05-09-2007, 06:21 AM
#16 | |
Krusty Olde Pharte™
Oddometer: 4,844
MikeyT 86 Concours 90K75RT Non Illegitimi Carborundum Save $5.00 when you sign up for Smugmug. Use coupon code: vqfl6p4wLXH7s |
05-09-2007, 06:46 AM
#17 | |
from B4 "adventure bikes"
Oddometer: 7,647
if the GPS pulls more than 3A what then? ok the fuse opens now what? put another fuse in and it pops. what now? the GPS is toast is what. and the fuse did NOT protect it. if a device draws more than it's designed to it's broke. so how did the fuse protect it? from letting excesive magic white smoke out? right out of the device and / or the wire feeding the device it is NOT there to protect the device
Do one thing every day that scares you. Baz Luhrmann Women and cats will do as they please, and men and dogs should relax and get used to the idea. Robert A. Heinlen Adventure is discomfort recounted at leisure. Flash / GSWayne Chrome don't get ya home. Rob Nye Stamp Out Hoplophobia in Our lifetimes. 1999 Tiger 885 1995 XT600E
05-09-2007, 06:54 AM
#18 | |
Oddometer: 7,647
![]() 33CFR183 ![]() take yer pick
05-09-2007, 07:17 AM
#19 |
Unpaved road avoider
Oddometer: 888
http://www.powerstream.com/Wire_Size.htm indicates 14ga chassis wire can handle 32 amps. If the GPS pulls more than 3A, something went wrong and some part inside is fried or a wire is shorted. If shorted, there's a chance the short can be separated and the GPS function again. If fried, the fuse blows so more parts don't also die. Chances are it can be repaired. If a 10A line fuse was the only fuse in the circuit, the entire GPS is more likely to be toast. It's also possible for a regulator failure to feed too high a voltage into the GPS and blow the fuse before the GPS is damaged. Many pieces of equipment have their own fuse or circuit breaker. There is a reason for it.
Pat in order of ownership 1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A greywolf screwed with this post 05-09-2007 at 07:33 AM |
05-09-2007, 08:25 AM
#20 | |||||
Oddometer: 7,647
the line loss calculator shows 0.934 volts of line loss on a 14AWG wire 6 feet long. call it a volt. that's 30 watts of heat that the wire has to disperse. what's the ambient temp where the wire is, say under the tank over the head? what's the insulation's temp rating? "...In careful engineering the insulation temperature limit, thickness, thermal conductivity, and air convection and temperature should all be taken into account." (http://www.powerstream.com/Wire_Size.htm) use whatever wire you want, we've been here before. what they're talking about is a bare conductor in free air, not a wire with insulation in a hot environment. you quote a small company, I'll continue to quote NFPA and/or applicable Codes. Quote:
![]() Quote:
do you think the manufacturers calculate the current if this or that shorts, or this fries? Quote:
you can look at fuses all day and you'll see 120v rated fuses in 12 vdc applications and there's nothing wrong with that fuses are time rated devices because they work on heat you cannot expect a fuse to open fast enough to stop a voltage transient ![]() why is the fuse located at the source end of the supplied cable rather than at the device itself? to fuse the wire
