Old 08-08-2013, 04:18 PM   #19921
toadl
toadl
toadl's Avatar
Oddometer: 880
Originally Posted by bobbed06 View Post
Any pics of these installed on your bike?
Creek I almost got a cross with these tires but I hit an underwater log. So although they are advertised as a mostly street tire they aren't bad off road. See the tire didn't get built up with mud.
Old and new set. Old set had 6000 miles, not the 8000 I reported but there was plenty of tread left for street riding, but I was heading on a big trip to the Northwoods.
M&M's don't know anything and have no meaning.
toadl is online now   Reply With Quote
Old 08-08-2013, 04:25 PM   #19922
toadl
toadl
toadl's Avatar
Oddometer: 880
Originally Posted by Jon B. View Post
I'm at 5500 miles on a D606 rear tire (on the KLR), with probably 1500 left on it. I'd estimate that 70 percent of those are gravel and dirt miles, the remainder on asphalt.
Good wear, good traction, decent price. I'd do it again - even though I have a TrackMaster 2 in reserve...
The DRZ wears Dunlop M51 non-DOT rubber right now.
Jon
Jon, refer to post 20572. I know you have a couple manuals.
Old 08-08-2013, 05:09 PM   #19923
George 99
George 99's Avatar
Oddometer: 778
Good stuff on the fairing 'n lights, Hasenwerk. Thanks.
Guys, got another ton o' parts today, 28L tank, Wolfman Enduro tank bag, LED license plate lites, and the flasher for my LED turn signals. So, pretty much everything is in hand axcept the Baja Designs turn signal switch.
And the seat. Spencer does fast turn around tho so now it's up to Fed EX (outbound) and UPS (home.) OMG!!! What a nightmare trying to shipping labels via internet. Neither company has a fully functional 'net presence. UPS guy at the shipping center said they have just as much trouble with their in-house system. Not a good feeling.
Oh, tires aren't here yet either. Still deciding how I'm gonna do the tubeless. Gotta go re-read all the stuff I've found about it.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 08-08-2013, 05:16 PM   #19924
bobbed06
Cavalera Conspirator
Oddometer: 1,236
I think I really would like these, Is the 4.60 x 18 the biggest rear I can get? I think I would prefer a 5.10
bobbed06 is offline   Reply With Quote
Old 08-08-2013, 06:17 PM   #19925
SteveROntario
Oddometer: 52
I know it may be a pain, but if someone could look up the free spring length for the fork spring on a 2005 DRZ400S, I'd really appreciate it. I have the repair manual for my 2001 but I upgraded the forks to the 2005 and I know the spring lengths are different.
I bought these on fleabay and wanted to see if I should get some shims before I take my forks apart.
http://www.ebay.com/itm/Eibach-Fork-...e7da9e&vxp=mtr
DR-Z400SK5 ('05-MODEL)
SUSPENSION Unit: mm (in)
ITEM STANDARD/SPECIFICATION LIMIT
Front fork stroke 288
(11.3) -
Front fork spring free length 573.2 561
(22.57) (22.1 )
Front fork oil level 129
(without spring) (5.07) -
Front fork oil type SUZUKI FORK OIL SS-05 - or an equivalent fork oli
Front fork oil capacity (each leg) 710 ml
(24.0/25.0 US/lmp oz) -
Front fork damping force adjuster Rebound 16th clicks turn back -
Compression 13th clicks turn back -
Rear shock absorber gas pressure 900 kPa
(9.0 kgf/cm2, 128 psi) -
Rear shock absorber spring 258.0
pre-set length (10.2) -
Rear shock absorber damping Rebound 13th clicks turn back -
force adjuster High speed 1 and 1/4 turns out -
Compression
Low speed 10th clicks turn back -
Rear wheel travel 295
(11.6) -
Swingarm pivot shaft runout - 0.3 (0.01 )
Service Limit: 561 mm (22.1 in)
If I could only figure out how to advertise a torrent... :)
Steve
2009 Suzuki DR-Z400SM (Zed version) with offroad wheels
SteveROntario is offline   Reply With Quote
Old 08-08-2013, 08:11 PM   #19926
toadl
toadl
toadl's Avatar
Oddometer: 880
5.10 I think would be too wide for the DRZ 2.15" wide rim. Bridgestone recommends the 120/80. They also have a 130/80. Here is a link.
http://www.bridgestone.com/products/...ing/index.html
Old 08-08-2013, 08:29 PM   #19927
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,291
5.10 inches is basically 130 mm. I run either a 130 D606 or a 140 Scorpion depending on what I'm up to. The 140 is 5.5"
PineyMountainRacing is online now   Reply With Quote
Old 08-08-2013, 08:30 PM   #19928
LSGiant
LSGiant's Avatar
Oddometer: 1,091
Those pics look kind of familiar, were you down between Henderson and Le Sueur ?
