Old 04-04-2013, 09:16 AM   #15346
2bold2getold
Oddometer: 1,631
Hanging Idle
From my experience, when you have the hanging idle problem it's because the idle circuit in your carb isn't working right ( clogged idle jet, air/fuel screw not right, idle air jet clogged, etc) and then to compensate you turn the idle speed screw up untill it is idleing on the next/mid range circuit. It's trying to get down to the idle circuit but it just can't and if it could there is nothing there to idle on. After you get the idle circuit working right, in most cases you will need to readjust the air/fuel screw after changing the idle speed screw. One will influence the other.
2bold2getold is online now   Reply With Quote
Old 04-04-2013, 11:10 AM   #15347
MrPulldown
MrPulldown's Avatar
Oddometer: 3,048
Originally Posted by Greg Bender View Post
Would only a new slide have seen the same improvement? I don't know because I didn't try replacing only the slide. A new slide through Rocky Mountain ATV MC is $100. An entirely new carburetor through Viperizer Racing is $216. It seemed wise to spend a little over double for the entire new carburetor, and not risk remaining wear to the carburetor body (not just the slide).
Regards,
Gregory Bender
NEw slide from Viperizer racing is only $20
MrPulldown is offline   Reply With Quote
Old 04-04-2013, 11:34 AM   #15348
Greg Bender
Oddometer: 1,162
Oooh...that's cheap!
Greg Bender is offline   Reply With Quote
Old 04-04-2013, 11:38 AM   #15349
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,706
Regards,
Gregory Bender
Good site link thanks
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is online now   Reply With Quote
Old 04-04-2013, 02:26 PM   #15350
LawlerClan
Oddometer: 39
Side plastics
This is the Argentina ones:
http://www.ebay.com/itm/SIDE-COVERS-...#ht_349wt_1159
OEM:
http://www.ebay.com/itm/New-White-Si...ht_2318wt_1159
Maier makes some side planels which I think are the Argentina ones but I can not find them right now.
Mair rear fender:
http://www.ebay.com/itm/Suzuki-MX-Re...#ht_193wt_1397
UFO front fender:
http://www.kientech.com/UFOFrontFender.htm
I think most dirt bike front fenders that attach with four bolts will work.
Anyone tried these:
http://www.cheapcycleparts.com/produ...nt-side-panels
LawlerClan is offline   Reply With Quote
Old 04-04-2013, 03:54 PM   #15351
haggeo
haggeo's Avatar
Oddometer: 900
Originally Posted by LawlerClan View Post
i saw those on thumpertalk's online store.
When the facts change, I change my mind. What do you do, sir? John Maynard Keynes
Faced with the choice between changing one's mind and proving that there is no need to do so, almost everyone gets busy on the proof." John Kenneth Galbraith
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane. Marcus Aurelius
haggeo is offline   Reply With Quote
Old 04-04-2013, 04:24 PM   #15352
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,709
Those are the Maier side panels someone mentioned earlier.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 04-04-2013, 06:17 PM   #15353
MadChap
MadChap's Avatar
Oddometer: 437
I have them. Look good. Crappy mounting system, but solid once you have them on. Did I mention the mounting system is crap. Buy used originaals if you can find them.
MadChap is offline   Reply With Quote
Old 04-04-2013, 06:30 PM   #15354
mustangwagz
mustangwagz's Avatar
Oddometer: 242
Anyone gotta QUICK source for a kickstart shaft Oil seal? Cant find none on Flebay, and most parts store i deal with online are Slow As Molasses.
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 04-04-2013, 07:06 PM   #15355
thump!
thump!'s Avatar
Oddometer: 1,274
I haven't looked at the starter seal but seals and bearings are usually standard sizes. The seal will usually have identifying numbers molded into the rubber. Take those numbers to a bearing supplier or an autoparts dealer (NAPA is better than Autozone). There's a good chance they will have what you need on the shelf.
thump! is offline   Reply With Quote
Old 04-04-2013, 08:38 PM   #15356
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,521
Got my DR out for the first ride of the year today. It was just around town, but this bike is just so much damn fun!
I rotated the bars forward to get a little more height out of them...what a difference. Arms are at a nice length now, sitting and standing. Might add some risers, but won't decide on that until riding on some dirt.
Moto since 2011, DR350
MTB since 1991, Full-Rigid Steel 1x8
_CJ is offline   Reply With Quote
Old 04-04-2013, 08:40 PM   #15357
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 570
I feel the same way man. I have been riding to work the last few days, and I just love the bike. I will never get rid of it. May you enjoy many more days on yours!
2006 Suzuki DRZ 250
redleger is offline   Reply With Quote
Old 04-04-2013, 09:39 PM   #15358
2bold2getold
Oddometer: 1,631
Ron Ayers has got it for $3.89
http://www.ronayers.com/Fiche/TypeID..._MODEL_L_M_N_P
I've ordered one a while back (still in the plastic bag). It looks like it could be a common seal. Suzuki PT# 09283-20044. writing on the seals is: A14 SD 20 27 6 HS and brand in script...Ats
Old 04-05-2013, 04:21 AM   #15359
Greg Bender
Oddometer: 1,162
Just guessing here. Extrapolating the dimensions I get:
OD: 27mm
Width: 6mm
Regards,
Gregory Bender
Old 04-05-2013, 09:43 AM   #15360
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 687
To those who have removed the rim locks...
I pulled my rim locks (balance issues posted earlier) and now am wondering what, if anything, I should do to plug the now empty hole in the rim. My thinking is something should go there to keep the tube from pushing out like a big zit!
Irrational fear or justified concern...?
FireDog45 is online now   Reply With Quote
Times are GMT -7.   It's 08:25 AM.
