Old 06-23-2013, 04:49 AM   #19291
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 549
Originally Posted by effensteve View Post
So, I'm pretty new to the wrenching bit. I have an 06 z with about 9k on the clock that's getting harder to start than I remember. Lots of cranking sometimes. the carb, air filter and oil are clean. It's gotten a couple of new plugs. Still hard to start. It has a yamaha petcock with the vacuum nub on the carb plugged. Could it need a valve adjustment?
or maybe something else I dont know.
Have you done any work on the carb?
Is the pipe stock? If not what has been changed as far as the motor? Pipe, cams, 3x3. etc..
How does it idle and run once it starts?
If it does not idle good, would guess, dirty pilot jet.
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is offline   Reply With Quote
Old 06-23-2013, 06:19 AM   #19292
STFU
Found
STFU's Avatar
Oddometer: 412
So the 2003 400E that I picked up needs a carb swap... seems that someone wanted the FCR39 and swapped it for the S model CV carb. I bought a replacement FCR from ebay only to discover that the throttle cables are different also.
Can anyone tell me if I can put the correct "E" throttle cables into the same throttle tube that the "S" cables fit in? DO I need a new tube also, or can I just swap cables?
Tiger 955i
450 EXC
STFU is offline   Reply With Quote
Old 06-23-2013, 08:41 AM   #19293
Plane Dr
Plane Dr's Avatar
Oddometer: 888
Just swap cables. You really only need the one cable
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 06-23-2013, 08:51 AM   #19294
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 752
I'll pull and clean the jets first, it does idle pretty low and sometimes dies when i take off from a stop. Carb first I guess.
thanks
effensteve is offline   Reply With Quote
Old 06-23-2013, 07:57 PM   #19295
axia
Super Schralpster
Oddometer: 60
Is there any particular reason that a (>500 miles) new chain would be stretching pretty significantly after every ride?
axia is offline   Reply With Quote
Old 06-23-2013, 08:49 PM   #19296
jdunay
time travler
jdunay's Avatar
Oddometer: 35
too tight??
get busy livin' or get busy dyin'. ellis boyd redding
jdunay is offline   Reply With Quote
Old 06-24-2013, 04:16 AM   #19297
tdrrally
tdrrally's Avatar
Oddometer: 3,453
i had to pull the carb on my drz250 twice in 12hrs to get the crud out of the carb.
the second time i added a filter
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 06-24-2013, 05:00 AM   #19298
Gadget678
Gadget678's Avatar
Oddometer: 1,206
What type of chain?
New or old sprockets?
As mentioned: tension.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 06-24-2013, 06:54 AM   #19299
LC8rider
LC8rider's Avatar
Oddometer: 659
Talking New to me 400E
Just got myself a 2002 400E. I'm a bit handy with the spanners, so when I went to view the bike I managed to haggle the price down ( -£700) to what I thought was a fair deal. So rather than buying a ride it now bike, it's more of a winter project! It's not as bad as it sounds, justs needs some TLC and consumables (rear disc, wheel bearings, c&s, cables etc..). Got a parts microfiche and a Haynes manual and a decent budget to make it a damn fine bike by spring.
Any pointers and a model specific heads up would be great. There must be weak points that need addressing (I've also got a KTM950 - all weak points sorted long ago and it is now a reliable and very very tasty bike).
The bike is going to be used for the trails. I'll need to travel some from where I live to get on them though, so I might need a bigger tank!
KTM 950ADV & Suzuki DRZ 400E
LC8rider is offline   Reply With Quote
Old 06-24-2013, 07:24 AM   #19300
Buliwyf
Buliwyf's Avatar
Oddometer: 359
Originally Posted by See-Three View Post
Something to get me through the summer, rack made from a piece of plywood.
Looks like a wooden stretcher! LOLz. Fitting for a dirt bike, I guess.
Buliwyf is offline   Reply With Quote
Old 06-24-2013, 10:25 AM   #19301
MartiniUp
Oddometer: 1,981
Only thing I would change is the holes. When too large they let the straps/cords slip and can let things shift, etc. And that orange has got to go, that will make your Suzy unreliable.
MartiniUp is offline   Reply With Quote
Old 06-24-2013, 11:46 AM   #19302
mp183
Oddometer: 310
2012 DRZ400S 1700 miles
Picking it up on Saturday.
Had to sell two bikes to my cousin to make room for this one.
Bike has been lowered.
It's too tame for my 17 year old but he has to get over it.
We sold off his TTR230.
He wanted a Yamaha wr250r but he's going off to college in the fall
and I'll be a heavy user of the DRZ.
I have a KLR250 which has been a rock solid bike for me but
I never really felt comfortable taking it out on longer rides.
Going to throw the KLR and the DRZ on a trailer and take them
out to NH and Maine ride some of the back roads.
From the looks of the seat it's not exactly for longer distances
so I bet we will be fighting over the KLR.
2004 DL650
2002 GS500
2004 KLR250
mp183 is offline   Reply With Quote
Old 06-24-2013, 01:10 PM   #19303
mebgardner
Oddometer: 76
Anyone got a CA gas cap in their spare parts bin?
I need a recent vintage OEM gas cap for a DZR400-S "CA" tank, (non-rotating type cap, they're usually silver, not black).
I've got a 2007 CA model OEM tank, and the gasket has rotted away.
So, I really need just the gasket, but it seems I can't buy just that.
If you have a somewhat newer cap (or one that that has been stored well and / or seen little use) kicking around in your parts bin, I'd like to buy it from you.
Thanks very much.
mebgardner is offline   Reply With Quote
Old 06-24-2013, 04:39 PM   #19304
outlaws
Oddometer: 364
Anyone know the axle diameter of our bikes? I' wanted to pick up one of those Kaurit Moto Tire Tool and not sure if I need an adapter or not.
outlaws is offline   Reply With Quote
Old 06-24-2013, 05:31 PM   #19305
rustycager
rustycager's Avatar
Oddometer: 717
The front axle measures .785" not sure on the back. That is a slick tool.
rustycager is online now   Reply With Quote
Times are GMT -7.   It's 11:27 PM.
