Old 08-27-2013, 10:24 PM   #20116
Creeker747
Creeker747's Avatar
Oddometer: 274
Originally Posted by 150ron View Post
Very nice ^^^^, liking that headlight and front fender, bike looks so much better then what you started with, good job, M8.
What 150ron said! How's your clutch adjusted? Whoops, sorry couldn't resist........
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!"
Creeker747 is offline   Reply With Quote
Old 08-27-2013, 11:58 PM   #20117
markjenn
Oddometer: 10,425
Originally Posted by PhiSig1071 View Post
Does anybody have a trick for getting the OEM crush washers off?
A utility knife works for me. Something very thin to break the bond between the washer and the flange of the bolt. Once this bond is broken, they come off pretty easy, sometimes just slipping off, sometimes requiring unthreading.
- Mark
Old 08-28-2013, 07:51 AM   #20118
Singletracksam
Oddometer: 7
My DRZ...
Gets me where I need to go.
Singletracksam is offline   Reply With Quote
Old 08-28-2013, 11:48 AM   #20119
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
- Mark
I usually use a pair of plain pliers. Straight grabbing the crush washer with the threaded part inside the jaws. Then simply unscrew the washer.
THRASHED is offline   Reply With Quote
Old 08-28-2013, 12:09 PM   #20120
Tropic-Of-Canada
Thread Derailleur
Tropic-Of-Canada's Avatar
Oddometer: 855
I like to use vice grips for this, much better bite.
Tropic-Of-Canada is offline   Reply With Quote
Old 08-28-2013, 12:54 PM   #20121
Tropic-Of-Canada
Thread Derailleur
Oddometer: 855
So I just picked up a Dynojet Stage 1 kit. I'm wondering how to pick what jet to use.... My machine appears to be running lean, I'm pretty sure it has stock jetting..
so from what I understand, you go to a smaller main jet for this..I have a 128,130,132,134,136 to choose from.
The bike mostly lives at sea level, I run a K&N filter, and a yosh Tailpipe of some description...No model given, It has some japanese on it, and says offroad.
I'm not too sure about wanting to do the 3x3 mod,thinking of dust/ water issues.
What is a good starting point for a machine running lean?
Old 08-28-2013, 01:31 PM   #20122
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,746
Not to be ignored! WELCOME and nice first post.............
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 08-28-2013, 03:02 PM   #20123
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Well hears a thing I may have mentioned before
I just put two washers under the needle to raise it a bit and all is fine, I know cos it runs great and I just change a plug and the colour is good on the old one
Other than that the engine is stock.
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 08-28-2013, 03:43 PM   #20124
George 99
George 99's Avatar
Oddometer: 778
If it's lean, go bigger, not smaller. If you gotta ask this question, get some more experienced help, ya don't wanna burn a valve or piston. Read all the responses, raising the needle a tad sound like good advice.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 08-28-2013, 03:46 PM   #20125
George 99
George 99's Avatar
Oddometer: 778
I'm starting to think I should do as you, Sam. I've only got 30 miles on my 03, started modifications before I gave her a real test. She's been down about three weeks as I've gathered parts and started mods. Prolly would'a been better off if I'd just follow my own advice...
GO RIDE!!!!
George
Old 08-28-2013, 05:08 PM   #20126
Tropic-Of-Canada
Thread Derailleur
Oddometer: 855
Ya, the plug is pretty white right now, i hear golden brown is ideal?
Old 08-28-2013, 05:44 PM   #20127
STFU
Found
STFU's Avatar
Oddometer: 397
Got out today to try out my new license plate:
Tiger 955i
450 EXC
450 XC-F
XR250R
TR200 FATCAT!
STFU is offline   Reply With Quote
Old 08-28-2013, 07:59 PM   #20128
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
Nice spot STFU!
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 08-28-2013, 08:49 PM   #20129
Bad Daddy
Oddometer: 103
2008, DRZ400S
3x3
Stock pipe, No Toil
JD jetting kit...
155 Main Jet
22.5 Pilot (stock) Kientech 2.5 turns out from gently seated
Blue Needle
3rd from the top
Recommended jetting from JD:
155 main jet
22.5 pilot jet with the extended screw, or 25 pilot jet with the stock fuel screw
blue needle
clip 4
I might try the needle on a different clip, but it is pretty good right now, 0-4000' feet is where I use it.
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 08-28-2013, 09:04 PM   #20130
Tropic-Of-Canada
Thread Derailleur
Oddometer: 855
Ok thanks, but I didn't get the James Dean kit, I got the Dynojet...I guess I'll see what size the stock main jet is, it better be smaller than 136!!
So if I want to go more rich, I move the clip closer to the pointed end??
Times are GMT -7.   It's 07:41 PM.
