01-16-2008, 09:12 PM
#241 | |
plainsman
Oddometer: 89,817
The hole is 2 1/2 inches in diameter. I have the pilot needle out about 1-1/2 to 2 turns. It's impossible to fine tune the pilot screw in this weather. It's only 12F above and the highs the next few days will be below zero. So I'm just waiting for spring now.
_______ |
01-17-2008, 04:30 PM
#242 |
Oddometer: 778
Damn you all!, reading this thread has got the best of me. For some time now I have been looking out for a MT-rat bike and I finally came across this little DR.
For the price of an Irish whistle I picked up a purple ![]() Drilling out the mixture screw and blowing out the various jets/passages has it now running like a top. Even at 200 lbs though I find the gearing (15:45) a little frantic. I would like to go 16:45 or 15:42(40) if anyone can tell me where to source the sprockets...please! I cannot believe how well this little 11,000 miles motor runs (not power-wise ). No-choke starts each morning are very satisfying. I can run this thing balls out for 20 mins on the highway and when I come to a stop the little engine just settles down to a perfect laxidasical idle as if it were sitting in my driveway Has anyone found a solution for the rear shock yet? I have a left over front end from an 05 DR650; Clamps, forks, wheel, brakes etc, from a past project. ![]() Bottom bearing on the 200 stem has a 30mm ID as on the 650, top however has a 25mm. I might try turning down the 650 stem to fit the 25 mm top bearing and seeing if I can make it fit. ![]() I would consider this in the 'free mod' category as aside from the wheel the rest of the front end would be virtually worthless on ebay, so why not try, right? The 'low' position adjustability (rearranging the spacer placement) of the 650 forks drops travel from 10.2" to 8.7" which should match the DR200's 8' if I slide them up a 1/2 inch or so. Brakes will be a huge improvement but overall weight should be up a little, though the 650 clamps and stem are aluminium vs all steel on the 200. Given the 80-100 lbs difference between the 2 bikes, the stock springs in the 650 forks should be a BIG improvement. I am not so much looking to turn this into a better 'trail' bike but rather trying to match the spring/damping and brakes to better suit my portly 200lbs. The bike is low enough as it is on its side stand but I am getting into Harley territory when I sit on it the poor thing right now. Either way this bike is a little charmer, 35-45 mph is just perfect for running errands in the sunshine and enjoying the balmy trades
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. GuinnesS screwed with this post 01-17-2008 at 04:37 PM |
01-17-2008, 06:07 PM
#243 |
Regi-mental Scotsman
Oddometer: 21
[quote=GuinnesS] Even at 200 lbs though I find the gearing (15:45) a little frantic. I would like to go 16:45 or 15:42(40) if anyone can tell me where to source the sprockets...please![quote]
If you're 200lbs, I'm sure you don't want to gear it up any. You should probably go down a tooth on the front (15 to 14). Anyway, you can usually find the sprockets on ebay. |
01-17-2008, 06:39 PM
#244 | |
Oddometer: 778
Any other sources for 16t's aside from fleabay? I am not a huge fan of PayPal
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. |
#245 | |
plainsman
Oddometer: 89,817
_______ |
01-17-2008, 06:42 PM
#246 | |
plainsman
Oddometer: 89,817
For a while front sprockets one tooth larger were available...the company is named earlier in the thread. I have one but it's promised to Ladybug0048 already. Search back in the thread.
_______ |
01-17-2008, 06:46 PM
#247 | |
Oddometer: 778
Too right!
01-17-2008, 07:36 PM
#248 | |
Oddometer: 21
01-17-2008, 10:15 PM
#249 | |
Oddometer: 778
I just need to find the bleemin things. Klay, where did you find your 16t? I had a chance to get a look at the rear sprocket when I cleaned and re-lubed the chain; 45T. I have not yet checked the front, it may well be a 14T, though everything else on this bike has been left stock by the two PO's. I'll have look in the morning. Right now the bike does feel high strung at 40-45 and while it will get up to 60+ mph (indicated) it feels alot like over-rev. My wife's GTS250ie is doing it's nails at 65 w/ more to go.
01-17-2008, 10:34 PM
#250 | |
plainsman
Oddometer: 89,817
_______ |
01-17-2008, 10:53 PM
#251 |
plainsman
Oddometer: 89,817
Found it, it's a company called Rebel Gears.
http://www.rebelgears.com/ Part number 655-16. You could give them a call and see if they have any around.
_______ |
01-17-2008, 11:03 PM
#252 |
Oddometer: 89
If you have any trouble finding a 16T sprocket, contact www.procycle.us
They'll fix you up |
01-18-2008, 05:32 PM
#253 | |
Oddometer: 21
sprockets
Suzuki and Kawasaki models: ·DR200SE (96-05) ·DR250 (90-95) ·DR250SE (93-95) ·RM250 (82-present) ·RMX250 (89-01) ·DR-Z250 (01-06) ·DR350 (90-99) ·DR350SE (90-99) ·DRZ400 E (00-present) ·DRZ400 S (00-present) ·KLX400R (03-present) ·KLX400SR (03-present) Maybe you could use one of these applications to find a 16 tooth. |
01-19-2008, 06:59 AM
#254 |
Oddometer: 10,906
A DRZ400 or DR350 front sprocket fits and 16T versions are easy to find. I got a 16t for my mom's DR200 from sprocket specialist and it works great. She much perfers it with the taller gearing. I was amazed how low it was geared in stock form. I found myself in top gear while still in her subdivision at 30mph or so.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
01-19-2008, 09:25 AM
#255 |
Oddometer: 148
DR is great
I just had to ride the other day. It was just a quick trip to the store but boy it felt good. Took a side road home. It was fun untill I got into some ice, but made it throught. That was two days ago and I am still smiling. Bad news is that the high on Monday in Centeral Oregon is going to be 10 with frezzing fog. Oh well I love that little bike.
