Old 03-14-2009, 10:00 PM   #1276
rocketkidd777
rocketkidd777's Avatar
Oddometer: 61
Originally Posted by Airvent
A poor college kid like me can barely afford a phone with a camera! Let alone an actual camera..
ditto!!
-2000 Suzuki DR200SE
-1999 Suzuki GS500e
rocketkidd777 is offline   Reply With Quote
Old 03-15-2009, 11:09 PM   #1277
FlyingFinn
Oddometer: 1,097
I thought I'd take a break from bitching at other people on some interweb message board and actually went riding today together with my GF. Great ride, good brunch, beautiful scenery and roads just made for dual-sports like the little DR.
It was a nice day here in CA:
But damn they have closed up all the good roads around here. Gates, gates, gates.... locked gate at the base of every darn nice road leading up to the mountains.
Mikko
FlyingFinn is offline   Reply With Quote
Old 03-16-2009, 01:01 PM   #1278
poppawheelie
poppawheelie's Avatar
Oddometer: 559
Laugh 3 Things
Three things that might make it easier for others working on their DR 200's:
1) For some reason all the fasteners, screws, etc. seem uncommonly tight on the 200. I've noted others experiencing this on the forum. Tip for loosening floatbowl screws when doing the Keintec thing: use an old fashoned impact driver, available for $10 ~ $12 at any automotive or hardware store. I was surprised to find that a tap with the hammer easily loosened the screws without damaging them, even with the carb turned sideways and still mounted in the rubber intake tubes. I guess the shock/vibration does the job. The force is also driven inward, driving the philips head into the screw, so it does not strip the top of the screw. In the old days, this was the only way to remove sidecases.
2) When mounting Happy Trail side racks, I remounted the stock turn signals out of harms way and made a very neat installation, I think. I didn't want to take time to order the shorter after market turn signals, and I didn't like the position of the provided bracket. I made a tiny bracket to mount them in/under the tail light. See pics. This way they are inboard of the rack frame, in case bags are off for rough trail riding and falling.
[IMG]turn sigs 3[/IMG]
No wires were harmed to do this job. In other words, no wires were cut or spliced. The wires were plugged back into the original receptacles under the seat. Integrity of the original wiring was maintained. I'm fussy about stuff like that.
3) One more thing I did to ease load on the battery for super cold starts, and to provide the option to going incognito, was add a switch to turn off the head and tail lights. I did this on my DRZ 400 and immediately noticed how the starter turned the engine easier and faster. This doesn't seem to be as much of an issue on the DR 200, with the bigger battery and smaller, lower compression engine, but if you want to do it, the picture shows which wires (brown to brown and yellow/white to yellow/white) to unplug and jumper in the Single Pull Double Throw (SPDT) switch. You'll have to use a pin against the lock tabs to pull these terminals from their terminal blocks, also shown in the picture. The yellow/green wire, shown still connected in the foreground, is the clutch switch lead.
[IMG]DR wiring[/IMG]
[IMG]DR 200 switch[/IMG]
This wire nest is over the headlight, beneath the faux number plate. JUST DON"T FORGET TO TURN THE LIGHTS ON WHEN ENTERING THE PUBLIC ROAD. Your stop light, turn signals and horn will operate as normal with the switch on or off.
Happy trailing!
poppawheelie is offline   Reply With Quote
Old 03-16-2009, 01:52 PM   #1279
Airvent
Airvent's Avatar
Oddometer: 347
Awesome job with the turn signal mounting, I might do that, im always breaking the rear signals..
Great info on the light switch, great for sneaking in and out of trails, especially at night!
Airvent is offline   Reply With Quote
Old 03-16-2009, 02:02 PM   #1280
poppawheelie
Oddometer: 559
Laugh turn signals
It would be even better with the shorty signals.
http://www.electrosport.com/products...etail-2104.php
Old 03-16-2009, 02:54 PM   #1281
FlyingFinn
Oddometer: 1,097
I like that turn signal relocation
The stock turn signals on the DR are very high quality units, much better than any after-market I've seen.
This is a very good way to retain them but keep them out of harms way!
Mikko
Old 03-16-2009, 05:48 PM   #1282
Airvent
Airvent's Avatar
Oddometer: 347
If i can request, can I see a picture of the rear lights from a small distance?
Old 03-17-2009, 08:14 AM   #1283
poppawheelie
Oddometer: 559
OK, here you go.
[IMG]turn sigs 5[/IMG]
[IMG]turn sigs 4[/IMG]
Old 03-17-2009, 08:58 AM   #1284
bross
Where we riding to?
bross's Avatar
Oddometer: 4,524
Poppa? why did your wife make a doily for your license plate?
Old 03-17-2009, 09:30 AM   #1285
poppawheelie
Oddometer: 559
So's you don't check my license plate and come steal our cutsie DR 200!
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
Old 03-17-2009, 10:42 AM   #1286
bross
Where we riding to?
bross's Avatar
Oddometer: 4,524
That's OK we got own.
besides, it's a little far...
Driving directions to Clearfield, PA, USA
4,046 km – about 1 day 14 hours
Old 03-17-2009, 10:46 AM   #1287
Airvent
Airvent's Avatar
Oddometer: 347
Thanks poppa!
I used to cover up my plates for pictures.. whats the point when you go out you pass hundreds of people in your local area with it uncovered. At least online, most of you live on the other side of the country !
Happy Saint Patty's day!
Old 03-17-2009, 11:15 AM   #1288
poppawheelie
Oddometer: 559
Thanks poppa!
I really don't know what the point is. I've submitted pics to other web sites, and the plate was blurred (by webmaster?) before posting.
Old 03-17-2009, 12:33 PM   #1289
Airvent
Airvent's Avatar
Oddometer: 347
My camera is so good, it has a built in blur to cover the plate. unfortunately it covers the rest of the picture too.
Old 03-17-2009, 03:00 PM   #1290
feline
Purrrrrrrrrrs!
feline's Avatar
Oddometer: 426
I tried to root through the various postings in this thread about tires but just got confused. Plain and simple question.....what size tires (front and rear) will fit this bike without modification? The original Trail Wings are on the bike, and in looking for replacements (80% road/20% off-road), I can't find sizes to match- there seem to be dozens of different sizes. Help me with my overwhelmed-ness!
Roll me away...........
feline is offline   Reply With Quote
Times are GMT -7.   It's 02:23 PM.
