Old 06-13-2009, 09:56 PM   #3136
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,260
Send a message via AIM to rthuey
Originally Posted by Drizzt
Anybody have a spare magneto cover for an s model that they would like to sell for less then 50 bucks? I broke mine and don't have enough money for a stock replacement ($150). I normally wouldn't post something like this but I'm in a bind.
do you have a spare stock exhaust you can trade?
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 06-13-2009, 10:19 PM   #3137
Drizzt
Ranger
Drizzt's Avatar
Oddometer: 997
Nope, sorry-I bought the bike used and it came with a yosh pipe and didn't come with the stocker pipe. I'm pretty sure that if I pay you for it it'll be enough for a stock exhaust though?
2000 Suzuki DR-Z400S
And what is good, Phaedrus, and what is not good- Need we ask anyone to tell us these things?” Pirsig
Drizzt is offline   Reply With Quote
Old 06-14-2009, 11:45 PM   #3138
caljon88
caljon88's Avatar
Oddometer: 111
Stock exhaust
Have one sitting in my shed doing nothing. It fits my 2009 400S, never used and if you want it you can buy it plus shipping. Cheap.
Send me a PM.
caljon88 is offline   Reply With Quote
Old 06-15-2009, 01:24 AM   #3139
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,260
so fiche calls out 2 numbers for both models, which one is the one you have
e
s
Old 06-15-2009, 02:37 PM   #3140
Drizzt
Ranger
Drizzt's Avatar
Oddometer: 997
Thanks for the offers guys but I already got one, thanks anyway! Happy riding.
Hmm, I actually have another question-do you need any special tools to install a jetting kit? I remember seeing a jet changer tool or something, is this needed to change it? Thanks
Old 06-15-2009, 08:16 PM   #3141
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
My KLx400R (offroad model) has an FCR carb (which is different than the CV as we all know) and I used a 6mm 6-point socket to change the main jet in it. The carb also has small metric allen head bolts holding the bowl and top cover on. Your's will be metric but the sizes might be different. The pilot jet on mine is removed with a flat blade screwdriver. Most importantly, go slow and have a small cup or dish to put everything in. Stuff gets lost easy when I'm working on carbs. Good luck!
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 06-18-2009, 11:27 AM   #3142
Stillupright
Make my day
Stillupright's Avatar
Oddometer: 284
Renthal CR HIGH plust 1 inch risers
My 2005 DRZ400S has stock handlebars with 1 inch Dirtly risers. If I put a CR High bend bar on the bike, will the stock cables still work?
Really want more rise to make standing easier but not really excited about needing to change all of the cables
2008 Versys
2012 WR450F
Stillupright is offline   Reply With Quote
Old 06-18-2009, 12:00 PM   #3143
EmmEff
Wannabe
Oddometer: 1,244
I've got Pro Taper Contours Cr Hi on Vortec Fat'daptors on my '08 and there's no issue with cable lengths.
EmmEff is offline   Reply With Quote
Old 06-18-2009, 09:37 PM   #3144
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 255
Just did this a week ago. Got the CR High bends plus 1" risers with plenty of slack left in the cable. Be prepared to move your igniton though, as there isnt much room to fit a key in with the new bars.
SOMBs!!!!
pavemike is offline   Reply With Quote
Old 06-18-2009, 09:47 PM   #3145
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,299
I didn't have to move mine but mine is an offroad model so no gauges getting in the way.
Prov 3:5 & 6
Old 06-19-2009, 12:59 PM   #3146
haknslash
haknslash's Avatar
Oddometer: 333
What I did for the DR.Z today...
Woke up early this morning and tore the bike down to check the valve clearances (all good and within spec ) and also finally get around to installing my TT MCCT! So much peace of mind now! Bike seems a little more quiet too but could be my imagination. DRZ is a noisy motor anyways .
Some pics...
(slack and cam gears not fully aligned in this pic because I had remived the stock CCT thus taking some tension off the chain)
TT MCCT installed and locked down
BTW the instructions on the piece of paper you get from TT need to be revised IMO. It says to finger tighten the MCCT and rotate the crank while taking up the slack in the chain by feeling the nut on the MCCT and tightening it when you feel the slack. I questioned this part of the install and I NEVER did that extra step on any of my other bikes (I install a MCCT on all of my bikes). When I did this what TT suggested and was rotating my crank after 1 revolution I heard the dreaded sound of cam gears jumping timing !!! Intake cam gear was trying to jump a tooth or two. Thankfully I was able to get it fixed without having to remove the cam gears. I would not do that extra step at all. Tighten it down finger tight while watching the cam chain take up the slack. One you've got it finger tight then snug up the locking jam nut. THEN rotate the crank while watching the chain.
No issues and bike runs fine.
haknslash is offline   Reply With Quote
Old 06-19-2009, 01:05 PM   #3147
haknslash
haknslash's Avatar
Oddometer: 333
BTW anyone have a stock seat they would want to sell me (all black or blue/black)? I'm wanting to shave one down a little.
Old 06-19-2009, 02:06 PM   #3148
y2blade
y2blade's Avatar
Oddometer: 747
taken this afternoon while out enjoying my new exhaust
y2blade is offline   Reply With Quote
Old 06-19-2009, 04:48 PM   #3149
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,260
too bad you did not ask yesterday, he's even just a bit north of you
Old 06-19-2009, 07:20 PM   #3150
mattc
mattc's Avatar
Oddometer: 402
Someone buy my DR650 so I can get a DRZ400!!!
http://www.advrider.com/forums/showthread.php?t=471031
It's all stock, $2500.
2008 950 SE-R
2000 XR650R
2001 CR250R
1983 ATC200E
mattc is offline   Reply With Quote
Times are GMT -7.   It's 10:24 PM.
