Old 05-08-2007, 12:28 PM   #1
airheadpilot OP
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 287
How to wheelie?
All,
I've got a problem. I can't seem to wheelie. Well, I have, but always on accident. I'm not interested in hooligan antics - riding down the freeway on one wheel and such, but occasionally it would be nice to deliberately and in a controlled fashion loft the front wheel to get over an obstacle. Seems that, when I goose the throttle on my XR650R all I get is tons of acceleration, but with both wheels on the ground. The harder I whack it open, the faster I go, but always on the level. What's the technique that I'm missing?
Andrew
1971 R50/5 project bike
1972 R75/5 toaster
1986 Honda Aero 50 (for sale)
2000 XR650R (Le Poulet du Desert)
2003 Burgman 400 (wife's bike)
2005 FJR1300A
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 05-08-2007, 12:45 PM   #2
Ceej
Ceej's Avatar
Oddometer: 442
First gear, get the revs up a bit, close the throttle, compress the forks, on the rebound open the throttle, lean back, and pull up. I would recomend trying these in small increments. And make sure someone is there to see you fall so they can point and laugh.
Ceej is offline   Reply With Quote
Old 05-08-2007, 12:51 PM   #3
Airhead
More human than human
Airhead's Avatar
Oddometer: 2,099
And keep your foot over the brake pedal!!!! That way, when you feel like you are going to flip over backwards, all you have to do is stomp on the pedal and the front end will come down. Try to resist the urge to throw your legs out behind you...that's how you get injured or get a foot caught between the chain and sprocket...
'05.5 KTM 950 Adventure
2008 KTM 450 EXC-R
All Orange, Baby!
Airhead is offline   Reply With Quote
Old 05-08-2007, 12:55 PM   #4
bikeslut
adventurous stud
bikeslut's Avatar
Oddometer: 1,708
couple other things
pointing up hill helps
get back on the seat
cover the rear brake, and keep the fingers on the clutch
your R should wheelie easier than most bikes
bikeslut is offline   Reply With Quote
Old 05-08-2007, 01:12 PM   #5
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
Check you jetting -- Uncork the thing and it should not have a problem.
I use my weight to my advantage and put my butt as far back as possible and just use the power of the bike to get over things.
Also, depending on your gearing it may help to lower it a bit.
alpiv is offline   Reply With Quote
Old 05-08-2007, 01:20 PM   #6
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
dude I can yank my R up in 5th with some body english, just hold the throttle WTFO and dump the clutch and make sure you get us some video
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 05-08-2007, 01:36 PM   #7
getmedirty
Mr Magoo
getmedirty's Avatar
Oddometer: 151
Read this thread!
http://www.advrider.com/forums/showthread.php?t=173274 He gives a lot of good advice.....
KLR 650
R1100RT
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines, Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream."
-Samuel Langhorne Clemens
getmedirty is offline   Reply With Quote
Old 05-08-2007, 01:53 PM   #8
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
That's on your Ruckus, I suppose...?
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 05-08-2007, 01:57 PM   #9
Ted West
n00b-ish
Ted West's Avatar
Oddometer: 485
Originally Posted by getmedirty
Yeah but then things start to skid off the tracks somewhere toward the middle. It kind of turns into this freakish movie script deal and then there is this whole Hillbilly/Deliverance theme that quite frankly makes me feel uncomfortable.
Watch your back man is all I'm say'n
-Ted West
'06 Husqvarna TE250
'82 Husqvarna 430WR
'81 Husqvarna 250XC
Ted West is offline   Reply With Quote
Old 05-08-2007, 04:52 PM   #10
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,975
I have a 600r in first and second I can power wheelie no problem. If I may be so bold I think you just arent being brave enough with the throttle. Its best to learn going around 2-5 mph then give it at least 1/2 to 3/4 throttle you will wheelie easy. I would not suggest doing it from a stand still as you will very easily find yourself with a completly vertical bike. I found this was the easiest way for me to learn. IMHO you dont need to compress the shocks and quickly releasing the clutch is a completly different technique, but at the same time one that can get you into alot of trouble if you are inxeperienced. Experiment with moving power wheelies they are the safest way to learn. Also shift your weight back more, if you ride the can the bike has to lift your mass as well as the front end. Good luck just get a little braver with the throttle and give it a good sharp opening.
focallength is online now   Reply With Quote
Old 05-08-2007, 05:35 PM   #11
bryantjt
Oddometer: 1,027
My buddy's 07 650L will pull roll on wheelies in first and second on the pavement. Are you sure you just aren't getting a ton of wheelspin with that acceleration? Heck my KLX250S will loft the front tire if I whack the throttle in first, OR if I'm sitting about halfway up the seat it will just break the ass end loose.
bryantjt is offline   Reply With Quote
Old 05-08-2007, 05:53 PM   #12
focallength
You're Welcome
Oddometer: 4,975
yeah I think he just needs to man up and give it some gas!
Old 05-08-2007, 06:34 PM   #13
bitterjoe
killing the fatted calf
bitterjoe's Avatar
Oddometer: 2,054
Sadly, I am going to post this link (click on the "download file" to get it to work right). Not that I have ever seen this website before...
I am wheelie deficient. Every time I get it lofted enough to look good I am afraid I'm gonna loop it.
2005 DR650, 2010 Triumph Scrambler
bitterjoe is offline   Reply With Quote
Old 05-08-2007, 06:49 PM   #14
jpaige
Adventurer in training
Oddometer: 56
You and me both brother. Been on the loop it end once too many.
jpaige is offline   Reply With Quote
Old 05-09-2007, 04:28 AM   #15
getmedirty
Mr Magoo
getmedirty's Avatar
Oddometer: 151
Originally Posted by Ted West
T his whole Hillbilly/Deliverance theme that quite frankly makes me feel uncomfortable.
That's why I ride sweep, so I can keep and eye on all you Hillbilly types!!!
KLR 650
R1100RT
Times are GMT -7.   It's 10:12 PM.
