Old 09-06-2013, 12:08 PM   #20206
bobfab
bobfab's Avatar
Oddometer: 1,409
photo from my "sick" day yesterday
This thread never has enough bike pics
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 09-06-2013, 12:16 PM   #20207
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,432
More bike photos?
That photo was taken after this was done (hopefully correctly):
One of my favorite local short (60mile) loops, Helvetia Mine loop:
Ubiquitous Tucson "backside of Mt Lemmon" shot:
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 09-06-2013, 12:53 PM   #20208
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
Originally Posted by 955616846 View Post
It looks like a H3C.
OK what kind of bulb is that. No hi low Motorcycle HID's available for it. This kind of messes with my plans.
Is there another name for this kind of base? Like a b0004 something or other.
MrPulldown screwed with this post 09-06-2013 at 02:42 PM
MrPulldown is online now   Reply With Quote
Old 09-06-2013, 03:35 PM   #20209
Gadget678
Gadget678's Avatar
Oddometer: 1,185
Originally Posted by MrPulldown View Post
A normal H3 will fit (but your earth/ground may have to be done differently. Common as- mostly in driving lights. Available at any auto store... heaps on ebay, but I've never heard of one with Hi/Low.
HID hi'low usually don't look like they'll fit properly and, from the few I've seen, are not a 'direct fit' for these smaller globes.... but they claim to fit.
This came up on ebay AU, look up some in your own area:
http://www.ebay.com.au/itm/AC-12V-55...item2ec9a426b3
For the money, I'd just look at changing the whole light to something like the Trailtech X2. Less stuffing around. http://trailtech.net/light_comparison.html
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 09-06-2013, 03:53 PM   #20210
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,480
I might be getting addicted.
Bought 2 this year, took the 2001 yellow with graphics one to Colorado and Moab this year, bought the 2003 from a inmate after i got back.
[IMG][/IMG]
ChromeSux is offline   Reply With Quote
Old 09-06-2013, 07:20 PM   #20211
675nyc
Oddometer: 3
First time doing an oil change.. and overtorqued the oil drain plug leading to a crack in the threads.
Anyone have any suggestions on patching this up? I was considering JBWeld or similar options unless someone has a better idea.
Image here: http://i.imgur.com/o880KTR.jpg
675nyc is offline   Reply With Quote
Old 09-07-2013, 06:00 AM   #20212
tdrrally
tdrrally's Avatar
Oddometer: 3,332
the off road lens is very small , this means less light with out a good optical lens to amplify the lumens .
look in to 2-4 rows of leds some for low and some for hi beams
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 09-07-2013, 04:54 PM   #20213
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 580
I have stumbled across this tidbit. I was going to look at another one tomorrow, but he sold it already.
http://dallas.craigslist.org/ndf/mcy/4048676700.html
I know the obvious questions to ask. What are some non standard things to look at that might be wrong with the 2002's. Ill check airbox, verify carb is not the CV carb and make sure everything looks ok from the outside. Any other information I should know?
2006 Suzuki DRZ 250
redleger is offline   Reply With Quote
Old 09-07-2013, 06:10 PM   #20214
bmwpowere36m3
bmwpowere36m3's Avatar
Oddometer: 90
Best repair would be welding up the cracks and re-tapping the oil drain bolt thread. Obviously you could also get a new lower case, but that's a lot for money and time. JB... yeah it'll work in a pinch, but I wouldn't ride around like that for any period of time.
If you search around this damage has happened to a few members. The usual cause is reusing the crush washer which leads to over-torquing the bolt.
bmwpowere36m3 is offline   Reply With Quote
Old 09-07-2013, 07:13 PM   #20215
rustycager
rustycager's Avatar
Oddometer: 580
Ouch! I was worried about that today when I had to reuse my washers. This is were I use a shorter 3/8 ratchet and just snug. My torque wrench seems to overtorque at these low ft lbs. Could try having it welded or find a new case.
2004 DRZs
rustycager is online now   Reply With Quote
Old 09-07-2013, 07:21 PM   #20216
See-Three
C3
See-Three's Avatar
Oddometer: 143
I did the same thing to my 1985 cb700 while i was in florida just before my trip back to nh....I tried jb welding it, but still ended up going through 10 quarts of oil in 30 hours... I agree with getting it welded.
See-Three is offline   Reply With Quote
Old 09-07-2013, 07:50 PM   #20217
See-Three
C3
See-Three's Avatar
Oddometer: 143
does this happen to be you?
http://boston.craigslist.org/sob/mcy/4052365216.html
Old 09-07-2013, 08:16 PM   #20218
rustycager
rustycager's Avatar
Oddometer: 580
Looking for tire advice. So far 95% of my riding has been gravel and pavement. I have t63's on it and can't think of one bad thing to say about them other than they only seem to last about 2000 miles but can be had for under $150 a set. I've pushed them fairly hard on both dry and wet pavement and they hang in there.
Think I would be disappointed going with something like a 705 or 700 over these? I never plan on being a hill climbing madman offroad so mainly concerned with gravel and gravel/sand that is kicked up in the roadway everywhere around here.
2004 DRZs
rustycager screwed with this post 09-07-2013 at 08:22 PM
Old 09-07-2013, 08:54 PM   #20219
gwhis
gwhis's Avatar
Oddometer: 474
T63s
i went through a rear T63 in 3 months so I just put a 140 TKC80 on since I get 5000 out of them on my F800
It'a a disease and once you have it-that's it, it doesn't leave your body.
Colleen Millsaps, On Any Sunday The Next Chapter
gwhis SE IN
DR650 DRZ
gwhis is offline   Reply With Quote
Old 09-07-2013, 09:03 PM   #20220
675nyc
Oddometer: 3
Originally Posted by See-Three View Post
Hah! Matches my bike closely but that's not me. I'm hoping to fix it and ride it for a while before I think of selling.
Thanks everyone, I'll try to find a tig welder
Times are GMT -7.   It's 11:51 PM.
