Old 04-07-2013, 09:45 AM   #15391
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
Originally Posted by brianjonesphoto View Post
Hey Ren here's one option http://seattle.craigslist.org/skc/mcy/3715599489.html I've seen another engine in Vancouver bc lately too.
Thanks, I emailed the guy about the right side case. Kinda funny to tear the engine apart if nothings wrong with it. I did notice in the pics the magneto cover isn't shown though.
SFC_Ren is offline   Reply With Quote
Old 04-07-2013, 09:46 AM   #15392
2bold2getold
Oddometer: 1,639
Might want to get at least both halves. They're probably/might be matched.
2bold2getold is offline   Reply With Quote
Old 04-07-2013, 10:19 AM   #15393
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
Yeah, I'm more than pretty sure that isn't the "case" haha. They are completely separate castings from Suzuki, and as long as they are either both the kickstart or both the e-start versions they should mate up no problem.
But, I just ordered a right side case off ebay for $110 bucks. and then a moose racing gasket kit too. So we'll see how my saga goes.
Old 04-07-2013, 11:05 AM   #15394
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,242
Originally Posted by Chicken Helmet View Post
I thought JB Weld was a KLR secret.
Little known fact: Every new KLR comes from the factory with two keys, an owner's manual, a little tube of JB Weld and this.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-07-2013, 11:08 AM   #15395
tntmo
Oddometer: 460
Originally Posted by SFC_Ren View Post
Well not sure what could have caused this but it sure is trashed.
If anyone has a good right side engine case from a kickstart model DR350 or DR350S or see's one on their local craigslist. Or has a spare motor let me know please.
I've seen this a few times, got two DR350's for next to nothing with the same issue. It's due to trying to start the bike without the decompression lever, or using it incorrectly. Ask Jesse at Kientech.com, he has probably seen a lot more.
The case halves are supposed to be replaced as a set.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 04-07-2013, 11:38 AM   #15396
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
Now admittedly my area of expertise as a mechanic for over 20 years is Heavy Diesels and automotive applications, but where did you get this information from and why do you think that the left and right cases are matched assemblies?
The factory service manual makes no mention of this fact and why are there separate part numbers for each side of the case? If it was intended to be a matched assembly then normally that is the only way they would sell it.
Thanks,
Ren
Old 04-07-2013, 11:43 AM   #15397
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 4,976
I got it all but the owners manual with my used 09,
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is offline   Reply With Quote
Old 04-07-2013, 11:47 AM   #15398
2bold2getold
Oddometer: 1,639
Split crankcase motors with the crank shaft running along the split center line are machined to provide the required main bearing "crush", and should be kept in pairs. You MIGHT get away with replacing just one side on the DR motor, but you might want to check the crank shaft end play. Don't know about transmission end play, etc. Problem is I don't remember seeing a spec for crank shaft end play in the manual. Most of the motors I've worked on are set at .003" to .006". Might want to check that out.
Old 04-07-2013, 12:11 PM   #15399
2bold2getold
Oddometer: 1,639
Thanks,
Ren
The places I looked, all sold them in sets.
http://www.suzukipart.com/oemparts/a...366c/crankcase
http://www.cmsnl.com/suzuki-dr350-19...st/FIG-03.html
http://www.cheapcycleparts.com/model...3703-crankcase
http://www.ronayers.com/Fiche/TypeID..._MODEL_L_M_N_P
Old 04-07-2013, 12:36 PM   #15400
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
It's a roller bearing crank and there is no end play measurement. It is also not a design where the crank bearings are surrounded "and crushed" by the opposite sides of the case. The crank is left to right through the case. This is not a BMW boxer motor or a VW air cooled motor which both have the design I believe you are referring to. Maybe that is what you are thinking of? But hey I guess I'll find out after putting everything back together. I'll update this thread then.
Old 04-07-2013, 12:41 PM   #15401
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
Split crankcase motors with the crank shaft running along the split center line .
But the key to your above statement, and maybe I wasn't clear in my other reply. Is that this motor is not split with the crankshaft running along the center line, like BMW boxer motors or old air cooled VW's. Maybe I said this more clearly now. :-)
Old 04-07-2013, 12:49 PM   #15402
2bold2getold
Oddometer: 1,639
Yes, I understand. Just thought that there might be more problems associated with mixing crankcases than meets the eye, and if you were going to buy some used parts off CL you might as well get both halves. Didn't think it would cost that much more. It's probably going to work out fine.
Old 04-07-2013, 08:03 PM   #15403
jmderyke
Miner
jmderyke's Avatar
Oddometer: 41
front sproket
does anyone know if a 15 tooth sprocket will fit under the 1991 s model front cover? I have the 14 thats stock and not sure if it will have enough room if there was an extra tooth
jmderyke is offline   Reply With Quote
Old 04-07-2013, 08:16 PM   #15404
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
No problem and thanks for the advice!
Old 04-07-2013, 08:18 PM   #15405
SFC_Ren
SFC_Ren's Avatar
Oddometer: 80
When I put a 15 tooth on my 1990 s model I had to clearance the case saver slightly with a dremel but it all fit back on there just fine to include the cover.
Times are GMT -7.   It's 01:19 AM.
