03-21-2013, 04:10 PM
#15136 | |
Oddometer: 40
03-21-2013, 04:16 PM
#15137 |
Oddometer: 40
Hi guys i just bought a '93 Dr350s
And I'm having the all-too-familiar hard to kick start cold problem. I've had the carb apart once and it looked fairly clean but I was too lazy to take it into work where I could blow through the ports with compressed air. I'm thinking its the choke circuit because I can drift start in on the hill next to my house and when it starts it doesn't idle at what I'd consider a high rpm even with the choke fully on. All the other suzuki's I've had ('78 gs750, 93gsxr1100, '02Bandit1200s) really roared when that choke was on and you could drive it away with it on. This dr you dare not touch the throttle until it warms up for a few minutes. What do you think?
03-21-2013, 04:21 PM
#15138 |
Oddometer: 40
I've also changed the plug, drained the tank, filled it with fresh fuel, replaced the leaking petcock with a non-vacuum type, plugged the vacuum port (for the petcock) on the carb, and unscrewed the plug boot off the lead and cut a 1/4" off it and screwed the boot back on. The plug wire is heat hardened pretty badly and I'm considering a new coil or at the very least a new suzuki resistor spark plug boot (resistor might be bad) I'm starting to regret getting a kick start only model but I'm going to keep trying until I make it easier to start. It starts on the 1st or 2nd kick once its warm btw.
03-21-2013, 04:47 PM
#15139 |
Mad Scientist
Oddometer: 3,202
For starters, shitcan the resistor and replace it with a piece of copper, brass, or stainless steel rod the same length.
http://www.thumpertalk.com/topic/413...plug-resistor/ |
03-21-2013, 06:20 PM
#15140 | |
Oddometer: 518
03-21-2013, 07:15 PM
#15141 | |
Oddometer: 188
Never knew this!!
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
03-21-2013, 08:36 PM
#15142 |
Oddometer: 36
I think I will go with Rotella T 15w40 then. I was told when I bought my bike that the engine was recently rebuilt, but I don't know how long ago. Hopefully the oil won't be too thick for the tighter tolerances? Also I plan on riding it a bit in this wonderful 30*F weather that we are supposed to be getting next week. Is the 15w40 going to be too thick for that? I plan to let it warm up 5 min before riding it.
I told a friend that I plan to run Rotella in my bike and he couldn't figure out why. He runs it in his deuce and a half (old military 6x6) and is questioning why I want to run it in a smaller higher revving engine. What ought I tell him? |
03-21-2013, 09:47 PM
#15143 |
Still a n00b
Oddometer: 190
Just put a pumper carb on my '90. It's running a little rich. Haven't had a chance to mess with it yet but I feel that the idle air screw won't do enough to get it running perfect. Before I have to order new jets is anyone aware if pumper carbs (the tm33 obviously) have needles with adjustable clip positions? Pretty sure one clip position would be just about perfect and it would definitely be more convenient. Thanks!
03-22-2013, 02:01 AM
#15144 | |
Oddometer: 40
03-22-2013, 04:38 AM
#15145 | |
Oddometer: 611
Regards, Gregory Bender |
03-22-2013, 04:39 AM
#15146 | |
Oddometer: 611
http://thisoldtractor.com/gtbender/d...g_resistor_cap Regards, Gregory Bender |
03-22-2013, 04:41 AM
#15147 | |
Oddometer: 611
Here is some info on jets if you need it: http://thisoldtractor.com/gtbender/d...arburetor_jets Regards, Gregory Bender |
03-22-2013, 04:46 AM
#15148 | |
Oddometer: 98
For those of us playing at home, I'm still confused as the solution and the symptoms don't line up, especially since the bike was running fine until the tank was changed. While the adjustment is there for a reason, you should never have to run the needle in the bottom position. And that main jet change wasn't really a big change IMO.....does anyone have a decent idea why the changes bullitman did would fix this after all the work RE went through? |
03-22-2013, 05:07 AM
#15149 | |
Oddometer: 611
Does buying the Valvoline product give me any advantage over the Rotella product? Probably. Maybe. Doubtful. Choose your own answer. I "feel" better using it, so I continue to use it (and I like the black bottle it comes in). Very scientific :> :> :> :> Living in Phoenix, I could probably easily get away with running a 15W40. Up in cold country, a person *might* easily get away with 5W40 or even 0W40. Let me be perfectly clear: I am not recommending any oil brand nor viscosity - use what *you* want to use. Is there anything wrong with using 15W40 in a DR350? I don't run it so I can't say anything from personal experience. But, there have been numerous posts from people who run it all the time without problems. Personally, I suggest you give it a try and see what you think. You are not going to ruin the engine or blow anything up or dramatically shorten the life of the engine. As for what to tell your friend, tell him whatever reasons *you* have for running the Rotella. Regards, Gregory Bender |
03-22-2013, 06:50 AM
#15150 |
Oddometer: 777
Shit running at high revs
Hi all HELP PLEASE
92 DR350 starts a peice of piss after 2 weeks standing BUT WONT RUN AT HIGH REVS !!! coughing and spluttering and no pick up !! Had the carb to bits loads of times and cleaned like a new one , had the jets out and and petcock cleaned everything !! It also sort of back fires through the carb !!!wierd put my hand on it and nearly jumped out of my skin first time. Getting sick of it now !!!!! any ideas Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
