Old 08-11-2013, 02:00 PM   #19966
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
Originally Posted by 150ron View Post
I learned the hard way yesterday that you CANNOT get the stock grip off the stock throttle tube...
So if anybody is picking up new grips to change out the stock waffle makers, pick up a new throttle tube too.
Did u use air compressor (hi-pressure) to blow air under the grips? They usually come right off. I changed them twice so far no problem. WD40 may help.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 08-11-2013, 02:27 PM   #19967
150ron
150ron's Avatar
Oddometer: 1,459
Not this, this thing is like fused to the throttle tube, even with a brand new stanley razor it barely comes off...
Just ended up getting a new motion pro throttle tube for $9 bucks, got the pillow tops installed, they feel great.
Just some dude...
150ron is offline   Reply With Quote
Old 08-11-2013, 04:47 PM   #19968
kioti
Cruzinonline
Oddometer: 193
Can't be done with the stock '05 and up S/SM 400 throttle tube with oem grip.
Grips molded to the tube.
kioti screwed with this post 08-11-2013 at 04:55 PM
kioti is offline   Reply With Quote
Old 08-12-2013, 01:41 AM   #19969
Brick Top
Brick Top's Avatar
Oddometer: 90
Over tightening the primary nut?
Good day Drz fans,
I have managed to over tighten the primary nut, the torque should have been 137 nm (101.5 ft-lbs) but it was close to 200 nm (147.ft-lbs). I have realized the torque wrench was not working and I loosen the nut, cleaned the threads and applied the loctite 638.
By over tightening the did I do some damage, I have not ran the engine?
B. Top
Brick Top is offline   Reply With Quote
Old 08-12-2013, 02:02 AM   #19970
Chef Gareth
Live 2 Ride
Chef Gareth's Avatar
Oddometer: 240
Originally Posted by OR Trail View Post
Since your XR has some power mods, and plenty of get up and go, I'm not sure how much improvement you would find the DRZ to be as an upgrade. The XR weighs less. A DRZ can be built up to be more powerful, and I have an "S" instead of an "E" and your bike has nice mods - probably faster than a stock DRZ400S. I suspect you will hear a lot of the positives of the DRZ in this thread; I like that the XR400 is lighter and has a more open cockpit. I find that leads to a better handling bike for a tall guy, and less fatigue. I wouldn't say that one is better than the other, but instead of an upgrade I would consider one vs the other to be a different set of trade offs.
Thanks for the feed back so far guys, I am mainly looking to upgrade to a bike that can handle more adv style of riding while still able to hit the trails with my mates. The xr is great on the trail but needs some money spent if I want to take it on longer adv rides. I have dropped lots of money into old bikes in the past and regrated it so am cautious to spend any more then I already have to set up a 11 yr old bike. The button start on the drz is another factor, when I come off or stall the xr its a bitch to start and I waste a lot of energy getting it going again and then have to play catch up.
My main concerns is that it wont have as much power as my "set up xr" (I can power wheelie in every gear including 5th) and wont excite me, but love the fact they are bullet proof and I suppose that's more important in a adv bike.
Chef
DL650 2012 (Travel)
DRZ400 2008 (ADV)
JR50 2006 (Daughters)
Chef Gareth is offline   Reply With Quote
Old 08-12-2013, 06:53 AM   #19971
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
I came from bigger thumpers to the DR-Z..
The magic button was one of the BIGGEST selling points... next to reliability, parts availability and ease of use...
Yes, there are better, lighter, faster and more powerful bikes out there... but a lot of that also happens between your ears.
I have my "Z" nicely (for me) sorted out and can do all sorts of riding with her... I ride with better riders on better bikes, but they rarely have to wait for me longer than a minute and on the surface roads, I usually have to wait for them.
I am on my 2nd "Z", the first one was a 2000, this one is a 2006... better motor and everything is just newer... just about to scratch 2000 miles. Looking forward to 10 fold that... and years of fun to come.
I have no intention to look in another direction... with the DR-Z (and the modest mods I made) I have found a bike that makes me happy.
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 08-12-2013, 08:17 AM   #19972
monkeyspanker
monkeyspanker's Avatar
Oddometer: 6
Carb clean/rebuild - guidance needed
Good morning, Gents -
I am looking for some guidance on a carb clean/rebuild.
2002 DRZ 400S - 7,300mi. 3x3 mod and JD Jet kit.
Bike sat for over a month without stabilizer. I replaced the spark plug, added Liquid Performance stabilizer and 2 gal of fresh gas. It will start cold for a few minutes, but won't idle. After a few minutes after starting with constant throttle, it dies and won't restart. I removed float bowl and cleaned jets with carb cleaner. This didn't change anything.
