Old 08-04-2011, 06:58 AM   #9901
tahoe_sasquatch
tahoe_sasquatch's Avatar
Oddometer: 27
Originally Posted by Naq View Post
Just look at the dog bones and see if they have Suzuki stamped on them. I can flat foot sitting on my DRZ with a 34" inseam. Make sure you set the rear spring rate and sag for your weight regardless. It makes a huge difference in performance.
Yes. My dog bones have 'suzuki' stamped on them. I measured the length and it's 125mm or 4.9'' (center to center). Are these stock?
Suspension setup is the next thing on my list - I would do it last week but riding is so much fun
tahoe_sasquatch is offline   Reply With Quote
Old 08-04-2011, 01:29 PM   #9902
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Brand or kit preference for Chain & Sprockets
Sorry I know this has been covered teeth number wise but What brand can you good folks recommend ?
I want to lower my ratio so thought a kit (two sprockets,tab washer, one chain) might be the best way to go if there is such an animal for the DRZ400S.
The plan would be to keep the stock set, 24 hrs on them and install new stuff.
Thanks in advance gents
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 08-04-2011, 01:52 PM   #9903
SloDon
Hey...where am I?
SloDon's Avatar
Oddometer: 638
Start here.......http://www.rockymountainatvmc.com/pr...dFamilyId=9635
This kit may not be the sprockets you want but the Primary Drive Brand of Chains and Sprockets are reasonably priced and DURABLE!
I have been very satisfied with them and serveral riding buddies also use them.....don't need a 'name' brand for more $
Don
SloDon
'12 R1200 GS Adv, '05 DRZ 400, '08 RE Bullet 500
http://www.youtube.com/user/SlooDon#p/u
Don't grow up.......it's a trap!!
SloDon is offline   Reply With Quote
Old 08-04-2011, 01:53 PM   #9904
Joey Jo Jo Jr. Shabadu
1 Less Car
Joey Jo Jo Jr. Shabadu's Avatar
Oddometer: 247
I bought my sprockets from Supersprox. Two sprockets (14/47) and the sprocket bolts. The rear sprocket is a steel ring gear button'd onto an aluminum carrier. You get the benefits of both worlds: steel longevity and the lighter (and unsprung) weight of aluminum.
They also have kits that include a new chain if you need one, but mine only had 400 miles on it, so I kept the existing one.
http://www.supersproxusa.com/
2009 Suzuki DR-Z400S
2007 Aprilia SR50R Factory
2005 Yamaha FZ-6
Joey Jo Jo Jr. Shabadu is offline   Reply With Quote
Old 08-04-2011, 03:19 PM   #9905
KEVINNJ30
Oddometer: 19
X2 hid light
Has anyone wired it to light both @ the same time on a drz400?
KEVINNJ30 is offline   Reply With Quote
Old 08-04-2011, 03:35 PM   #9906
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
chain: regina o-ring (though there are certainly other good chains out there)
sprockets: pick one. steel, though, unless you like replacing them more often.
LittleRedToyota is offline   Reply With Quote
Old 08-04-2011, 03:40 PM   #9907
Gadget678
Gadget678's Avatar
Oddometer: 1,198
Yep. No troubles at all. It only draws about 70w.. apparently the DRZ is about100-110w standard.
I hard wired the spot beam to be on permanently, then had the flood come on with the high beam switch. If you wire the spot and flood to the standard high/low wiring, you'll be riding in the dark for a few seconds while the other light fires up (whichever way you go from high/low, or low/high)
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 08-04-2011, 03:43 PM   #9908
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
U don't have to go expensive Eric, like others mentionned no need for brand name but make sure it's o-ring or x-ring type chain. My gearing is 15ct to 47T & i am happy with it, i climb steep rocky hills to freeway riding (up to 80mph) no problem. O-ring chain would be good enough. X-ring is a bit more $$$.
DR650SEDDY is offline   Reply With Quote
Old 08-04-2011, 05:05 PM   #9909
59DEN
59DEN's Avatar
Oddometer: 886
Originally Posted by mrt10x View Post
Those are E model DRZ's? you must have done some custom support work welded or bolted on the back of the E subframe? I mean there is nothing behind the battery box on the stock E frame. Any chance you have some pictures of what work you did?
Sorry, I was not aware of the different sub- frames on US bikes, could a S frame be fitted to your bike as they are a strong unit. Thanks to the other posts for pointing this out
Dennis
59DEN is offline   Reply With Quote
Old 08-04-2011, 05:21 PM   #9910
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,005
U mean like this ?? Yes there's a way u can connect it to z frame (on da batterie side), but u must shave a little of ur plastic cover for that arm to go under (i used dremel tool).
Old 08-04-2011, 06:55 PM   #9911
Gadget678
Gadget678's Avatar
Oddometer: 1,198
Originally Posted by 955616846 View Post
More like 180W from a stock S (E is the same?) although 100W is about all that we'd be able to draw on lights and accessories and a few rpm are required for that. 200W maximum is available with a rewind.
I was told 110w for my E (by Betta Bikes in SA - My focus was on the lighting though.)
It's 200w now.
Old 08-04-2011, 07:06 PM   #9912
VTSteve
VTSteve's Avatar
Oddometer: 160
I recently lowered my S down to 14/47 , with Steel Sunstar sprockets. They're the same as the OEM ones, and they're really durable.
I love the raitio, it's really wayyy better than the stock gearing off the pavement. I left my chain a bit longer than the stock size, (114 vs 112 Links), so I can get a bigger rear sprocket down the line without breaking the chain. It also makes rear wheel removal a little easier.
VTSteve is offline   Reply With Quote
Old 08-04-2011, 07:10 PM   #9913
VTSteve
VTSteve's Avatar
Oddometer: 160
That reminds me, has anyone tried out this rear sprocket?
http://www.motosport.com/dirtbike/pr...KET/?id=125450
The thing looks like it would last forever.
Old 08-04-2011, 07:19 PM   #9914
Gadget678
Gadget678's Avatar
Oddometer: 1,198
There is a bike running around locally that has one of them- very light and thin. It doesn't look like it would last, but he's given it a flogging... and it's doing well.
Here's another one to consider. (I read an article years ago that claimed that these guys were their own worst enemy- their sprockets just don't wear out)
http://www.chaingangchainsandsprockets.com.au/
Old 08-04-2011, 07:36 PM   #9915
bobbed06
Cavalera Conspirator
Oddometer: 1,236
I am on the fence wether I should go with the Trailtech X2 HID or the Trailtech 8 inch light. How do you like the x2 so far? Do you have a night time rider perspective with your light on that you would post for us to see? I really prefer the looks and weight reduction of the X2.
bobbed06 is offline   Reply With Quote
Times are GMT -7.   It's 04:07 PM.
