07-12-2010, 06:46 PM
#2821 | |
Oddometer: 130
I always reassemble my carbs and then hook up a small fuel tank before I reinstall. It makes sure that the float is ok as they can get little holes in them and that the needle and seat valve is working. Then drain and put back in. Cheers from NZ New Zealand..home of the only team unbeaten at the World Cup |
07-12-2010, 07:28 PM
#2822 |
Oh boy that was close
Oddometer: 969
If the airbox is flooded with gas the vacuum petcock is not working and allowing fuel to flow into the carb then into the airbox when the carb overflows. If it is the petcock order a Yahama part #5LP-24500 for a manual petcock. It's about $20 and the Suzuki OEM one is about $90. The Yahama one bolts right in like OEM.
Honda ST1300 Honda NC700X Honda CH80 Dave |
07-15-2010, 06:09 AM
#2823 | |
Oddometer: 2,870
A few things to check first.....Hoses..... The inside side of the petcock......goes to the right forward side of the carb..... the aft side of the petcock where it says pri. ...goes to the left side of the carb....... The right aft side of the carb is the carb vent and goes to the airbox. Check those settings. Did you complete ly remove the carb.....or just rotate it???? I would suspect float stuck......Since you did not have flooding issue before....O would not suspect the petcock...( although they have been known to fail)...... Did you have the needle/spring apart??????? Let`s start with this.... I`m sure it`s easily fixable....... Last thing..... you run the petcock on RUN.....Not on PRIME....right??? Erling ebrabaek screwed with this post 07-17-2010 at 04:46 PM |
07-17-2010, 07:23 PM
#2824 | |||||||
Oddometer: 100
Still not starting.
Ok, tore into it again today.
I know, you have to ask.
2009 DR650 2004 DR200 |
07-17-2010, 10:32 PM
#2825 |
Oddometer: 130
As suggested, it is sometimes helpful to run a flow test before putting it back into the bike. You can also open the drain screw when on the bike but not running and if the fuel doesn't stop flowing after the bowl drains you know it is the petcock. You should also check the float height but if it was working OK before then it is most unlikely to have changed.
Cheers |
07-18-2010, 02:21 PM
#2826 |
Oddometer: 130
Ok, you said you cleaned the petcock but it is getting "gummed up again". That may be your clue. Drain the tank and give it a bit of a clean. The petcock should not be getting dirty that fast unless there is something in the tank, or the rubber seal/washer/o ring in the petcock is reacting with the fuel.
Maybe a previous owner put something weird in the tank. Good luck. |
07-18-2010, 06:53 PM
#2827 | |
Oddometer: 1,324
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper |
07-21-2010, 09:46 AM
#2828 |
Oddometer: 19
Seeing other DR200's
I've been commuting from Laguna Beach to Long Beach (where the boat is) along PCH 3 or 4 times a week, and I've spotted a couple other DR200's along the way. Am I seeing any of you guys?
I returned the windscreen I ordered - they mistakenly sent me the 1" kit is opposed to the 7/8" and gave me too much hassle about switching, so I RMA'd it and bought an AirHawk. I just installed the AirHawk and can't wait to try it. Lol, I was sitting on a memory foam pillow to save my arse. The more I ride the 200, the more comfortable I get with it on the road - it is really not as limited as I expected. I've even made the 80 mile roundtrip on the I405 averaging well over 70mph, but it is not as fun, and the mileage suffers badly (62mpg fwy vs 86mpg on PCH.) After about 60mph, the cam picks up, and the engine smoothes out (stops buzzing.). It seems to buzz worst between about 54-59mph then smoothest right out again - probably just a weird harmonic. I do wish it had a 6th gear sometimes... Does anybody have any ideas about some kind of scissor joint I can get to make my handlebars foldable? |
07-21-2010, 01:09 PM
#2829 | |
Oddometer: 130
I am sure these would be somewhere in the US. Cheers |
07-21-2010, 09:40 PM
#2830 |
Oddometer: 746
brakes
Searched the forum and couldn't find the answer.. I want to change my front brake pads, Sintered or carbon pads?
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
07-21-2010, 10:00 PM
#2831 |
Oddometer: 746
oo and by the way Klay... your Odometer is quite amazing.
07-22-2010, 08:07 AM
#2832 | |
plainsman
Oddometer: 89,815
It's pretty idiotic.
_______ |
07-22-2010, 04:56 PM
#2833 |
Oddometer: 142
Uh-Oh
According to a recent article on motorcycledaily.com, it appears there will not be a 2011 DR-200; at least not here in the U.S. Come to think of it, I don't think I have seen a 2010 either. There are still dealers with leftover 2009s and I talked to a dealer the other day who just sold his last leftover 2008 this week.
If you think getting old is bad; consider the alternative. |
07-22-2010, 09:12 PM
#2834 | |
plainsman
Oddometer: 89,815
_______ |
07-23-2010, 04:54 PM
#2835 |
Oddometer: 142
I stopped at the dealer today and he verified that the DR-200 was a no-show for 2011, and there was no 2010. The only small(ish) D/S bikes will be the DR-650 and the DRZ-400. He said it appears that the whole line will be available in Canada. Oh well, he has one 2009 DR-200 still to be prepped.
