Old 08-27-2013, 07:39 AM   #20101
DJFireUSA
2Fast4U
DJFireUSA's Avatar
Oddometer: 339
Originally Posted by rustycager View Post
Try rocking if it is still tough then something isn't right or bent shift parts. Hard to get stopped gears to mesh.
Isn't the rs4 the dual exhaust? Did you mean rs3?
AH CRAPO- yeah... rs3 duh
here's a vid of what I have...
http://youtu.be/czC9m4LbBBc
Alcan Survior 2009 - 3 months and 20,000+ smiles
2007 GL1800 Goldwing, 2009 Harley Police Road King, 2007 DRZ400sm, 1985 Honda CB650sc (Special Edition), 2006 S-50 (aka VS800 intruder - for sale)
Top Gun Expert Level Champion and occasional hooligan
Youtube.com - search for DJFireUSA
DJFireUSA is offline   Reply With Quote
Old 08-27-2013, 07:54 AM   #20102
WayneJ
City Slicker
WayneJ's Avatar
Oddometer: 6,207
Originally Posted by DJFireUSA View Post
Without the bike running, lever pulled in she doesn't want to shift into 1st from 2nd and from 2nd to first. Hard to get it into neutral as well.
Modern motorcycle transmissions are constant mesh transmissions, they are designed to be shifted when the gears are turning.
Try doing it with the bike running.
Get an owners manual, it will tell you how to adjust the clutch.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 08-27-2013, 08:20 AM   #20103
slower_than_you
Slacker
slower_than_you's Avatar
Oddometer: 51
Looks like a good set up - anyone used this set ? Im looking very closely at the Baja Designs kit , but , if this one works just as well, I think I might have a winner.
In speaking with my insurance agent and the inspector , I should be good to go wiht a few changes - insert evil laugh of your choice -
Originally Posted by DR650SEDDY View Post
Some state are flexible than others when it come to converting ur bike, in the worse case scenario u might have to do it right.
Street Legal Kit Suzuki RMX450 450 DRZ400 DRZ 400 RMX
slower_than_you is offline   Reply With Quote
Old 08-27-2013, 09:23 AM   #20104
DJFireUSA
2Fast4U
DJFireUSA's Avatar
Oddometer: 339
book smart and street smart are two very different things... there are tweaks to the bike that the book just isn't going to cover. I already stated the clutch is adjusted PER SUZUKI. So adjusting it per the OM isn't going to change anything.
I appreciate the "education" on transmission working but that's not what I was asking about. The other bikes shift just fine, even while stopped and motor off.
There are times when riding the shift from 1st to 2nd and 2nd to first just does not happen which, I believe, is related to clutch cable adjustment mixed with after-market lever adjustment. Remember I am running ASV levers and I suspect the adjustment on them is such that the lever can not travel enough, thus the cable is not being pulled enough.
Look, all I am trying to figure out is how much tighter I can adjust the cable AFTER all the slop is out of it or if this is just a bad idea and I need to hone in on grip to lever gap and adjustment of the levers.
While it is possible the lever is not traveling far enough due to it's adjustment, even before they were added, the tech adjusting the cable back to suzuki specs threw it out of whack.
Old 08-27-2013, 09:25 AM   #20105
George 99
George 99's Avatar
Oddometer: 787
I've piece parted mine using parts from various vendors. The only Baja Designs product is the head light/turn signal switch on the handle bar. Too expensive, found another that looks identical but no high beam indicator for $20 less. Too late for me but maybe you can use it. There's another Tusk model on E-Bay for $9.
I added a dual beam headlight, cheap LED turn signals with a solid state relay, and a #60 ADV LED light. My bike had already been plated in AZ by the PO, mirror, horn and brake light switch were already on the bike. It's easy to plate a dirt bike in Arizona, almost impossible in California. Everyone else lands somewhere in between.
If I had seen that kit on E-Bay I probably would have bought it. With the wiring harness already built, it's worth it. I've probably spent about that much and have to make my own harness.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 08-27-2013, 10:17 AM   #20106
tdrrally
tdrrally's Avatar
Oddometer: 3,456
the tusk kit is money well spent !
1996 Dr350se 1997 DR350se
2002 Drz250k2 i miss that bike 2007 sv650 naked scrambler
tdrrally is offline   Reply With Quote
Old 08-27-2013, 10:29 AM   #20107
FamilyRider
FamilyRider's Avatar
Oddometer: 321
I didn't use this kit on my DRZ, but I did use it on my CRF. It is a pretty decent kit. The only thing I didn't like was the on/off switch. I modified mine to use a key switch that acts as a kill when off and when on, it enables the lighting and the starter motor. I had to cut some wires in the kit harness and the bikes harness, but it works.
