all the drz400 e and s electric start bikes have the same stator.
i could be wrong
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k1 i miss that bike
tdrrally is offline   Reply With Quote
Old 06-14-2013, 06:46 PM   #19177
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,674
Here is one. http://www.moto-racks.com/Products4.html
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Old 06-14-2013, 07:32 PM   #19178
DualSportDad
DualSportDad's Avatar
Oddometer: 2,440
Originally Posted by bobbed06 View Post
I had my OEM kill switch converted into a manual fan control switch and use my key to shut the bike off now. My engine is a high compression, cammed , 434 and it runs cool with stock rads. I also used a T Stat eliminator from the E model. No need for larger rads on the Dizzer.
Any idea what temp your bike runs at normally? I changed the coolant again in my bike and added water wetter and got it down to the 140's. That seems fine by me. I'll take the bike out on the highway tomorrow and make sure it doesn't climb too high. If it does I'll take it to the Dyno asap and have the a/f ratio checked.
Sent from my Galaxy Note 2 using Tapatalk 2
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 06-14-2013, 08:24 PM   #19179
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Normally runs in the 130-170f range depending on traffic. (Remember I dont have a thermostat either)
I have my Vapor set to warn me at 180f to turn my fan on, I have seen temps in the 185-205f if I forget to turn the fan on in extreme heat 100f temps and riding tight trails.
If I leave the fan on the entire time I am riding in hot temps 100f and in tight trails it seems to hover around 165-170.
When its cool out and I am riding on the highways or roads without the fan on it runs in the 120-135 range.
I never like to see any coolant temps on my machines off road or on road over 205f, although some of my GSXRs saw 230f prior to manually controlling the fan. I am happy with anything 180f or below in most situations.
bobbed06 is offline   Reply With Quote
Old 06-15-2013, 05:27 AM   #19180
ohgood
ohgood's Avatar
Oddometer: 2,878
Flush the cooling system once a year and forget it. The auto fan setup works great.
(Says the guy on stator number five)
Old 06-15-2013, 06:27 AM   #19181
rebar
Oddometer: 250
Pc310
I haven't found any info on the odyssey PC310 battery in the DRZ. I'm surprised I'm the first to try it. I usually follow..
It fits nicely after I hacked up my box for a superstart kit. I honestly think it would have fit without hacking the back out, but a bracket would be needed and it does push the cover out a touch just like Eddies kit did.
If this battery performs like the two other odyssey batteries I have (6 years plus) I will be satisfied.
Here it is.. And it cranks long and hard.
07 DRZ400s, 85 Vmax stock, 85 Vmax custom, E350 6bt/nv4500, Featherlite surv 24' toyhauler
rebar is offline   Reply With Quote
Old 06-15-2013, 09:33 AM   #19182
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
I'm reassembling the head on my KLX and have looked at what I think is a compression release mechanism on the exhaust cam.
It doesn't appear to be connected to anything and looks to have centrifugal weights, which move freely.
The shop manual shows a bracket attached to the left side of the head, which may be a part of this mechanism, but my engine doesn't have that.
Who can explain how this mechanism works?
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 06-15-2013, 09:52 AM   #19183
Bad Daddy
Oddometer: 103
I think if you had a kick start, you would require all of the bracketed, for a manual compression release.
I seem to remember that the kickstart kits come with the necessary gadgets to add manual compression release, but the S and SM heads don't support it. Only the E heads do.
If you look up the DRZ kick start install on this site, you'll see what I mean.
My Clymer manual doesn't show it, either!
BD
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 06-15-2013, 11:14 AM   #19184
focallength
You're Welcome
Oddometer: 4,979
BD
Old 06-15-2013, 07:48 PM   #19185
Muddler
Muddler's Avatar
Oddometer: 775
Footpegs
I would like to get more distance between my feet and the bars. I have already fitted risers, but still not comfortable standing. I have heard that YZ pegs are not offset up like the DRZ pegs. Can anyone confirm if they will fit?
Muddler is offline   Reply With Quote
Times are GMT -7.   It's 06:06 PM.