"Keep it rural, don't over water"
2010 Concours, 2000 DRZ400E
COG 7524, IBA 46513, GLMC 214
LSGiant is offline   Reply With Quote
Old 08-08-2013, 08:54 PM   #19929
toadl
toadl
toadl's Avatar
Oddometer: 880
No. Those pics were taken a few years ago. I have to admit, I really struggle with riding my bike where I shouldn't. This was public property. Not developed or really used so it's easy to justify riding there. On the other had I'm an AMA Member and believe in trying to be a good representative for the motorcycle community. In other words, you get no second guesses.
Old 08-08-2013, 08:56 PM   #19930
toadl
toadl
toadl's Avatar
Oddometer: 880
(11.3) -
(22.57) (22.1 )
Compression
(11.6) -
Steve
Thanks, I owe you $5.
Old 08-08-2013, 09:21 PM   #19931
bmwpowere36m3
bmwpowere36m3's Avatar
Oddometer: 90
Those spring lengths are incorrect, they only apply to 00-01 DRZ400S models. All other S,K,E models (not SM) have ~510 mm front springs.
bmwpowere36m3 is offline   Reply With Quote
Old 08-09-2013, 10:56 AM   #19932
STFU
Found
STFU's Avatar
Oddometer: 397
Oversized tank?
Figured Id check this thread before purchasing a new tank, I got no results from my WTB post in FM. Anyone have a decent used over sized tank in either yellow or clear/natural that they want to get rid of?
I think I have narrowed down my search to an IMS 4 gallon, but had a clarke before an really liked it so I could go either way.
Tiger 955i
450 EXC
450 XC-F
XR250R
TR200 FATCAT!
STFU is offline   Reply With Quote
Old 08-09-2013, 01:40 PM   #19933
hasenwerk
hasenwerk's Avatar
Oddometer: 1,310
Originally Posted by 955616846 View Post
Don't mean to be the misery guts, but... Take a couple of extra straps because I'd expect that to finish any trip that involved even gravel roads strapped to the rear rack. Folded 4-6mm 5052/5087 H32 aluminium plate would be a better option if you're trying to avoid pannier frames. Even then I'd still be a little concerned about the loads placed on that portion of the sub-frame. Vertical loads have a lateral component when the centre of mass is offset as is the case here which translates into a twisting motion at the sub-frame rail.
I agree. I don't like the engineering as there is no triangulation to prevent twisting. My 20mm square tubing nor my welds are going to break - even if I crash. Replacing the square tubing with a piece of folded plate will result in bending the mounting tabs or twisting of the frame the if attached to the same two tabs.
I think before I go on the trip I may add another piece that goes from the back half of the outer 20mm tube across to the other side of the frame to the exhaust bolt to form a triangle. That way if I crash the plastic fuel can holder will be the piece that gives and not the frame.
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
ONE TANK REMAINS! BMW F650 GS & Dakar / G650 GS & Sertao "Adventure Extender" 6L / 1.6gal Auxiliary Fuel Tanks
hasenwerk is offline   Reply With Quote
Old 08-09-2013, 04:08 PM   #19934
ohgood
ohgood's Avatar
Oddometer: 2,721
Originally Posted by DualSportDad View Post
Tires... I know, I know....
I have two sets of e model rims now.... My current set that are slightly bent and a nice straight set. I am planning on running knobbies on the current not so straight set and butting as close to a 100% street tire on the other set. I am about to start daily riding my KLX every day. I was going to sumo the bent rims but its way too expensive and I'd have to swap chains every time I swap.
I've searched about tires for the e model wheels and I don't come up with much and what I do come up with the tires are discontinued. Best I can find is a shinko 705 and a deathwing for the rear. Anyone else know of any cheap tires I can run that will get a ton of miles out of?
Sent from my Nexus 7 using Tapatalk 2
http://bamarides.com/ride/dual-sport...ead-dualsport/
For a ton of street miles... Bt45
For even better tire selection....
http://bamarides.com/ride/supermotar...-info-thread)/
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 08-09-2013, 04:22 PM   #19935
150ron
150ron's Avatar
Oddometer: 1,310
If anybody is interested, 2007 with only 2,500 miles.
http://advrider.com/forums/showthread.php?t=910530
Just some dude...
150ron is offline   Reply With Quote
Times are GMT -7.   It's 04:10 PM.