2014 KTM 350 XCF-W
FamilyRider is offline   Reply With Quote
Old 08-27-2013, 02:37 PM   #20108
George 99
George 99's Avatar
Oddometer: 787
Agree the Tusk kit looks good, tho I'm using 16 ga wire instead of the 18 ga that kits probably contains. Jus' sayin' as I've not seen it in person. Also, I don't like the included rear fender. Don't need it anyway so I'm happy the way I'm doing it.
Working on wiring yesterday, made a quick bracket to hang the rear mini-turn signals. Ran into this when tightening the nut on this one.
(shoot, can't the photo to load. :( )
Anyway, 6mm threaded rod with thru hole for the wires,,, rod broke off when I tried to tighten the nut.
Vendor is already on it to get me a replacement but I also ordered a "do all" tail light, all LEDS with stop, brake, and turn signal built in. Only $20 and no turn signals hanging in the wind.
George
George 99 screwed with this post 08-27-2013 at 02:52 PM
Old 08-27-2013, 02:51 PM   #20109
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
Couple of things:
1.Don't such an ass when people give you info to help you out, especially when you have 67 posts and are asking such an elementary question such as how to adjust clutch levers. Book smart and street smart? what the hell does that even mean in this context? The manual explains clutch adjustment, end of story. It doesn't matter what levers you have the mechanism is very basic and it's still the same.
2. Just because you paid some tech to change and adjust your levers, or whatever you had him do, doesn't mean it was done to SUZUKI SPEC. as you call it Jesus man, he gets paid flat rate to turn wrenches, he can make a mistake.
3. There has to be some free play in the clutch lever. If you tighten the cable all the way in you risk the chance of burning out your clutch plates. There should be at least an 1/8th inch gap of loose cable before it starts to take up pressure.
4. If you have shorty levers I would check to make sure you are getting full pull to the bar with lever. Make sure it isn't bottoming out on the control housing or something else.
5. Also check the shift lever, make sure it isn't hitting the engine cover and fouling up your shifts. It would also be a good idea to check and make sure the shift lever is tight as well.
You tube has a few clutch lever adjustment videos that you might find useful as well.
Good luck.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 08-27-2013, 02:55 PM   #20110
George 99
George 99's Avatar
Oddometer: 787
What internal said.
If you have to ask how to adjust a clutch cable, you don't have a lot of cred to be dissing those who try to help.
George
Old 08-27-2013, 03:14 PM   #20111
211john
Oddometer: 226
08 sm... looking for kick start kit... ideas?
Busted my arse pushing the bike up a hill with the intent on bump starting it down said hill. Foot slipped and bike fell on top of me. Nuff of that *#-&!
will post again shortly.
nice led action... just picked up same lights you have on top
http://www.ebay.com/itm/Suzuki-DRZ40...3da406&vxp=mtr
cheaper on ebay than anywhere else I could find. I love mine. Especially on cold days.
211john is online now   Reply With Quote
Old 08-27-2013, 06:35 PM   #20112
jackpiner57
Moto-Racks.com
jackpiner57's Avatar
Oddometer: 1,687
Originally Posted by eakins View Post
Spencer takes stock foam and reshapes/adds/subtracts.
Plus he has an optional (LD - long distance) Supracore top layer he can use.
He then puts your cover back on.
Not sure why George added Supracore when a new Seat Concepts foam was used? http://greatdaytoride.com/Home_Page.php
Thanks Eakins, looks like a fantastic material! I'll be looking into it for sure. -Tom
Tom - '07 DR-Z400S, '05 DL650
Dual Sport Luggage Racks: DRZ400, DR650, KLR650, WR250R:
http://www.moto-racks.com
"I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott
jackpiner57 is offline   Reply With Quote
Old 08-27-2013, 07:12 PM   #20113
George 99
George 99's Avatar
Oddometer: 787
Frank carves out a pocket on the bottom of the seat foam and adds the Supracore into the pocket.
George
Old 08-27-2013, 07:50 PM   #20114
STFU
Found
STFU's Avatar
Oddometer: 412
Everyone likes pics, so here are a few from my recent build of a 2004 400E that I picked up cheap with a parts bike. Its almost done now. Still need some hand guards and engine protection:
Phase 1 complete:
Phase 2, lets get some better lights
New Brakes, wiring harness and other street legal crap added
Now extend the range a little
And Finally, the most important part:
Tiger 955i
450 EXC
STFU is offline   Reply With Quote
Old 08-27-2013, 08:59 PM   #20115
150ron
150ron's Avatar
Oddometer: 1,459
Very nice ^^^^, liking that headlight and front fender, bike looks so much better then what you started with, good job, M8.
Just some dude...
150ron is offline   Reply With Quote
Times are GMT -7.   It's 11:24 PM.
