Old 05-13-2007, 05:18 PM   #1
mwolff OP
Oddometer: 215
'05 R12RT fuel venting problem
The fuel tank is not venting properly, causing it to misshape as it heats up, getting in the way of the front left fork. It caused me a bit a scare yesterday when I found I could not turn to the left at a slow speed. When I discovered the problem, I removed the gas cap to hear the whoosh of air escaping, and to watch the tank pop back into shape. Happened again as soon as I rode for awhile more.
Anyone see or hear of this before? Any home fixes that would help?
Mwolff
mwolff is offline   Reply With Quote
Old 05-13-2007, 05:46 PM   #2
eaglemike
Oddometer: 904
I know the distortion/interference was discussed over on bmwrt.com some time back. I don't remember what the cure was. You might try the hexhead section there.
all the best,
Mike
eaglemike is offline   Reply With Quote
Old 05-13-2007, 07:31 PM   #3
rous44
rous44's Avatar
Oddometer: 1,252
Several people have experienced this problem.
I had it happen on my 1200ST. The vent line is pinched under the tank. You need to remove some body panels and the tank...you'll see it pinched there. Just re-route it and all will be well.
Registered offender
"picking up hookers, instead of a pen, the words of my youth slipped away" Waylon Jennings
MX '06 http://www.advrider.com/forums/showthread.php?t=176637
MX '07
http://www.advrider.com/forums/showthread.php?t=278826
rous44 is offline   Reply With Quote
Times are GMT -7.   It's 09:58 PM.
