Old 04-03-2008, 08:05 PM   #796
wide open
in second gear
wide open's Avatar
Oddometer: 354
Any of youse have both a top rack (maybe the Suzuki or the Pro Moto) AND Dirt Bagz (with their support rods) installed?
If so, did the supports for the Dirt Bagz and the top rack mounts conflict?
And also if so, is there a photo of your set-up on one of the Z threads?
Muchas gracias.
wide open is offline   Reply With Quote
Old 04-03-2008, 10:19 PM   #797
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Originally Posted by Black06LJ
Thanks. 15/41 looks good to me. My 15/44 gets my fat butt up to 87mph. I just want better rpm at 75mph.
I'm using 15/47 as I was offroading a lot more than pavement. Now that it's getting used for commuting, I'm too broke to buy a smaller rear so I'll leave it be. I can still do 65 pretty easy on the hiway but it's revving more than I'd like.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 04-04-2008, 10:36 AM   #798
AdventureGirl
AG
AdventureGirl's Avatar
Oddometer: 98
Originally Posted by pi3832
If you get the Suzuki six-pack rack, you should be able to fit a Givi topcase adapter plate.
Not the cheapest way to go, but it should work.
I like the side mount tools but I'm thinking I want to go with a tube and a bit more volume for the tools
-AG
AdventureGirl is offline   Reply With Quote
Old 04-04-2008, 01:18 PM   #799
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
I am looking at the Givi (http://www.helmetheadcyclegear.com/c...ex.cgi?pid=546). I hate wearing a backpack to work every day. I might even order the 30L one today.
Todd Sweeney - Cageless from 4/2008 to 8/2013.
Currently bikeless.
Black06LJ is offline   Reply With Quote
Old 04-04-2008, 01:30 PM   #800
pi3832
New to dirt
pi3832's Avatar
Oddometer: 14
I'll be installing a Monolock E30 on my SM this weekend. I test sat the case on the rack last night and I think it's going to be perfect.
I'll post results and hopefully pics.
Mike Freeman
In transit: Baton Rouge --> Chicago
2007 DRZ400SM DaRth Zed
pi3832 is offline   Reply With Quote
Old 04-04-2008, 01:44 PM   #801
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
Sweet. Review n a pic would be awesome. I'll wait on ordering until hear back. I think I would be very happy with one, but a real review from a real person means alot. Thanks.
Currently bikeless.
Old 04-04-2008, 03:31 PM   #802
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
sprockets
ok, so I wanna swap to a 41 tooth rear sprocket... Where is the best place to get one (price/quality)? I am not a fan of the dealership.
Currently bikeless.
Old 04-04-2008, 07:29 PM   #803
pi3832
New to dirt
pi3832's Avatar
Oddometer: 14
Installing a Givi Monolock topcase on a DRZ400SM
I lied earlier. I installed a 33-liter, not a 30-liter Givi topcase. It's a little shorter.
Anyway, it was a very easy install. The Givi mounting plate is universal, and comes with four "clips" for mounting to tubular racks. The clips are asymmetric, with each side supposedly for different sized tubes. Whatever, just use what works. An allen-head bolt goes through the plate, through the clip, and then into a locking nut.
I ended up only using three of the clips.
Note that I had to take the "tool box" off the rack to get the front(top) left clip installed.
There is very little clearance between the bolt and the fender. I'm not sure how well cutting the bolt shorter would work, because it was rather fiddly getting the nut on there as it was.
That stuff on the bolt is "Electric Pink" nail polish. My niece has poor taste colours. I prefer nail polish to Loc-Tite and the like because it's thicker, you apply it with a brush, and it's tacky right from the start. Works well for sticking washers to nuts for easier installation, too.
After installing the plate to the rack, you install a plastic cover over the diamond holes in the plate, and you're done! Just pop the topcase on and go.
Note that the way I installed the plate, you can see two of the clips sticking out. It might be worthwhile to paint them.
And, yes, I did make the ritual sacrifice of human blood to the motorcycle gods.
On the whole, the 33-liter seems the perfect size for the SM.
Can't say much about living with it, since I just installed it tonight.
One thing I did notice: apparently the Monolock cases do not have the rubber gasket between lid and case that the Monokey cases do. At this point I'm not too confident that the case is water proof. A little weather stripping should solve that problem, though.
At less than $100 for the case and the universal mounting plate, I think the little Givi Monolock topcases are a bargain.
Mike Freeman
Old 04-04-2008, 07:41 PM   #804
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
Sweet!
Looks great. Thanks for the pics too! I will order one tonight. It definately looks better than the milk crate I was tempted to bungee on. JK JK.
I like the look. Not too Vespa looking.
Currently bikeless.
Old 04-04-2008, 08:26 PM   #805
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,565
I use http://www.rockymountainatv.com/home.do
You will need a 110 link chain for 15/41. Stock S uses 112 links. I run 16/44 with my 17" wheels & it really makes it feel like a streetbike.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 04-04-2008, 08:30 PM   #806
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
ok... so I need to drop 2 links? or get a new chain? I am new to mod'ing bikes. I left my last 2 bone stock.
I'll have to call them. Their site shows no less than 47 teeth on rear sprockets.
Currently bikeless.
Black06LJ screwed with this post 04-04-2008 at 08:40 PM
Old 04-04-2008, 09:19 PM   #807
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
If your current chain is in good shape keep it and shorten it unless you need or want a new chain.
Prov 3:5 & 6
Old 04-04-2008, 09:36 PM   #808
DirtHopper
DirtHopper's Avatar
Oddometer: 408
If you find a shop with a parts unlimited catalog, you will find a wide range o sprockets available for the Dizzr. the range from 11 to 16 teeth on the fron sprockt and 41 up to 48 i beleive on the rear one. happy hunting
Witout pavement.....The world would be a better place!
DirtHopper is offline   Reply With Quote
Old 04-04-2008, 09:44 PM   #809
Black06LJ
ZRX1200R Thrasher
Black06LJ's Avatar
Oddometer: 300
thanks 4 helpin a noob!
Thanks ya'll. I know of a local shop that comes highly reccomended. He'll be doing the work. I just need to know the answers to his questions before I get there. Ya'll have been a great help.
Hope ya don't mind if I keep askin noob questions once in a while.
Currently bikeless.
Old 04-06-2008, 07:30 PM   #810
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 821
Question DRZ/KLX
Ok I think I am going to be getting myself a DRZe model....but to be quite honest I like the Kawasaki green better. I am pretty sure I know the answer, but just for my own edification....
KLX 400 is the same as a DRZ S model and not an E....is that correct?
Does the KLXs have a FCR or Mikuni carb.....Think Mikuni since the DRZ changed to Mikuni in 04 (I think that is correct)
Any help would be greatly appreciated.
These are not the droids you are looking for.....
FS/FT: 2006 BMW R1200GS Adventure
drdfblackm is offline   Reply With Quote
Times are GMT -7.   It's 08:07 AM.
