Old 08-13-2011, 05:04 AM   #10066
59DEN
59DEN's Avatar
Oddometer: 837
Thumb Touring Setup
Originally Posted by Jettn Jim View Post
Threadkiller covered that a couple post back thanx tho...
No worries on the Caliper mounts...yet since I found a set of 2005-E forks in GREAT shape! then grabbed a 2006-S Caliper too, both clean and fresh. Gett'n psyched up about this upgrade now...
Since I have'nt seen many pics in the thread lately I figured I'd show ya who I'm hang'n the 49mm's on
This is how Desiree' looks now with about every upgrade you can do....you name it, it's prob on her... ported 705, Moab shock, XS Twin, Rick Mayer seat, Rox risers, IMS Tank w/custom brace, Double-Take mirrors, Billet choke relo, Adjustable kickstand, Turn sig headlight off in the dirt switchgear, Heat troller controlled grips, KLX needle, Clean mounted throttle lock, all guards, bashplates, wiring etc... It's a long list probably 60 more things to go..let's just go get a beer instead.
Also ordered a new Battery today that's gonna save me 11 lbs over the Odessey! (which has been a killer batt too) WoooHooo
[/URL]
ALMOST every upgrade.....until 2nite I just bought that set of 2005 DR-400E forks w/Tree and a 2006 caliper. Then another 2005 KLR Tree so I can sell mine with my forks...which have Intiminators, Cogent springs, a bunch of xtra spacers, an old brace and new boots.
Gonna throw a Brittania Lynx faing on now , drop the fairing sub-frame, dash and some weight. I'll use a Vapor for data and build some signal/highbeam indicators. The front wheel will prob be a Warp 9 21x1.6 with billet hub (no speedo) stainless rotor, and either black, clear or red rims?? (any opinions on color?? ) Gotta do some more research and make sure it's a quality piece first.
Hi Jim, that is a well setup bike
Dennis
59DEN is offline   Reply With Quote
Old 08-13-2011, 06:35 AM   #10067
firemedic3293
firemedic3293's Avatar
Oddometer: 98
I like those tool tubes mounted on the skid plate- did you make those or are they sold somewhere?
2009 Suzuki DRZ400S-1984 Honda Magna VF700C-2011 F-150 Raptor SVT
Dual Sport Maps by Craftycoder
SPOT Adventures
SPOT Shared Page
RDS Adventure D/S Forum
firemedic3293 is offline   Reply With Quote
Old 08-13-2011, 09:59 AM   #10068
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Originally Posted by ZukiNoomin View Post
Not running any electrical accessories at all. From the looks of it, the insulation on the wiring attached to the
stator failed due to high temperatures. In my opinion, Suzuki should have used an insulation material better
suited to the harsh conditions inside a motorcycle crankcase. Also, the battery is undersized for an electric start-only machine.
Other than the stator problem, the bike has been 100% reliable.
OK good to know. So is there a better replacement stator from someone other than Suzuki? Should a rewind be done by a specialist? Or, are the replacement parts you buy from Suzuki IMPROVED? Or do just SOME of them do this? Or is the RR the real culprit anyway? Enuf to make you want to.
buls4evr is offline   Reply With Quote
Old 08-13-2011, 10:17 AM   #10069
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,790
Thumb
Dennis
Thank you Dennis
"firemedic3293 • Today 08:35 AM
I like those tool tubes mounted on the skid plate- did you make those or are they sold somewhere?"
Thanx I made them firemedic...I have a couple lengths of both 2" and 3" if youd like one...
I have used schedule 40 PVC and painted it etc...but it's pretty heavy stuff, so these/those are Black ABS solid all through (for when you slide down the road on yer tubes ) strong and much lighter. I also found the Oatey end caps to be the best for durability, weight and metal/rust freeness. I replace the center bolt with stainless and now use stainless nyloc nuts instead of a wingnut to open them. Someone will need a wrench or pliers to snoop around in my gear, though the wingnuts were a leeetle more handy not much though. JJ
Jettn Jim is offline   Reply With Quote
Old 08-13-2011, 11:09 AM   #10070
Drizzt
Ranger
Drizzt's Avatar
Oddometer: 1,034
The oem stator is expensive, there's a company that sells great replacement stators, ricky stator. There's some made by moose but the fitment isn't that great. There's all sorts of info on Thumpertalk about these. Don't get it rewinded, they never last, just get a new one.
2000 Suzuki DR-Z400S
And what is good, Phaedrus, and what is not good- Need we ask anyone to tell us these things? Pirsig
Drizzt is offline   Reply With Quote
Old 08-13-2011, 11:55 AM   #10071
Logpile
Mr.V- or Drz
Logpile's Avatar
Oddometer: 168
Kicker
I just put a kicker kit on mine. Dont have any electrical aftermarket stuff yet. But last year I stalled out WAY back out in the woods and it struggled to get started the last time on the battery. No way to push start when alone and in a wet sloppy, swampy trail. So I got the kit the very next day.
Not hard to install and it's nice to know I can allways kick it if I need to.
Logpile is offline   Reply With Quote
Old 08-13-2011, 12:00 PM   #10072
bobbed06
Cavalera Conspirator
Oddometer: 1,223
You should directly wire the regulator to the battery (aka Free Power Mod) which eliminates a possible point of resistance,arcing, and stator failure. Rick Stator is the only way to go for a stator.
bobbed06 is offline   Reply With Quote
Old 08-13-2011, 01:40 PM   #10073
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Hey dude you got a link for that mod
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 08-13-2011, 02:58 PM   #10074
LockRider
Oddometer: 44
I think red would look badass on that bike, black would look nice as well. In my eyes, if you are going to spend the money for aftermarket rims, they should at least look the part.
LockRider is offline   Reply With Quote
Old 08-13-2011, 03:06 PM   #10075
bobbed06
Oddometer: 1,223
Yessir....
http://www.thumpertalk.com/forum/sho...50#post9566050
There ya go.
Old 08-13-2011, 03:14 PM   #10076
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,069
I agree. You already have a lot of Black. Red would add a bit of visability, which should keep you a little safer in traffic....unless you get in front of a "Texter"
GlennR is offline   Reply With Quote
Old 08-13-2011, 04:00 PM   #10077
LockRider
Oddometer: 44
Humm...I wasn't thinking about visibility, I was just thinking of how sweet black and red would look. If visibility is a consideration, it also could be true of the fuzz seeing you better as well.
Old 08-13-2011, 07:52 PM   #10078
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,790
Thumb
Thanx guys! yup I've gotta keep add'n red to her...I'm wonderin' Black wheels, Red hubs and Red nipples???....or vise versa...I'm really doing this for strength and to help the bikes handling with a stiffer set of wheels...the Colors just a bonus :)
Only doin the front right now I think then the rear this winter...
Jettn Jim screwed with this post 08-13-2011 at 07:58 PM
Old 08-13-2011, 08:27 PM   #10079
Oddometer: 532
Good man
KLR 650-sold
1977 BMW R100-sold
Old 08-13-2011, 08:36 PM   #10080
LockRider
Oddometer: 44
WOW!!! Well, if black and red is your color scheme, then I would think the black rim, with red hub and nipples would be sweet.
Can I get these for my DRZ?
Times are GMT -7.   It's 04:02 AM.
