Old 08-24-2013, 06:58 PM   #20056
caljw
caljw's Avatar
Oddometer: 393
Shift lever removal
Been fighting with my shift lever...damn if it won't come off the spline. Any tricks?
cal
"If you follow every dream you might get lost." Neil Young
2011 BMW 1200 GSA
2014 KTM 500 EXC
caljw is online now   Reply With Quote
Old 08-24-2013, 07:10 PM   #20057
STFU
Found
STFU's Avatar
Oddometer: 397
Did you take the bolt all the way out, not just loose? try spreading it where it clamps on the splines by putting a prybar or screwdriver in the split of the lever.
Tiger 955i
450 EXC
450 XC-F
XR250R
TR200 FATCAT!
STFU is offline   Reply With Quote
Old 08-24-2013, 07:23 PM   #20058
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,002
Originally Posted by woodly1069 View Post
Hey fellas I am wondering if you might be able to enlighten me about the new noises coming from the old 400E. Seems that maybe the chain is stretching or the guides are wearing cause I can readjust the manual cam chain tensioner and the noise will go away for a while but then it comes back after a 100 miles or so. At least until today anyway, now maybe every 50 miles. I am adjusting it correctly and the slapping noise will go away but then it comes back.
I guess I am wondering if this is a normal wearing of these items? If so, should I expect to replace the chain and guides only? Will the sprockets have wear too?
Thanks for any advice!
I had the same issue in March so I decided first to replace my old acct to the new acct one (past 2003) before I go ahead and replace the timing chain. I got one from ebay in great condition (06). The noise from the chain is gone, until now no issue so far.
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 08-24-2013, 07:29 PM   #20059
caljw
caljw's Avatar
Oddometer: 393
Yup thats what it took spreading and working from behind with driver. Thanks. Hope the new one goes on easier.
cal
2011 BMW 1200 GSA
2014 KTM 500 EXC
Old 08-24-2013, 07:38 PM   #20060
BEEF706
King of the dumb dab
BEEF706's Avatar
Oddometer: 723
Originally Posted by signit98 View Post
...it is likely that your pilot jet is clogged or obstructed. clean it out and try again... symptoms fit perfectly.
chalk it off under "shit happens"
Thanks, I'll try that tomorrow
NMOHVA Member NMTA Member
07 CRF450x, 04 Beta Rev3 270, I like red bikes
A good friend will take you trail riding, an ADV friend will double back and say, "how did you get down there?"
BEEF706 is offline   Reply With Quote
Old 08-24-2013, 07:50 PM   #20061
ohgood
ohgood's Avatar
Oddometer: 2,877
how much is left to adjust on the screw ?
the last 1/4" on mine went really fast, like you're describing.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is online now   Reply With Quote
Old 08-24-2013, 10:21 PM   #20062
George 99
George 99's Avatar
Oddometer: 778
Evening folks. Got all my stuff minus the new rear sprocket and chain. Checked the fit of the tank today, wondering how I'm gonna refit the radiator guards but I'll get it done.
First real job is to get the turn signals all wired up. Hitachi connectors and color coated wire.
The tires will wait another thousand miles.
Wondering how I'm gonna "stuff" all that HID wire. Probably need to shorten them.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 08-25-2013, 03:24 AM   #20063
tdrrally
tdrrally's Avatar
Oddometer: 3,378
spencer's ld magic ?
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k1 i miss that bike
tdrrally is offline   Reply With Quote
Old 08-25-2013, 05:26 AM   #20064
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,951
what do you mean by acct? auto cam chain tensioner?
I am using the manual version and have been adjusting it myself...
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 08-25-2013, 05:32 AM   #20065
woodly1069
woodly1069's Avatar
Oddometer: 1,951
strange...and I believe you experienced what I am now. There was about 1/4" between the "staked" nut on the end of the threaded assembly and the locknut for the two years I have had it on the bike and now there is only about half that. And that was distance was adjusted out in the last 200 miles!
What did you wind up buying to fix yours? Chain and guides? Guess that's what I need to do...
Old 08-25-2013, 06:56 AM   #20066
George 99
George 99's Avatar
Oddometer: 778
7777777777777777777777777777777
TD, mentioned it in an earlier post: Spencer's Seat Mod, he adds a hollow cell foam under the seat foam which extends the range. Along with the wider seat concepts pad and cover, should make this a real LD seat. I have his seat mod on both my ST1100 seats.
"What is Supracor: Supracor is the new material that has replaced Flex Gel and is added to your seat in the "LD" (longer distance)
upgraded modification. It is a "honeycomb" of thermoplastic urethane material that was developed for aerospace and medical
applications where a form fitting, supportive,flexible, breathable, and shock reducing surface is needed."
Lots of LD riders swear by his work. He'll work on about any seat except a Corbin.
George
Old 08-25-2013, 08:36 AM   #20067
hasenwerk
hasenwerk's Avatar
Oddometer: 1,323
Look where I went yesterday
OK... now I am impressed the DRZ can go some pretty cool places - more so than what I would dare to take my BMW 650GS! Yesterday and friend with his Yamaha 230 and I rode to Fraser River outside of Quesnel and took the scenic route. For the record the Heidenau K60 tire on the front has NO lateral grip in the mud and the Mitis E-07 on the back didn't fare much better. In my opinion, the DR needs all the help it can get from the front end. On the vast area of rounded river stones, everything was fine, these are way more "fun" to ride on than European cobblestone! Did all of this on a 41-15 sprocket combo with no problems at all. I think this is the perfect gearing combo for the DRZ - 120km/h all day on the highway and the ability to start on mega steep tracks.
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline   Reply With Quote
Old 08-25-2013, 11:56 AM   #20068
150ron
150ron's Avatar
Oddometer: 1,404
Just did 117 miles, all at 75+ mph, had it up to 98 at one point, could've done more too, love it, bike runs great.
Just some dude...
150ron is offline   Reply With Quote
Old 08-25-2013, 01:20 PM   #20069
SquadraCorse
SquadraCorse's Avatar
Oddometer: 133
Let there be light.
And did the KTM fork guard mod:
2013 RallyMoto Overall/Dakar Champ
http://styleperpound.blogspot.com/
BMW R1100S Light | KLX 400
SquadraCorse is offline   Reply With Quote
Old 08-25-2013, 03:09 PM   #20070
Psycho18th
Oddometer: 430
Originally Posted by slower_than_you View Post
So, anyone had any luck in converting a DRZ-E into a street legal version ? Is it as easy as Im thinking , minus the DMV headaches ? I really like my E and I think if I could ride it legally on he road ,Id like it even more -
Been running my E for a couple years now on the Tusk dual sport kit from Rocky Mountain. I use the integrated front turn signals in their aluminum hand guards. I ended up buying a cheapo acerbis headlight, but I don't go far at night.
It will take some abuse.
Then a quick wash and you can commute to work the next day.
Psycho
02 DRZ400E Dualsported in AZ
14 KTM 250 XCW (Plated in AZ)
85 HON XL80S (Wife's ride)
00 and '07 YAM TTR 90s (kids' bikes)
89 Lockheed F-16C (Work vehicle )
Psycho18th is offline   Reply With Quote
Times are GMT -7.   It's 11:41 AM.
