Old 07-06-2013, 01:12 PM   #19441
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
Originally Posted by ChromeSux View Post
1. The rear shock has 2 adjustments, my friend who has a DRZ was showing me how to turn the larger nut in and out, and while doing this he backed it way out and a little fluid leaked out, not good right? the shock still seems to work fine after screwing it back in.
2. What are the adjusting nuts/ screw features, what does the nut do and what does the little screw do.
The Larger nut should not be touched (it's there to disassemble the rear shock when necessary), if it leaked oil most likely air went in, this happened to me last year. I had to rebuild my rear shock don't take the risk and ride it this way. It might be good for you to rebuild the rear shock after all.
The top screw is the compression adj. the bottom one is the rebound. I set them up hard setting when riding on sand/soft terrains etc... and soft when doing rocky stuff or hard terrains. U can also find a compromise setting that can work for all around riding (See Clymer manual for better understanding the adj. process).
To adjust the setting u should first start by close the screws (top & bottom) all the way by turning them clockwise. For example the compression screw (top rear shock), if you wanted it too soft u must turn the screw 15 clicks or more counter clockwise. Ride it a little to see if it's to ur satisfaction and so on.
Prior to do that it's highly recommended to set the sag to ur height & weight accordingly. I posted some video from youtube in a previous posts on how to do that. Good luck and have fun with ur new ride.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 07-06-2013, 01:19 PM   #19442
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,536
So stoked. Picking up my DRZ462E tomorrow!
stevh0 is offline   Reply With Quote
Old 07-06-2013, 02:17 PM   #19443
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,943
Originally Posted by tdrrally View Post
unless your a great rider or racing don't worry about the suspension
Now that is piss poor advice!
The suspension adjustments are more important to a novice rider than an experienced rider when it comes to control confidence.Regardless of skill or ability the suspension adjustments are the first thing someone should learn to understand. Suspension can make a poor bike great or screw it up and can make a great bike unrideable. Set up the sag first for your weight then make little adjustments to one component at a time, fine tune after finding your sweet spot on each adjustment. Don't just jump in and make changes to compression, rebound, sag or damping all at one time. Change one thing at a time until you have improved the ride then move to the next component. Start with the sag and move on from there.
Just say'n..............................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 07-06-2013, 02:26 PM   #19444
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,961
I ju
Parts are dirt cheap for these things find a used front end.
You need to take that on the TAT...
BTW- traditionally these bike are sprung on the light side, you might need to change springs too.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 07-06-2013, 02:28 PM   #19445
tdrrally
tdrrally's Avatar
Oddometer: 3,456
bill crap
i have owned a lot of bikes over the years
the adjustments are very nice to have but not that important for the average rider.
i had drz400s forks on my drz250 for a year or so and never missed it
the rm forks i later put on it, has a broken adjustment screw dont miss it
learn to ride what you have the way it wants to be ride'n
stiffer springs will help if needed. re valving the shock is not needed in most cases. worth it if you have the cash.
a dr200 is good bike no adjustments short of spring preload, never missed the adjustments either.
get the bike and go ride it find out you need
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 07-06-2013, 03:23 PM   #19446
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,943
bill crap
Apparently you've never ridden a properly set up motorcycle before..........
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 07-06-2013, 03:24 PM   #19447
Spacelord
Mutha Mutha
Spacelord's Avatar
Oddometer: 875
You must be slow as hell and weigh 140 lbs.
Take a break from giving suspension advice.
"I swear to god that I will beat you senseless with a sanka can before I die"
Spacelord is offline   Reply With Quote
Old 07-06-2013, 03:27 PM   #19448
Jim patton
Oddometer: 21
Who needs suspension
Or tires, steering head bearings, brakes, use rope for your chain.
It's just your life, don't sweat it.
Jim patton is offline   Reply With Quote
Old 07-06-2013, 03:35 PM   #19449
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,689
I have got to get my suspension dialed in. I've been trying to really work on lofting the front wheel up and over obstacles/potholes in the trails, and I feel like I've got the concept down but the front shocks don't seem to be working with me. I'm not weak by any means, but when I preload them they don't seem to have much pop in them. Real squishy like. I'm sure that makes zero sense...
I'm 215 lbs give or take a few depending on breakfast.
Falcon86 is offline   Reply With Quote
Old 07-06-2013, 03:58 PM   #19450
tdrrally
tdrrally's Avatar
Oddometer: 3,456
i'm about 280lbs at my best a b rider
and with an ego that is under control
adjustable suspension is a good thing to have but you DO NOT NEED IT!!
you can spend more time dialing in a suspension than riding .
get the bike and ride it !! don't let the lack of an adj screw stop you from riding a bike.
when you are getting 100% out of what you have then start looking for more
Old 07-06-2013, 03:59 PM   #19451
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,582
Richard, thanks, i will look around for a newer front end, next time you want to get out and ride these parts let me know.
Phil
ChromeSux is online now   Reply With Quote
Old 07-06-2013, 04:00 PM   #19452
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
Hope this will help...
Shock Spring
DRZ400 all
$109.95
Race Tech shock springs in a wide range of spring rates to dial in your rear suspension to suit your weight (stock spring is 5.5 kg/nm). Recommended spring rates:
Rider weight w/gear (lbs)
Spring Rate
100 or less
4.6
100-124
4.8
125-149
5.0
150-174
5.2
175-199
5.4
200-224
5.7
225-274
6.0
275 +
6.3
Front:
Fork Springs
DRZ400 all
$99.95
A pair of Race Tech fork springs to dial in your front suspension to suit your weight.
Fits all DRZ400 models with conventional forks (not for SM)
Rider weight w/gear lbs.
Spring Rate
90 or less
.42
90-119
.44 (stock)
120-150
.46
150-180
.48
180-220
.50
220-250
.52
250+
.54
More info if u decided to get different springs/shocks...
http://www.procycle.us/bikepages/drz400.html#suspension
Same thing here 180 + a heavy breakfast burrito make that 185 lbs
Old 07-06-2013, 04:01 PM   #19453
tdrrally
tdrrally's Avatar
Oddometer: 3,456
that's the spirit or just get what you have serviced
fresh oil in the forks and shocks does a wonder
Old 07-06-2013, 04:28 PM   #19454
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
I'll have to disagree with u here tdr, If there's anything to pay attention to, or to improve ur ride on a DRZ is tires and suspensions.
It also help keep the shiny side up in the rough stuff.
After reading the Clymer manual (suspension chapter), it took me 1 min. to adjust the whole front and rear. (just few clicks back & forth).
Old 07-06-2013, 05:39 PM   #19455
tdrrally
tdrrally's Avatar
Oddometer: 3,456
i agree suspension is the best place to spend your money
most folks will never notice
what i am saying buy the bike and ride first
i have seem more than one person spend 10k on bike to ride trails
then spend another 2k on the suspension before they even ride it, because some magazine or web page said too
that is bs !!
and oil change in the suspension every year will net the best gains
i still laugh every time i recall the customers that dropped all that cash on the bike then rode it once or twice if at all before selling it
hours of seat time on the bike is the best money spent is all i'm saying
Times are GMT -7.   It's 03:45 PM.
