Old 03-23-2013, 02:05 PM   #15166
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 570
On another subject:
would this tank fit a 350? I know it is advertised for a 650 but I am no aware of any major frame and mounting differences.
http://www.kientech.com/DR650IMSfueltank.htm
2006 Suzuki DRZ 250
redleger is offline   Reply With Quote
Old 03-23-2013, 02:23 PM   #15167
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,288
Call Jesse and ask. He's the DR guru.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 03-23-2013, 03:22 PM   #15168
MrPulldown
MrPulldown's Avatar
Oddometer: 3,048
then let us know. I think it does not fit with our seat.
MrPulldown is offline   Reply With Quote
Old 03-23-2013, 03:32 PM   #15169
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 570
No it's does not :( I really wanna change the look but I really don't want to paint or dye.
Sent from my KFJWI using Tapatalk HD
2006 Suzuki DRZ 250
Old 03-23-2013, 07:31 PM   #15170
jmderyke
Miner
jmderyke's Avatar
Oddometer: 41
Pulse and trigger output voltage
Im looking for the stator pulse and trigger coil output voltage specs anyone have em? the clymer manual doesnt specify a/c voltage just resistance. I have the 91 dr350 with the single pickup coil.
jmderyke is offline   Reply With Quote
Old 03-24-2013, 12:10 AM   #15171
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,246
Originally Posted by PHILinFRANCE View Post
Cheers Travis
I had thought it could be a valve problem but not having a real mechanical mind i didn't fancy doing it !!!!
Looks like i'mgoing to have to though
Phil
Mine is currently doing the exact same thing since I've just put a pumper on. The backfiring is more likely to be caused by running rich (would explain bogging with throttle which also is happening with mine) or your ignition timing being off. I just did a top end rebuild so I'm sure by valves are dead on. I always like to check my ignition timing before messing with jetting. Although it's never a bad idea to check your valves.
Anonawesome is offline   Reply With Quote
Old 03-24-2013, 12:51 AM   #15172
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,127
Cheers for the reply Anonawesome
Vales and timing are next on the list , thought i'd sussed it yesterday !!! took the carb apart AGAIN ,popped out the diaphram and needle and found the small circlip NOT FIXED to the needle
Put it all back together hoping things would be ok !!! they were better but still not right
Quick question .............can the timing JUST SLIP ???????
Cheers all Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 03-24-2013, 05:46 AM   #15173
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 1,260
Cheers all Phil
Unlikely. Altough the timing chain sliders can break or the tensioner can run out of adjustment...
But if it was running fine before sitting it's most likely carb related. Is the petcock flowing freely? Also check the air filter and the fuel filter above the needle valve seat.
dbarale is offline   Reply With Quote
Old 03-24-2013, 07:25 AM   #15174
thump!
thump!'s Avatar
Oddometer: 1,273
Cheers all Phil
Ignition timing is not adjustable. Valve/cam timing is and can "slip" if the cam chain is too loose. It would have to be pretty much worn out for that to happen though. I suspect you have a mixture problem. It also possible that your coil or spark wire is breaking down or arcing although in my experience that usually occurs under high load as opposed to high revs.
thump! is offline   Reply With Quote
Old 03-24-2013, 08:41 AM   #15175
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,855
Originally Posted by jmderyke View Post
Yeah its definitely lean at idle, the plug is grey not the coco brown im looking for, it will idle with the choke off
You absolutely CAN NOT tell the state of your idle mixture by reading a plug.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 03-24-2013, 09:50 AM   #15176
cwc
Oddometer: 917
I think the reason that they only give resistance is that it is easier to measure and most of the time is a reliable indicator.
I have a 95SE which is quite different, but most CDI's operate at similar voltages.
The "power suppy" coil on the stator on mine runs about 75-80 volts AC (rms) with the bike running. I have actually tested the CDI using 110VAC from an outlet. It works fine.
The output of the trigger coil is a little trickier, but I hooked up an ANALOG voltmeter on the 3 volt DC range and waved a magnet by the coil. I got blips of less that a volt. This will depend on the response time of your voltmeter, but it is an indicator of sorts.
Using a digital meter (Fluke 77) for this test didn't give useful results.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc screwed with this post 03-25-2013 at 04:18 AM
cwc is offline   Reply With Quote
Old 03-24-2013, 10:36 AM   #15177
MrPulldown
MrPulldown's Avatar
Oddometer: 3,048
Does anyone have a decomp cable and lever they are willing to part with. Too difficult to operate the the decomp with a screw driver and a pair of pliers.
Old 03-24-2013, 01:13 PM   #15178
daverbmxer
Oddometer: 43
I have a FMF muffler that is rattling because the rivets at the tail end are loose. Is it as simple as drilling out the old ones and riveting in new ones? Are long or short rivets better? Any danger of the end bit falling inside the muffler and working its way back into the engine?
Edit: Thought I'd add a picture.. did a little bit of snow riding yesterday!
daverbmxer screwed with this post 03-24-2013 at 01:23 PM
daverbmxer is offline   Reply With Quote
Old 03-24-2013, 02:31 PM   #15179
thump!
thump!'s Avatar
Oddometer: 1,273
The output of the trigger coil is a little trickier, but I hooked up an ANALOG voltmeter on the 3 volt DC range and waved a magnet by the coil. I got blips of less that a volt. This will depend on the response time of your voltmeter, but it is and indicator of sorts.
Keep in mind that pre-94 models use a single ignition trigger. '94 and newer has two ignition trigger pickups. The CDI on later models will only fire if the two pulses are received in the correct order.
Old 03-24-2013, 05:45 PM   #15180
Teeeeeemu
Oddometer: 104
Just drill them out and possibly pick the shrapnel out. Then just new rivets. What do you mean with long or short?
The stick part gets cut out when you pop in the rivet.
The lenght doesnt change, only diameter as far as I know.
Nothing should fall to the inside while installing the rivets.
Man snow is stupid without studded tires. Couple weeks ago I went to watch a few of my friends riding on ice (Gulf of Finland) with the sun shining and not too cold. Good day.. I was the only one without studs
Teeeeeemu is offline   Reply With Quote
Times are GMT -7.   It's 01:26 AM.
