07-10-2010, 07:59 AM
#2806 | |
Oddometer: 50
Quite a bit quieter. The FMF is loud even at idle, my 12yo loved it. I have a CRF230 with a CHM System that has a very acceptable purr until you crank on it. Has anyone found/installed a "sportier" rear fender?
CRF230(plated) KTM105SX patski screwed with this post 07-10-2010 at 11:31 AM |
07-10-2010, 02:44 PM
#2807 | |
Where we riding to?
Oddometer: 3,572
07-10-2010, 04:09 PM
#2808 |
Oddometer: 100
Question for all you mechanical brains.
My wife's DR200 is having an idle issue. I got on and rode around on it to see what it's doing, and it will not stay running when downshifting if you don't keep the gas applied. There is no chance of it staying running just sitting there in neutral without gas. I figure it's something to do with the idle, but I don't know anything about it. I feel confident in working on it, if somebody knows what the issue is. Any advice will help. It's bone stock btw.
2009 DR650 2004 DR200 |
07-10-2010, 04:28 PM
#2809 | |
Oddometer: 1,324
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
07-10-2010, 04:48 PM
#2810 | |
Oddometer: 100
Sweet! Do you have a picture or a diagram. I really am new to this. ![]() Edit: I got to the pilot jet. I don't really see anything in there that would be clogging it up. I'll clean it anyway, and reassemble and see what happens.
2009 DR650 2004 DR200 slackline screwed with this post 07-10-2010 at 05:23 PM |
07-10-2010, 06:39 PM
#2811 |
dreaming adventurer
Oddometer: 89,836
Quite often you can't see anything when a jet is dirty or partially plugged. I went through this same trouble with my DR200 at one point, and cleaning the jets thoroughly even though I couldn't see anything fixed the problem. Actually, it took a couple tries.
_______ |
07-10-2010, 09:23 PM
#2812 | |
Oddometer: 50
So I soaked it in Chem-Dip for an hour, reassembled and it idled fine. Pat
CRF230(plated) KTM105SX patski screwed with this post 07-10-2010 at 09:31 PM |
07-10-2010, 10:16 PM
#2813 | |
Oddometer: 1,324
07-11-2010, 02:14 PM
#2814 |
Oh boy that was close
Oddometer: 969
Sometimes the clog in the idle circuit is further downstream from the jet itself and the passage to the venturi will need to be cleaned and blown out. I throw this in if cleaning the jet makes no difference. Does it run better with the choke partially or fully out? If it does you can be pretty sure you need to clean out the jet or idle circuit. The rich mixture from being choked helps relieve the lean mixture caused by the clog.
Honda ST1300 Honda NC700X Honda CH80 Dave |
07-11-2010, 02:44 PM
#2815 | |
Oddometer: 2,871
Does it other why run fine?????? Second Pilot jet is plugged....... You need to rotate the carb to gain access. It is done through the fuel bowl, on the bottom of the carb... Erling |
07-11-2010, 03:44 PM
#2816 | ||
Oddometer: 50
He's going to post some pix.
CRF230(plated) KTM105SX |
07-11-2010, 08:31 PM
#2817 |
Oddometer: 142
Suzuki : TSR 200: eBay Motors (item 260633038833 end time Jul-16-10 12:45:17 PDT)
I hope the link works. It's a TSR 200. Very neat. Maybe what the DR200 could have been.
If you think getting old is bad; consider the alternative. |
07-11-2010, 09:17 PM
#2818 | |
Grandpa Adventurer
Oddometer: 1,178
Broken off clutch ball
Dave
Smilin Jack Western Oregon USA 2006 DR650SE CB250 1991 Adventure bike "dual-sport" http://www.advrider.com/forums/showthread.php?t=441736 http://www.advrider.com/forums/showthread.php?t=469125 http://www.advrider.com/forums/showt...e#post11612867 http://www.facebook.com/album.php?ai...8&l=3d8dcb2743 |
07-11-2010, 10:31 PM
#2819 | |
dreaming adventurer
Oddometer: 89,836
_______ |
07-12-2010, 06:12 PM
#2820 |
Oddometer: 100
Pilot jet cleaned, now won't start!
Completely disassembled her carb to clean everything. Sucker was dirty. Re-assembled and it started right up and ran fine. Ran out of gas, got gas, wouldn't start, ran battery down, and put it on a trickle charger for a bit. Opened up air box, completely flooded, so I drained it and promptly got it started. Only thing was, it was super rough. It died when I ran to get a shirt to ride it around the block with my wife at the gas! Now it won't start again. I imagine it's flooded, but I haven't had the time to crack it open again.
