Old 02-11-2014, 05:24 PM   #21946
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,779
Rode a DRZ400 for the first time yesterday....
cool little bike....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Under Construction
950SE......Desert Beast
'Berg 570..Trail Beast
Nowwhat is offline   Reply With Quote
Old 02-11-2014, 06:41 PM   #21947
marine_mike
marine_mike's Avatar
Oddometer: 319
Originally Posted by bobfab View Post
The only blinkers that i have found to be crash proof are the ones that surface mount.
I am parting out my DRZ here, lots of 'rare' aftermarket goodies: http://advrider.com/forums/showthrea...8#post23442488
I use these. They are bright as all hell and viewable from the side and the rear. (They are on the rear fender.)
marine_mike is offline   Reply With Quote
Old 02-11-2014, 08:10 PM   #21948
ohgood
ohgood's Avatar
Oddometer: 2,636
is so cool to see stuff a buddy made on those bikes ... get thrashed ...
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 02-12-2014, 12:44 PM   #21949
GoGoGavin41
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 812
Looking for a DRZ
Figure I'll do a shameless plug in here as I'm eager to get on a DRZ. Looking for a scoot in SoCal if anyone is planning on parting with theirs/a friend's.
GoGoGavin41 is online now   Reply With Quote
Old 02-12-2014, 01:02 PM   #21950
Plane Dr
Plane Dr's Avatar
Oddometer: 847
I have used those and a couple LED versions. Work like a charm.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 02-14-2014, 09:52 AM   #21951
nmtrialsguy
Oddometer: 204
Question E Model hoses?
Anyone know of a source for high temp silicone radiator hoses for the E model? I have been looking to no avail...thx for any help.
'15 Freeride 250r
'12 KTM 500EXC
'07 Ural GearUp
nmtrialsguy is offline   Reply With Quote
Old 02-14-2014, 09:54 AM   #21952
bobfab
bobfab's Avatar
Oddometer: 1,395
There is some on ebay called pro silicon hoses or something like that. It took me a try or two before i found the right ones.
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 02-14-2014, 10:28 AM   #21953
oldenuf
Oddometer: 453
comparing motorcycle gearing
Interesting site for time when riding is not ideal.
www.gearingcommander.com/ Not every motorcycle is reviewed, but if you can find the primary and transmission and final gear ratios and tire diameter you can look at a ton of information on gearing and gear options.
Art
oldenuf is offline   Reply With Quote
Old 02-14-2014, 11:05 AM   #21954
nmtrialsguy
Oddometer: 204
Thumb Cool
Thanks! Found them, and ordered, should have tried there first!
'15 Freeride 250r
'12 KTM 500EXC
'07 Ural GearUp
Old 02-14-2014, 11:10 AM   #21955
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,391
Tuff Lites are the best:
Old 02-14-2014, 02:21 PM   #21956
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
So how easy is the install on the DRZ, I see they need a relay and possibly a special turn signal harness
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 02-14-2014, 02:26 PM   #21957
Dell_dude
Dell_dude's Avatar
Oddometer: 185
The relay is the flasher relay. Grab one on eBay or something similar, and it's plug and play. It replaces the stock non LED flasher unit that's hiding behind the headlight mask.
Then it would just be a matter of connecting the two wires per turn signal.
Seems pretty straight forward to me.
DeLorme inReach SE tracker
Dell_dude is online now   Reply With Quote
Old 02-15-2014, 01:08 AM   #21958
Goofy Footer
Oddometer: 497
FMF Powercore to Q4 - Rejet Needed?
Hey Guys,
I recently swapped my old FMF Powercore4 (pre decibel rating requirement pipe) for a new FMF Q4. The bike has historically ran great with the Powercore4 but it was simply too loud for me on long rides (not that the Q4 is all that quiet either..).
I've started to notice that my idle seems a tad lower and that the choke (cold start enrichment) doesn't seem to have as much effect/change as before - ie the the choke idle isn't much higher than regular idle. Occasionally when I come off throttle after a long full throttle section (highway exit ramp for instance) the motor dies (carb related). It's hard to explain but it kind of "feels" fat/rich. I might be off with that diagnosis - hence why I'm asking for advice/opinions.
I know I can tinker with the idle adjustment and I will be cleaning/replacing the idle jet soon. My question is whether switching from a wide open pipe like the old Powercore (FMF said it's over 100db and a very free flowing pipe) to the Q4 could require a rejet? Complicating things is that I want to install a 1 1/8ths inch FMF insert to quiet the Q4 down further.
Any links to rebuild kits/parts? It's time for a refresh on my beloved DRZ-E as it is getting a little long in the tooth.
Thanks for your advice, I want my ol DRZ to be back and running strong once again!
Goofy Footer is offline   Reply With Quote
Old 02-15-2014, 06:27 AM   #21959
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 342
On the subject of lights. I'm running the Edge tail-light turn signal combo. If they are not mounted too tight, the pivot just fine. I've had my share of downs and they are still holding in there.
THRASHED is offline   Reply With Quote
Old 02-15-2014, 08:29 AM   #21960
AngryRed
Lost in Cyber Space
AngryRed's Avatar
Oddometer: 365
I'm looking for a fender eliminator for my new DRZ SM. Saw this recommended on supermoto junkie.
http://www.wheelingcyclesupply.com/s...r-drz400sms/46
Still the hip way to go? Their post was a little old. Anyone have experience with them? Bolt right up and go?
2013 Super Tenere
AngryRed is offline   Reply With Quote
Times are GMT -7.   It's 09:23 PM.
