Old 07-04-2013, 05:07 AM   #19426
lam007
Oddometer: 25
headlight
Does anybody have an extra drz 400 headlights laying around in white. It can be the full thing with the light or just the plastic shroud.
lam007 is offline   Reply With Quote
Old 07-04-2013, 05:23 AM   #19427
tdrrally
tdrrally's Avatar
Oddometer: 3,349
dr headlights works well too
1997 DR350se
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 07-04-2013, 05:53 AM   #19428
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,692
Originally Posted by carbon_unit View Post
Here is a third way to skin that cat.
http://drriders.com/topic5258.html
video
https://www.youtube.com/watch?v=vbtnlF4XGso
I use this on my DRZ400 and it gets the wind off of your chest and I like the velcro mounting in case I need to jump the bars in a hurry. (deer)
This is really really awesome. Must try.
Thank you!
Falcon86 is offline   Reply With Quote
Old 07-04-2013, 01:15 PM   #19429
150ron
150ron's Avatar
Oddometer: 1,358
Pics dont do it justice, tis like a freaking wall, lol, rated red diamond (expert only), DRZ DOING WORK!!
Really enjoying this bike to the fullest.
Just some dude...
150ron is offline   Reply With Quote
Old 07-04-2013, 01:31 PM   #19430
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,692
Second wide open or second with some serious clutch workage?
Old 07-04-2013, 01:42 PM   #19431
150ron
150ron's Avatar
Oddometer: 1,358
Running stock 15/44 gearing, 1st gear WFO all the way to the top go big or go home with that climb, if i even let go of the gas a bit, ill drop it, (stall) no clutch at all, 14/44 would be so much better imo, but i enjoy my 95+mph bursts on the way home too much to change gearing
With the HotCams/MRD SSW, first gear can reach 25mph, the HotCams made it pull much harder.
Just some dude...
Old 07-05-2013, 10:45 AM   #19432
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
JD Jetting kit question (DRZ400S)
I am installing (actually its done..sorta) the JD Jetting kit on my DRZ400S and have a quick question for those that know.
When installing the oem washers on the needle valve, there is a noticable space between the plastic spacer and the clip. Unless I use alot of force it will not "seat" on the clip as it does on the stock needle.
See pic.
Is this space normal (how it should be left)? Or should it be sitting snug under the clip (as oem)?
thanks in advance
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 07-05-2013, 11:56 AM   #19433
carbon_unit
carbon_unit's Avatar
Oddometer: 43
The plastic washer needs to be up against the clip.
carbon_unit is offline   Reply With Quote
Old 07-05-2013, 01:05 PM   #19434
jhock
Oddometer: 2
Just joined the ranks of DRZ owners, a 2004 DRZ400s with 6800 miles.
Pick it up next Saturday, needs few bits, hand guards, some higher bars (I am 6' 3") and bigger tank at some point.
Cant wait to get on and use it!
jhock is offline   Reply With Quote
Old 07-05-2013, 01:59 PM   #19435
The Toad
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Thanks.
In hindsight kind of a dumb question.
Oddly enough the bike runs exactly the same either way
Old 07-05-2013, 02:13 PM   #19436
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,692
Congrats!
I highly recommend Pro Taper ATV Hi Bars.
Old 07-05-2013, 03:17 PM   #19437
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,505
I just joined the ranks of DRZ400 ownership, bought a 2001, looks nice 5,000 miles, $1,800.00, i know it has the suspension that is not as tunable in the front as a 2002+, i am addressing the loose counter sprocket, yes it was loose, but the counter shaft is in good shape and i will do the locktite fix, but i have a few other questions.
1. The rear shock has 2 adjustments, my friend who has a DRZ was showing me how to turn the larger nut in and out, and while doing this he backed it way out and a little fluid leaked out, not good right? the shock still seems to work fine after screwing it back in.
2. What are the adjusting nuts/ screw features, what does the nut do and what does the little screw do.
3. Will gold valves help the front or should i seek out a 2002 and up front end, i dont want to throw good money after bad so to speak by purchasing gold valves if they dont help a DRZ that much, i did them on my DR650 and liked it.
I am only going to address the suspension now, the bike has all the power a 51 year old man need for goofing around in the woods.
ChromeSux is online now   Reply With Quote
Old 07-05-2013, 04:16 PM   #19438
tdrrally
tdrrally's Avatar
Oddometer: 3,349
unless your a great rider or racing don't worry about the suspension
1997 DR350se
Old 07-06-2013, 10:06 AM   #19439
-TRED-
-TRED-'s Avatar
Oddometer: 181
help
I just had my stator and battery replaced and I am still not able to keep a charge. I have very limited mechanical skills so if anyone has any suggestions for what can cause a new stator from charging the batter I would appreciate it.
'07 WR450F
'04 DRZ400S (FOR SALE)
I was going really fast until I crashed.....BRAAAAP!
-TRED- is offline   Reply With Quote
Old 07-06-2013, 10:10 AM   #19440
FamilyRider
FamilyRider's Avatar
Oddometer: 256
Do the "free power mod". You can find info on ThumperTalk. It is common for the connectors between the stator and battery to have too much resistance, which prevents the battery from charging fully. I was constantly replacing batteries and components until I learned that simple mod. I haven't had any trouble since.
2014 KTM 350 XCF-W
FamilyRider is offline   Reply With Quote
Times are GMT -7.   It's 05:50 PM.
