Old 05-08-2007, 08:51 PM   #1
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
OK charging system guru's, WTF is up with my GS...
So, here is the deal.... Rode to work yesterday, no problems... parked the bike and didn't hook up the battery tender that I always do, jumped on the bike and rode to work this morning no problems again. At lunch I jumped on my bike (no problems) rode 30 mile run on the freeway to drop off my Triumph crankcase for welding and when I got on it to head back to work it almost didn't turn over.... wtf? Rode back to work parked for four hours and when heading home it barely cranked over again... at home with the bike turned off the battery read ~10.5 volts on my Fluke, and running at 3K it was still at ~10.5 volts.
The generator light is lit when the key is on, bike off. It does not come on when the bike is running or at idle. This didn't really attract my attention because it hasn't lit at idle ever since putting in a new diode board two years ago... and btw the battery is a three year old Westco sealed unit that is always on the battery tender when the bike isn't in motion, well except for last night.
So, I plan on testing the resistance of the slip rings this weekend (can't run the bike at night as it keeps the kids awake)... any other advice?
And yes, i will buy Rick's book in the morning... what a crummy way to end a crummy day
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 06-20-2008 at 12:31 PM
Solo Lobo is offline   Reply With Quote
Old 05-08-2007, 09:26 PM   #2
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,251
Hate to say it solo, but it sounds like your battery bit the big one. That's my gut feeling from the start. I've had those Westcos do that - just die suddenly for no good reason. One only lasted a year. Now I stay away from them and go with the Odyssey or Panasonics from Digikey.
Disconnect the ground and hook up the battery charger. See if the voltage comes up, and stays up. Betcha it won't.
Old 05-08-2007, 09:33 PM   #3
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,196
It's a tough call on this end but since you own a Fluke, I'm going to assume you know how to use it.
Have you considered that the battery may have dropped a cell? The alternator can charge its little guts out but if one of the cells is shorted internally, it'll never get the system over 11-12V. I had a Gold Wing that did this and it charged the battery until the case was bulging. I was limping it home on the battery thinking I had a bad alternator (11V indicated). A new battery and I was on my way.
I think under those circumstances the generator light would go out because the alternator is doing its job--it just can't raise the system voltage of the bad battery.
The other check would be to charge it at home. Charge it, then take it off the charger and let the battery rest (stabilize) for about 10 minutes. Measure the voltage. If you don't have 12.4+ it's toast.
My other knee-jerk guess is a failed diode ground harness (if you're using the stock BMW diode board).
Of course those are edumucated guesses but 10 minutes with a voltmeter and that front cover off should give you some answers. It may also be one of the normal suspects (rotor, diode block or brushes) but I assume you know how to check those.
Donkey Hotey is offline   Reply With Quote
Old 05-08-2007, 09:34 PM   #4
Donkey Hotey
De Jo Momma
Oddometer: 12,196
Damn, 205'd while editing my masterpiece.
Old 05-08-2007, 09:42 PM   #5
Wirespokes
Wirespokes's Avatar
Oddometer: 8,251
Great minds think alike!
Looks like it's a slam dunk Solo! Got a favorite place you get your batteries at?
Don Kehotey - where'd the expression '205d' come from? Sorry for sneaking in right under you, but I agree whole heartedly with your diagnosis. Well, except that it could possibly be the diode bd, rotor, etc. No, it's the battery! Hell, I wouldn't even take the front cover off, what's the point??
Old 05-08-2007, 09:52 PM   #6
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
LOL!
Thanks guys... I have the battery on the tender right now and will let it run up a charge until after work, let it "stabilize" and remeasure the standing voltage.
If I can choose one, dead battery ain't too painful!
Then, I'll measure everything anyway
R65LazaruS
Solo Lobo screwed with this post 06-20-2008 at 12:32 PM
Old 05-08-2007, 09:56 PM   #7
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
I'm confilcted a bit here, what exactly is the trigger for the light to light? or not light as the case may be..... I would have guessed a certain voltage output above, no light below, light on.... am I correct? If so, what is the mechanism?
R65LazaruS
Old 05-08-2007, 09:57 PM   #8
Donkey Hotey
De Jo Momma
Oddometer: 12,196
Down in the basement I'm supposed to tell you to STFU and get me a beer but considering you've got more years here than me and this ain't Jo Momma:
A few years ago there was the story about a guy getting arrested for 205 MPH on the freeway. LINKY It got retold as 'news' so many times that somebody stuck the term '205' to anything that's already been posted.
Or so I've been told.
Old 05-08-2007, 10:01 PM   #9
Donkey Hotey
De Jo Momma
Oddometer: 12,196
I'm pretty sure that it's simply a diode and the direction of current flow.
  • If the alternator is at lower voltage than the battery, current flows from the battery back to the alternator windings which lights the indicator.
  • As the revs come up, they balance, no current flows so the light flickers and goes out.
  • When the alternator voltage is higher than the battery, a diode in that circuit keeps the lamp from lighting up again.
If the battery is shorted and sucking all the current (acting like a big resistor), the system voltage could be 6V and the alternator could be on fire trying to keep up. As long as the alternator has higher voltage than the battery, the light will go out.
Old 05-08-2007, 10:02 PM   #10
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,396
The alternator light will not come on with the key on and the engine off if the rotor is open. The same is true if you are screwing with the wiring and forget to reconnect the voltage regulator and ride from San Francisco out to Concord on just the battery. I had to ride out and rescue a service writer who did that.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 05-08-2007, 10:03 PM   #11
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
very interesting.... Thanks!
R65LazaruS
Old 05-08-2007, 10:12 PM   #12
BobLoblaw
Comfortably Numb
BobLoblaw's Avatar
Oddometer: 1,507
Put the voltmeter on the charged battery. When you press the starter the voltage will rapidly drop if there is a cell shorting under load.
BobLoblaw is offline   Reply With Quote
Old 05-08-2007, 10:14 PM   #13
Wirespokes
Wirespokes's Avatar
Oddometer: 8,251
How the hell did you get so many posts in such a short time??? You've got me beat by a mile.
Thanks for the explanation. I kind of get the idea. So I'm supposed to get you a beer now?
Solo - the idiot charging light works like this: When you turn on the key it energizes the charging system. Because the charging system can't just generate electricity on its own just from the rotation it needs a flow of electricity to the rotor to energize it. The charging light is after the ignition switch and before the rotor.
When the motor starts and the alternator gets spinning real good, it starts charging. At that point it's putting out as much electricity as at the ignition switch, so there's no way for the little electrons to flow through the light. It goes off. As long as the alternator is putting out more juice than the battery the light will be off.
To go one step farther, the regulator turns that flow off and on, because without that flow to the slip rings and the rotor windings, there's no electricity generated. When the battery needs a bit more charge, the regulator turns on the flow to the rotor.
A good question would be why the light doesn't go off and on all the time. Don't know - but I guess it's all happening so fast once the battery is charged up that the filament never gets hot enough to luminate.
Old 05-08-2007, 10:15 PM   #14
Wirespokes
Wirespokes's Avatar
Oddometer: 8,251
Damn! Now I'm the one that got 205d - and not by just one guy but by four!!!
Old 05-08-2007, 10:19 PM   #15
Donkey Hotey
De Jo Momma
Oddometer: 12,196
I've got my quota of 'four per day' in just this thread.
Times are GMT -7.   It's 05:33 AM.
