Old 06-26-2013, 02:10 PM   #19336
hasenwerk
hasenwerk's Avatar
Oddometer: 1,326
Recent mods to my 400S
Over the past weekend I did some upgrades to my 2009 400S - figured I would do a show and tell!
First was a wider luggage rack to hold my dry bag that holds my tent and sleeping bag. $6 with of 12x16" aluminium, $10 to get it it bent at 45 degrees at the back, $8 for the 1" hole saw and some stainless fasteners.
Next I added the Trail Tech Tachometer and transfered my Garmin 60Cx with the Touratech Holder from my 1100GS.
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline   Reply With Quote
Old 06-26-2013, 02:17 PM   #19337
hasenwerk
hasenwerk's Avatar
Oddometer: 1,326
Question DRZ 400S and 41T rear sproket
I think I am doing it wrong!
I want to drop my highway RPMs a tad, so I bought a 41T sprocket to replace the 44T sprocket. The logic behind it is say I am riding for a few days on the highway before I get the dirt - would be nice to make that highway cruising a little more relaxed and then spend 10 minutes to swap out the rear cog for the 44T sprocket. Minimal tools are required - 6mm allen and a 12mm wrench plus the wrenches to remove the rear wheel. Oh yeah... Suzuki bolts are quite soft I am finding...
Is issue is now my chain is too long. On the 44T sprocket I have the "snails" at 5 and with the 41T in there I can't adjust it back enough.
If I remove a link pair from the chain, will I be able to still use the 44T sprocket?
Old 06-26-2013, 02:42 PM   #19338
bobfab
bobfab's Avatar
Oddometer: 1,482
^^What front sprocket are you using? 15T?
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 06-26-2013, 03:50 PM   #19339
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,012
I planned a ride to The Grand Canyon for our AZ folks, it's a yearly 2 days event that set the stage for major rocky and versatile terrains to tackle. It's suppose to be 430 miles off-rd but dueto mechanical mishaps here and there I had to shortened the route down to ~ 355 miles.
Taking a fix up break.
My Z sleeps inside tonight.
And to make it a perfect trip we had a chase truck with trailer for any needs or emergencies.
Horses and bikes they don't mix.
Later on that day (day2) and for riding so ferocious on rocky trails try to keep up with Baja racers I got this to deal with:
Renthal Bars Snapped in half I got to keep the shiny side up though and got it to full stop without issues. I got my scares of the day.
Quick fix to get me out to the chase truck. I didn't have the center bar piece on, that would have prevented it from cracking like that.
I salut you from AZ the great Grand Canyon state. Till next time.
Pics from the south rim (hwy 64).
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 06-26-2013, 04:05 PM   #19340
tdrrally
tdrrally's Avatar
Oddometer: 3,395
looks like a good time
makes me home sick
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 06-26-2013, 04:36 PM   #19341
150ron
150ron's Avatar
Oddometer: 1,421
Great pics, thanks for sharing,
ive never seen bars snapped like that.
Just some dude...
150ron is online now   Reply With Quote
Old 06-26-2013, 04:42 PM   #19342
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,012
I just got a new Seat Concepts $150 . My ass is going for even longer rides now..A new battery "Phantom" just like Shorai with 9amp cranking power, A Tag handlebars, oil/filter and new Maxxis tire. Ready to roll again.
Old 06-26-2013, 04:53 PM   #19343
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,012
I guess I got to quiet the heavy weight when I hit the gym , I was shocked too that this happened to me. My buddy Mike (an expert Baja racer/owner of motorcycle parts co.) Was with us and suggested that: not having the center bars piece could be a factor why it snapped like this. There's Flex handlebars but they're over $300, no thanks I said.
I might inject Bar buzz kill into the handlebars to even be sure it won't happen again.
http://www.barbuzzkill.com/site/defa...=1372112620103
Old 06-26-2013, 05:22 PM   #19344
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,845
I did the same thing. I took out a link in the cahin because I like the lower highway rpm's and still works fine on the fire trails and gravel.
Wanna keep your chain lenght,swap the front sprocket.......
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 06-26-2013, 05:56 PM   #19345
See-Three
C3
See-Three's Avatar
Oddometer: 144
when removing the rear sprocket you want to break the nut on the inside of the wheel loose with a socket. first try it without even using the allen head, If the bolt spins with the nut simply use the allen head to hold it in place while you break the nut free.
See-Three is online now   Reply With Quote
Old 06-27-2013, 07:36 AM   #19346
bobfab
bobfab's Avatar
Oddometer: 1,482
x2... but i imagine it was because you removed the center support. They were just 7/8 bars not OS 1-1/8's
Looks like an amazing trip through!
CRF250L | KTM200SX
Old 06-27-2013, 09:36 AM   #19347
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 368
+1
Also make sure you are all the way on the nut with the wrench/socket. These are super soft as well. I stripped one off the first time I swapped out the sprockets.
As for sizing, I removed a couple of links. With the 44 I'm on 0 and with the 41 I'm on about 3.5.
THRASHED is offline   Reply With Quote
Old 06-27-2013, 01:45 PM   #19348
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,513
Did the control Rd up the back side of Mt Lemmon on my DRZ, I loved it!
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 06-27-2013, 01:57 PM   #19349
tdrrally
tdrrally's Avatar
Oddometer: 3,395
ride up to alpine have lunch and the bear wallow
then hit the ohv trail over to eager
Old 06-27-2013, 02:01 PM   #19350
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,462
Between the 650r and 950, the 400s is feeling very under powered and somewhat boring to ride.
Its completely bone stock, no airbox mods (only a gutted exhaust)
any ideas?
Been told the FCR/3x3 header and exhaust will do the trick... Is the FCR needed?
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Times are GMT -7.   It's 09:59 AM.