The air filter is pretty old and dirty, so I plan to replace immediately.
I'm not totally sure what to do next. I was thinking about buying all new jets and cleaning everything in the carb.
Question: Is this overkill or am I heading down the right path?
I would really like to take care of this on my own, as the local shop recommends that I pay them $500+ to replace all of the guts in the carb.
Also posted in Thumper Talk
monkeyspanker is offline   Reply With Quote
Old 08-12-2013, 10:03 AM   #19973
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
Take out the jets, inspect and clean them... flush out the channels/pathways in the carb and make sure your diaphragm is OK...
If she runs better with the choke pulled, it's usually the pilot jet... also, make sure you actually has the correct jet-size (just for shits and giggles) i.e. (aproxx.) 25 pilot and around 155 main...
Sometimes crap just gets stuck in there and if the bike stands long enough and has a chance to dry out, it can REALLY get stuck... so that you actually have to manually remove whatever crap is in the jets.
If that doesn't work, you can still throw the bike away... just let me know where and when.
Ralf Wilkowski
www.itwasnotme.com
Old 08-12-2013, 10:59 AM   #19974
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,054
The air filter must be replaced asap, it's between $15 to $25 on ebay.
The whole rebuild kid is $42...(and free shipping ).
Moose Carb Carburetor Repair Kit Suzuki DRZ400S 2000 - 2009 Motocross Enduro
$500 What are these guys smoking??.
For $500 i'll fix ur carb and be your DRZ's Chauffeur for 1 entire week .
Old 08-12-2013, 11:59 AM   #19975
LC8rider
LC8rider's Avatar
Oddometer: 659
Talking 400E frame colour?
I've just stripped down my new-to-me 400E. I hadn't planned on a full strip down when I bought it, but after getting to it, I've found quite a few bearings need changing (all suspension linkage, swing arm, front and rear wheels plus fork seals etc). I don't mind because I knocked down the seller by a huge chunk of cash and it would give me piece of mind any way.
Question is, what colour should I powder coat the frame? I'm not doing the bike up as per showroom, just mechanically A1, but I'd like it to look cool/different. Plastics are yellow and in good condition, so I'll be keeping these. So what colour would you do?
KTM 950ADV & Suzuki DRZ 400E
LC8rider is offline   Reply With Quote
Old 08-12-2013, 02:12 PM   #19976
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,945
pink?
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 08-12-2013, 03:02 PM   #19977
WayneJ
City Slicker
WayneJ's Avatar
Oddometer: 6,207
Question: Is this overkill...
...the local shop recommends that I pay them $500+ to replace all of the guts in the carb.
You usually have to remove the jets to clean them and the carb properly.
You don't need to buy new jets.
If you want to bring the carb down to the shop, I'll take it apart, clean it(I have an ultra-sonic cleaner if needed) and it will cost you a 12 pack.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 08-12-2013, 03:44 PM   #19978
Dirty Tread
Roadapple Flinger
Dirty Tread's Avatar
Oddometer: 24
Clean it all
Hi. I did your routine first and too still experienced issues...
My solution was to buy carb cleaner ($16) and soak the carb and all jets entirely for 24 hours... Then i air blew everything clean & dry.
Delicately put things back together along with a cheap but worth it: in-line fuel filter! Best $1 spent in a long while!!
Dirty Tread
DRZ400s
Dirty Tread is offline   Reply With Quote
Old 08-12-2013, 04:19 PM   #19979
WayneJ
City Slicker
WayneJ's Avatar
Oddometer: 6,207
You have no idea what my routine is.
You still had issues because you obviously didn't do it correctly the first time.
I do this shyt for a living n00b.
20% Smug Mug Credit
Old 08-12-2013, 04:31 PM   #19980
Dirty Tread
Roadapple Flinger
Oddometer: 24
Cry
Woah. And this is a good example of the beauty of attempted "normal" conversation via email, text or mere chucking dialogue over a wall.
I apologize, I quoted the wrong soul on this Green Earth.
I still stand by my routine if those interest want to apply to their situation at hand.
Lastly, I am sure your routine is the highest of routines and don't doubt it the least bit. May it be clear: I only wanted to emphasize the level of cleaning depth I had to take for cleansing success.
I now must revert to my noob state... And dust my bike off.
Dirty Tread
DRZ400s
Times are GMT -7.   It's 11:36 PM.
