Old 09-01-2013, 02:02 PM   #20161
George 99
George 99's Avatar
Oddometer: 778
Originally Posted by THRASHED View Post
Yep, I've got a couple of items that I hope I never need. But just in case..
Such events are what are leading me toward tubeless on my DRZ. Much easier to plug a tire than change a tube.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 09-01-2013, 02:16 PM   #20162
George 99
George 99's Avatar
Oddometer: 778
Thought it might be a good idea to post this here, more concentrated market.
Make me an offer.
George
Old 09-01-2013, 03:49 PM   #20163
George 99
George 99's Avatar
Oddometer: 778
Update on my farkling. Sent the UFO headlight back and bought Sanjoh's fairing and an M60 to go with the M44 I already have. Updates coming (don't even have it in hand yet. )
George
Old 09-01-2013, 07:07 PM   #20164
LSGiant
LSGiant's Avatar
Oddometer: 1,104
[QUOTE=See-Three;22229758]Speaking of flat tires, popped both of mine this last Friday.
How much air pressure were you running ?
"Keep it rural, don't over water"
2010 Concours, 2000 DRZ400E
COG 7524, IBA 46513, GLMC 214
LSGiant is offline   Reply With Quote
Old 09-01-2013, 07:37 PM   #20165
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,521
2001 question
My 01S has a slight bog or stall of sorts, it happens at about 1/16 maybe 1/8 throttle, the carb has stock jetting and intake/exhaust, carb has been taken apart and put in sonic bath, then put in Pine sol.
A/F screw is set at 3 turns out, there is no snorkle in the air box.
I am thinking that due to its age, i may need to replace the rubber diaphragm, i had a fellow DRZ owner tell me that solved the same issue on his, what say ye.
My 03S has the 3x3 mod and jets done, it runs like a pickle seeder.
ChromeSux is offline   Reply With Quote
Old 09-01-2013, 07:47 PM   #20166
See-Three
C3
See-Three's Avatar
Oddometer: 144
[QUOTE=LSGiant;22233350]
I set the front tire up at 21 psi just before the ride, simply felt the rear and called it good. it was probably right around 20psi
See-Three is offline   Reply With Quote
Old 09-01-2013, 08:31 PM   #20167
George 99
George 99's Avatar
Oddometer: 778
Originally Posted by Wasca View Post
Really? not enough top end speed? I'm running 15 x 47 and I can get to 140Km easy, I suppose if you really want to go faster than that then the lower tooth rear will help. Oh and I'm on the DR-Z400E Aussie model.
Wasca, did you have any trouble fitting the 15 on your E? I just tried and swingarm slide guard won't allow it.
Help?!
TNX,
George
Old 09-02-2013, 01:46 AM   #20168
Muddler
Muddler's Avatar
Oddometer: 776
Originally Posted by 955616846 View Post
Yep, I use Tubliss that makes removing a wheel a rare thing.
Have you had any trouble with Tubliss and minor rim dents?
Muddler is offline   Reply With Quote
Old 09-02-2013, 01:48 AM   #20169
Muddler
Muddler's Avatar
Oddometer: 776
Have you had an trouble with Tubliss losing seal due to minor rim dents?
Old 09-02-2013, 07:23 AM   #20170
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 620
If I were you I'd remove the carb. Take it apart so that you can get to the needle, washers and black plug. Following the proper sequence of reassembly with the final and important step-make sure the black plug is firmly seated over the grooved end of the needle. It it pops off you will get exactly that symptom. DAMHIK
'05 BMW R1200RT
'13 KTM 690 Enduro R
Ride tales
Utah / Colorado http://tinyurl.com/lcy2yhu
Mexico http://tinyurl.com/lhgznun
coarsegoldkid is offline   Reply With Quote
Old 09-02-2013, 07:36 AM   #20171
coarsegoldkid
Oddometer: 620
I certainly like the idea of Tubliss. Their information says for off-road use only. I road my DRZ on a long dirt ride over two weeks. Road riding at highway speeds was inevitable. So for dual sport bikes I wonder.
'05 BMW R1200RT
Ride tales
Old 09-02-2013, 09:51 AM   #20172
Wlfman
Wlfman's Avatar
Oddometer: 1,290
I learned my lesson on Aluminum Sprockets. At least it was Cheap being on sale and all.
Aprox 1200 miles on this:
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 09-02-2013, 09:55 AM   #20173
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 365
Ouch..talk about premature wear.
THRASHED is offline   Reply With Quote
Old 09-02-2013, 10:04 AM   #20174
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,521
I just went out and checked, all that part is correct, i am about to come to the conclusion that is is a combination of the below.
1. Stock jetting.
2. Snorkel removed.
3. Aging rubber diaphragm.
Last week i ordered a new diaphragm, i will also do the 3x3 mod as well, when the parts get here.
Old 09-02-2013, 10:08 AM   #20175
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,709
Originally Posted by Bear Archer View Post
So I'm kinda new to the drz. What are some of the necessary modifications?
I'm talking about trying to make it more reliable not so much as superior.
Sent from my DROID RAZR using Tapatalk 2
I beat on mine for a year, in stock form, before doing any modifications. Just start with fresh oil/filter, fresh air filter and fresh tires. Then consider milage and things like chain/sprockets, valve adjustments and everything else that wears out with time and miles.
These bikes are pretty bullet proof. Just make sure you have "case savers" on it. The Thumper Talk ones are fine.
Sent from my fat thumbs on a small touch screen.
“If God invented marathons to keep people from doing anything more stupid, triathlon must have taken Him completely by surprise.” P. Z. Pearce
'14 KTM ADV R - '06 DRZ 400
fifthcircle is offline   Reply With Quote
Times are GMT -7.   It's 07:37 AM.
