Old 03-22-2013, 08:55 AM   #15151
thump!
thump!'s Avatar
Oddometer: 1,368
Originally Posted by PHILinFRANCE View Post
Hi all HELP PLEASE
92 DR350 starts a peice of piss after 2 weeks standing BUT WONT RUN AT HIGH REVS !!! coughing and spluttering and no pick up !!
Had the carb to bits loads of times and cleaned like a new one , had the jets out and and petcock cleaned everything !!
It also sort of back fires through the carb !!!wierd put my hand on it and nearly jumped out of my skin first time.
Getting sick of it now !!!!! any ideas
Phil
If you're running the CV carb, I suggest you look for a leak/tear in the rubber slide diaphragm. If there is one, it will be hard to see unless you hold it up to a light and stretch it out. I once rode around quite a while on a DR350 with the TM33 pumper carb that wouldn't run at all wide open but ran reasonbly well otherwise. Turns out the main jet had come unscrewed and was laying in the bottom of the float bowl... but you've already been there.
thump! is offline   Reply With Quote
Old 03-22-2013, 09:27 AM   #15152
Greg Bender
Oddometer: 1,173
On my CV carb, the diaphragm was just a little "shrunk". It still fit (kinda), but it did not perform right. A new diaphragm transformed the carb. :>
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 03-22-2013, 02:02 PM   #15153
travis789
travis789's Avatar
Oddometer: 103
Originally Posted by Greg Bender View Post
Sounds to me like the diaphragm at the top of the carburetor should be replaced. Mine had those symptoms early on when I switched from a new pumper to a used CV carb. I love the CV carb now on my kick start dirt machine :>
Regards,
Gregory Bender
Thanks Gregory, I'll check that carefully and probably order one just in case. I have to send away for the o-ring that goes on the float unit anyway.
travis789 is offline   Reply With Quote
Old 03-22-2013, 02:21 PM   #15154
thump!
thump!'s Avatar
Oddometer: 1,368
You have to buy the whole slide to get the diaphragm. Don't remember exactly how much but I do recall they are kind of pricey. I repaired one on a KLR a few years back with silicone sealer. It was still working fine a couple of years later when I sold it.
Old 03-22-2013, 02:30 PM   #15155
Greg Bender
Oddometer: 1,173
Actually, the diaphragm is available separately, see part number 13507-44B00, for example.
Rocky Mountain shows sells it for $18.06 (I have not compared prices elsewhere).
http://www.rockymountainatvmc.com
Regards,
Gregory Bender
Old 03-22-2013, 05:11 PM   #15156
thump!
thump!'s Avatar
Oddometer: 1,368
Regards,
Gregory Bender
Cool, that's good news.
Old 03-22-2013, 08:13 PM   #15157
travis789
travis789's Avatar
Oddometer: 103
Hi all HELP PLEASE
Phil
have you checked the valve clearances? Backfiring through the intake could be a symptom of an intake valve that's too tight and not closing all the way. We are lucky it only takes a few minutes to check them on Drs.
Old 03-22-2013, 08:56 PM   #15158
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
Pilot jets
hey guys, I am on the final stretch of having my dr put back together. Its now a 362cc port and polished with tm33 pumper carb thats running a little lean. It has the stock 37.5 pilot jet and idles up with the choke on at opterating temperature and can not adjust pilot screw out any more (and there are no air leaks fyi).
I would like some advice on how many jet sizes to order for jetting? I was thinking of ordering a 40, 42.5, 45, and a 47.5 think I may need to go higher?
jmderyke is offline   Reply With Quote
Old 03-22-2013, 09:05 PM   #15159
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
Fired up the bastardly child Dr today. Could not kick start it, but it bump started right up when I rolled it down the hill. Good thing it started. Don't know if I would have been able to push it back up. Flat front tire and no clutch.
MrPulldown is offline   Reply With Quote
Old 03-22-2013, 09:22 PM   #15160
2old2Bbold
was 2bold2getold
Oddometer: 1,704
Not sure what your problem is. What does it do with the choke off. 362 isn't a lot bigger, dought if you will need a lot bigger jets. 1 or 2 sizes up at the most.
2old2Bbold is online now   Reply With Quote
Old 03-22-2013, 09:44 PM   #15161
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
Yeah its definitely lean at idle, the plug is grey not the coco brown im looking for, it will idle with the choke off
Old 03-22-2013, 11:14 PM   #15162
MadChap
MadChap's Avatar
Oddometer: 441
$4,200......for a DR350
Portland, OR craigslist a guy is wanting $4200 bucks for a DR350 with 1100 original miles. Yes it's nice.......but $4200 bucks. WOW, I might think about selling mine if they are worth that much LOL.
MadChap is offline   Reply With Quote
Old 03-22-2013, 11:22 PM   #15163
tnktm
Oddometer: 43
Digging the DR
tnktm screwed with this post 03-22-2013 at 11:31 PM
tnktm is offline   Reply With Quote
Old 03-22-2013, 11:34 PM   #15164
heirhead
Oddometer: 580
2 much
heirhead screwed with this post 03-31-2013 at 11:04 PM
heirhead is online now   Reply With Quote
Old 03-23-2013, 01:07 AM   #15165
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,161
Cheers Travis
I had thought it could be a valve problem but not having a real mechanical mind i didn't fancy doing it !!!!
Looks like i'mgoing to have to though
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Times are GMT -7.   It's 11:27 AM.
