Old 03-28-2008, 09:09 AM   #766
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Originally Posted by taco250
$299? That's about 50 less than Corbin. I'm going to try the DIY method I think: get some better foam from the local upholstery and maybe some better vinyl too then start tearin and trimmin.
I just got my SDG tall seat for the DRZ. I got lucky as these things seem to be out of stock all the time. Anyways it was about $100 and its a little wider then stock and taller. The foam is a bit stiffer so far and the seat surface is a lot grippier....it will no doubt be a much better trail seat.....the bike is not set up for touring so I cant comment on how it would be for extended long distance rides.
Seth S
Seth S is offline   Reply With Quote
Old 03-28-2008, 09:18 AM   #767
dre10dancer
Above the Tree Line
dre10dancer's Avatar
Oddometer: 71
Sargent will makeyou a seat. Fast turn-around. good work. good prices.
BTW, I've just set up my for SHORT TRACK
Because it is there.
dre10dancer is offline   Reply With Quote
Old 03-28-2008, 03:01 PM   #768
bikeslut
adventurous stud
bikeslut's Avatar
Oddometer: 1,661
I just got the same seat... so far, i love it... and it was cheap.
Now i have my stock pan to play with... I'm thinking a wider rear (the seat; not mine) with some firm foam just on the back section. That will be my meg-mile seat, if I ever get that urge.
you're asking HERE?!
bikeslut is offline   Reply With Quote
Old 03-28-2008, 03:20 PM   #769
on2wheels52
Oddometer: 2,344
Just a quick uestion on fork oil on a DRz400S, is a one liter bottle enough to do both fork legs?
Jim
R1200GS Ural Patrol KLR650 DRz400 XL185
Austria '08 http://www.advrider.com/forums/showthread.php?t=352082
Back to the Alps in '11 http://advrider.com/forums/showthread.php?t=744205
on2wheels52 is offline   Reply With Quote
Old 03-28-2008, 08:30 PM   #770
GooseR6
Ride the World!
GooseR6's Avatar
Oddometer: 101
Front fork oil capacity is 709ml. I am 99% sure that is per fork. I haven't done mine yet on the DRZ but I needed 2L for my KLX.
Also, I have a Corbin on my DRZ and my R6. I think they are great. For the R6 it is comfortable. For the DRZ I don't sit on the seat much because I mainly use it for trail riding but the height is perfect for my 5'7" frame.
It is always something...
GooseR6 is offline   Reply With Quote
Old 03-29-2008, 06:22 AM   #771
on2wheels52
Oddometer: 2,344
Thanks Goose, I don't use 5wt in anything else and didn't want excess. Will spring for two liters.
JIm
Old 03-29-2008, 08:36 AM   #772
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
JIm
If you want a little more dampening in the front end you may want to try 7W instead. It helped a lot with the bottoming and excess dive I was experiencing.
paochow is offline   Reply With Quote
Old 03-29-2008, 11:09 AM   #773
on2wheels52
Oddometer: 2,344
On most bikes I have gone up a step in fork oil weight, this one has the best suspension of any of my bikes without any modifications. Plus I'm only 155 and this bike never carries any luggage so don't need additional damping.
Jim
Old 03-30-2008, 06:29 PM   #774
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
I put 10w in when I changed my fork oil last time as I already had one qt on the shelf. Made the front stiffer, maybe a little too stiff. Still playing with the clickers so it will be a little softer on the rocks.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 03-30-2008, 07:20 PM   #775
hart11b
hart11b's Avatar
Oddometer: 45
Just picked up my new to me 2006 DRZ400S! I'm stoked to take it out and rage.
I have a question about an upgrade for those that may have done it. I've seen the DRC taillight and turn signal mod that looks pretty sweet. Anyone know which one to get and what additional parts to get. I see talk of the Edge vs. Edge II, but which one do I want?
More DRZ posts to come by a new owner.
2006 DRZ400S
hart11b is offline   Reply With Quote
Old 03-30-2008, 07:50 PM   #776
TwoShots
Vagabond
TwoShots's Avatar
Oddometer: 1,448
Edge II
TwoShots is offline   Reply With Quote
Old 03-30-2008, 09:25 PM   #777
Odin69
Odin69's Avatar
Oddometer: 384
fuel tank
I want to put a larger fuel tank on my 06 DRZ and from what I have read here in the thread, a Clark is the one I may want to try. Do they install easy? I have read that on some of the other brands you may need to move the fan? Do you have to do this with the Clark also?
Odin69 is offline   Reply With Quote
Old 03-30-2008, 10:45 PM   #778
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Mine has the IMS 4gal and it fits fine. If I were to do it again though, I'd go for the Acerbis 4.25 gal. It rides a little higher but has dual petcocks and uses the factory radiator shrouds. I can only get 3.5 gal out of my IMS before I hit reserve and I never get all of it as some sits lower than the petcock.
Prov 3:5 & 6
Old 03-30-2008, 10:49 PM   #779
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
Nope, the fan stays in place. Install is fairly easy, just don't forget the through the frame cross brace. The only issue I had with the Clarke is that it is very close to the kickstarter, causing rubbing if left alone.
Old 03-31-2008, 10:20 AM   #780
Odin69
Odin69's Avatar
Oddometer: 384
I have an S model without a kickstart, but thanks for the info. I was concerned about having to relocate the fan.
Times are GMT -7.   It's 06:59 AM.
