Old 09-03-2013, 06:43 PM   #20191
wingam00
Formely AKA Wingam00
wingam00's Avatar
Oddometer: 528
bmwpowere36m3 thats good to know about the 20% odd for being an ADV inmate.
DR650SEDDY thanks for the info, but looking for used to save some $$s.
Mark
“There is only one reason for pavement and that is to get to dirt.” - “King” Richard Burleson
-- If you argue with a Fool you are a FOOL! --
wingam00 is offline   Reply With Quote
Old 09-03-2013, 06:59 PM   #20192
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,658
Flogged her pretty good this weekend. All day Saturday, leading a group all over the "good" roads in NE Nebraska. Then I cleaned!
Sent from my fat thumbs on a small touch screen.
“If God invented marathons to keep people from doing anything more stupid, triathlon must have taken Him completely by surprise.” P. Z. Pearce
fifthcircle is offline   Reply With Quote
Old 09-03-2013, 07:34 PM   #20193
Singletracksam
Oddometer: 7
I make big air box and pop out my exust and it seem to make very good power. I thin it breath better
Singletracksam is offline   Reply With Quote
Old 09-03-2013, 07:49 PM   #20194
Tilt2turn
Tilt2turn's Avatar
Oddometer: 437
I enjoyed taking my 400E up Taylor Pass over the weekend. It's the most challenging road I've taken my bike on.
02 DRZ400E, plated
http://winginit.smugmug.com/
Tilt2turn screwed with this post 09-03-2013 at 08:00 PM
Tilt2turn is offline   Reply With Quote
Old 09-03-2013, 09:22 PM   #20195
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,912
Nice...
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 09-03-2013, 09:57 PM   #20196
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 597
They call this a trail in parts Utah.
'05 BMW R1200RT
'13 KTM 690 Enduro R
Ride tales
Utah / Colorado http://tinyurl.com/lcy2yhu
Mexico http://tinyurl.com/lhgznun
coarsegoldkid screwed with this post 09-04-2013 at 05:48 PM
coarsegoldkid is offline   Reply With Quote
Old 09-03-2013, 10:01 PM   #20197
coarsegoldkid
Oddometer: 597
Is this a commercial for Cheer . Your whites are sooo white and the blues are vibrant.
'05 BMW R1200RT
Ride tales
Old 09-03-2013, 10:50 PM   #20198
Tropic-Of-Canada
Thread Derailleur
Tropic-Of-Canada's Avatar
Oddometer: 851
Ok, re-jetted my S with a stage 1 Dynojet kit, 134 main, like it said, 4th clip up, fuel screw 3 1/2 turns like it said.
It got rid of the WOT bog, but I get a bit of pinging when I crack it in the cruising to mid rpm range, higher RPM's it's fine....
Still too lean I'm guessing.. Where should I start, raising the needle, or change to the 136 jet?
I'm thinking raising the needle position first, reading that it usually controls between 1/4 to 2/3 throttle, also given that it's easier to get to, rather than pulling the carb for a jet change....Good idea, or go straight to the main jet???
Tropic-Of-Canada is offline   Reply With Quote
Old 09-04-2013, 07:15 AM   #20199
fifthcircle
Beer Knurd
Oddometer: 5,658
I'm envious of you Colorado guys. I'm going to make it a goal to get out there and ride at least one weekend every summer.
Originally Posted by coarsegoldkid View Post
They call a trail in parts Utah.
Good, bright sunlight helps
Old 09-04-2013, 07:25 AM   #20200
Naq
Kitsune
Naq's Avatar
Oddometer: 200
I had the same issue during testing after reassembling the cylinder and head, but it turned out to be the chain slapping when getting on it from mid/low rpm on the street. I thought my engine was going to explode at first.
Check your chain tension first so you're not amplifying it. Cruise around as long as you can at the suspect rpm then shut down and allow the engine to cool before pulling the plug and checking if the mixture is too lean. I'm not sure the stock engine has high enough compression to ping on a hot lean mixture or not.
Aside from that noise, how is the idle and throttle response below WOT?
That side up.
'02 FZ1, '02 DRZ400S, '09 TE250
Naq is offline   Reply With Quote
Old 09-04-2013, 01:27 PM   #20201
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by 955616846 View Post
It is hard to get an idea of what is going on there with the information supplied. It could be a few things... needle position, jet size or slide response as the throttle is opened.
On the last... The lighter spring with the DJ kit allows the slide to open more increasing pressure (reducing suck) at the needle jet causing a momentary (a second or three) lean mix when the throttle is "cracked". Slide response is limited by the need to accelerate the fuel in changing conditions. The OEM set up is a fairly fine balance of spring pressure and slide port dimensions to produce a slight delay to the slide in order to provide a momentary lower pressure (more suck) to accelerate the fuel through the needle circuit before the slide stabilises... the function is throttle mixture enrichment for CV carbs in lieu of an accelerator pump... The DJ kit messes with that balance requiring overall wetter mixtures to compensate or other measures such as slide port adjustment to correct. It is just easier not too buy DJ kits when other better designed kits are available.
One thing at a time. I'd start with the needle if WOT above 7000rpm is okay.
Scuse my brain fart but WOT ??
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 09-04-2013, 01:45 PM   #20202
Tropic-Of-Canada
Thread Derailleur
Oddometer: 851
I think it's the same as WFO!
I'm kind of not surprised my bike is still running lean, being at sea level.
Old 09-04-2013, 02:47 PM   #20203
ram1000
ram1000's Avatar
Oddometer: 1,833
If by cracking you mean fully opening the throttle it would be the main jet as the needle is tapered out of the metering area. If you mean only another quarter throttle then it would be the needle, but the needle position would best be adjusted based on steady cruising at that throttle opening rather than momentary responses. Also realize that a sudden change in throttle is variable depending not on the twist of the throttle but the overall vacuum moving the slide which in turn adjusts the positioning of the needle. In other words there is no direct relation between the throttle position and the needle position.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 09-04-2013, 09:12 PM   #20204
bmwpowere36m3
bmwpowere36m3's Avatar
Oddometer: 90
Yea I searched for a while and didn't find any in the rates I was looking for used. I'm guessing not many people upgrade the springs and then sell them off later...
$180 new springs (Shock Spring 5.7 & Fork Springs 0.48)
bmwpowere36m3 is offline   Reply With Quote
Old 09-05-2013, 10:32 PM   #20205
MrPulldown
MrPulldown's Avatar
Oddometer: 3,045
What kind of bulb does a drz400E use? The single filament 55w one.
MrPulldown screwed with this post 09-06-2013 at 10:29 AM
MrPulldown is offline   Reply With Quote
Times are GMT -7.   It's 02:30 AM.
