Old 08-30-2013, 08:19 PM   #20146
Brods1675
Giant
Location: Tasmania. Amazing roads. Adventure bike heaven.
Oddometer: 130
that's disconnected. Thanks anyway.
2010 R1200GSA
2014 WR450FE
https://www.airbnb.com.au/rooms/4158796
Brods1675 is offline   Reply With Quote
Old 08-30-2013, 09:05 PM   #20147
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
Vapor locked gas tank...?
Garthe is offline   Reply With Quote
Old 08-30-2013, 09:11 PM   #20148
Brods1675
Giant
Oddometer: 130
Wink
now there's a thought...
2010 R1200GSA
2014 WR450FE
Old 08-31-2013, 01:51 AM   #20149
Goofy Footer
Oddometer: 569
Stator? Mine went whacky before it finally blew (E model DRZ).
Goofy Footer is offline   Reply With Quote
Old 08-31-2013, 02:49 AM   #20150
Adrian V
Oddometer: 515
Ailing bike carby related?
I've got an Oz 400e with the FCR carbie, that started to drip from the overflow tube, part way into a desert trip. The bike ran fine for a few days and only seemed to drip at tick over, so I left it, but the drip became a trickle and the bike became progressively harder to start and lost tick over. Once underway it still seemed to run fine and was returning 17-18 km per litre (51 mpg imperial), through sandy desert terrain.
Once out of the scrub the bike finally quit outside a pub.... (wouldn't start once cold). I took the float bowl off and looked at the float, float needle/seat and everything looked fine. The float bowl was also clean. Put it back together and changed the plug, but still no go. On the verge of giving up I gave it one more kick (fuel off, throttle open) and the bike started . Didn't start the next day though...... back firing through the carbie etc.
So, I'm thinking overflow = leaking float needle/seat = flooding at low revs and possibly a fouled plug, but.... why did the bike run ok once underway, and run fine for 4-5 days before it quit? Is there anything else in the FCR I should be looking for, that would give these symptoms? Would I even be able to see a buggered needle/seat?
Could the overflow be a red herring and the stator be playing up?
Once last thing, the bike was running on OPAL, a low aromatic low octane petrol used to combat sniffing in the indigenous communities, could this have buggered an O-ring somewhere?
Any ideas would be appreciated, my plan of action unless something obvious comes up is to rebuilt the carbie and check the valve clearances (but the bike only has 5500km), but I'd rather find out what went wrong so I can fix it out bush if it happens again..
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 08-31-2013, 04:31 AM   #20151
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 626
I would suspect the tank vent is not venting especially if it's one with a check valve.
Cheers,
Adrian
Adrian, I'm hearing two things that could make starting difficult. FCR carbs are foreign to me however I think if the float valve/o-ring assembly is leaking then your engine would have flooded, you would find a very wet spark plug which would be useless until dry. Fuel would also seep past the piston rings into the crankcase diluting the oil.
OPAL fuel is also foreign to me. Sniffing? I am curious and shall look it up. Perhaps this low octane fuel doesn't have the volatility to fire well in a high compression engine.
coarsegoldkid is offline   Reply With Quote
Old 08-31-2013, 12:43 PM   #20152
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 375
Originally Posted by EOD3MC View Post
Moved the bags I usually use on the KTM's crashbars over to the DRZ.
Looks like the straps will provide a solid mount...guess we'll find out tomorrow when we head out for a couple hundred miles of fun
Other side holds tool kit, air pump and a few other items...
(bags are 6x10 tactical gear bags from 5.11)
Interesting idea. I'm sure if you are fully loaded the bike handles differently, but with just those up front do you notice much change?
THRASHED is offline   Reply With Quote
Old 08-31-2013, 02:36 PM   #20153
Brods1675
Giant
Oddometer: 130
Cheers,
Adrian
Mine had this as one of the early problems. Float got stuck and fuel poured out of it. My bike probably has similar mileage to yours.
2010 R1200GSA
2014 WR450FE
Old 08-31-2013, 02:41 PM   #20154
Crabenho
NOOBish
Crabenho's Avatar
Oddometer: 608
Subframe and Wolfman Racks Needed
Hey Guys,
I have a set of Wolfman Expedition bags that I want to put on my 2003 KLX R. I guess I need to replace my subframe with a S or SM model. If anybody has one, I'd be interested. I also need the Wolfman DRZ side racks.
Thanks,
Chris
My buzz ain't a sammich.
Crabenho is offline   Reply With Quote
Old 09-01-2013, 03:32 AM   #20155
Adrian V
Oddometer: 515
Thanks for the input...
Thanks for the input. I think I'll try and replace the O-ring first, is it worthwhile getting a Viton one (size?)?
I'll also check the valve clearances, just in case....
If that fails I'll replace the needle/seat; hopefully one or other of these will sort it out.
Cheers,
Adrian
Old 09-01-2013, 06:22 AM   #20156
coarsegoldkid
Oddometer: 626
I looked up OPAL fuel. I would have never in a thousand years guess that anyone would want to inhale gasoline fumes to get mental relief from daily boredom. Damn don't they grow marijuana there?
'05 BMW R1200RT
'13 KTM 690 Enduro R
Ride tales
Utah / Colorado http://tinyurl.com/lcy2yhu
Mexico http://tinyurl.com/lhgznun
Old 09-01-2013, 07:30 AM   #20157
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,868
Did about 350 miles with them yesterday...didn't notice them at all until I had to fix a flat...Then I really appreciated the expanded tool kit I was carrying
EOD3MC is offline   Reply With Quote
Old 09-01-2013, 08:13 AM   #20158
See-Three
C3
See-Three's Avatar
Oddometer: 144
Speaking of flat tires, popped both of mine this last Friday.
See-Three is offline   Reply With Quote
Old 09-01-2013, 08:27 AM   #20159
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 375
Yep, I've got a couple of items that I hope I never need. But just in case..
Old 09-01-2013, 01:53 PM   #20160
George 99
George 99's Avatar
Oddometer: 786
Kid, ya got it backwards, low octane fires more easily than high octane, hence the problem with knocking under high pressure. I'll go with stuck float valve 'til a more precise diagnosis is come upon.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Times are GMT -7.   It's 10:27 AM.
