Old 04-19-2013, 06:43 PM   #15541
DR350seKING
Oddometer: 68
1999 DR350se how to choose what "jets" to use?
hey guys im new to this place so here it goes. i just picked up a 99 DR350se it has a FMF powercore4 on it and i was told that it was not jetted yet so does anyone know or have this pipe that can help me with the right jet. I was out riding today and it feels like it bogs down when accelerating. Also can anyone tell me where does the tool box bolt to i cant seem to find the right place it would go (i may just be missing it). last thing does anyone know what type of bulb goes behind the tach thanks guys
info: 1999 DR350se 100072 miles
DR350seKING is offline   Reply With Quote
Old 04-19-2013, 07:22 PM   #15542
Tork
Pinsetter
Tork's Avatar
Oddometer: 3,506
Welcome , I do not have a DR350 yet . Just wanted to say your mileage on yours is impressive
Tork is online now   Reply With Quote
Old 04-19-2013, 07:23 PM   #15543
2bold2getold
Oddometer: 1,627
First I would make sure the jets haven't been changed. "Boggs" can be either rich or lean. You will probably have to try jets on both sides to test for improved performance. Plug color might give an indication of which way to go. Tool carrier goes on left side just behind the side cover plastic below the rear frame/sub frame loop. Manual says tack light is 3 watt.
2bold2getold screwed with this post 04-19-2013 at 07:28 PM
2bold2getold is online now   Reply With Quote
Old 04-20-2013, 04:53 PM   #15544
travis789
travis789's Avatar
Oddometer: 95
I wouldn't be that surprised if its true!
“Immorality is the word we use to describe people that are not sinning the same way we are.”
― Shannon L. Alder
travis789 is offline   Reply With Quote
Old 04-20-2013, 04:55 PM   #15545
travis789
travis789's Avatar
Oddometer: 95
hi mileage
from thumpertalk: "'m fresh to TT so I haven't been able to read every post there is to read yet. Anyway my problem is I've noticed a distressing number of 10 year old low mileage bikes. I'm talking 2,000 to 5,000 miles! I have a '94 dr350ser that just rolled over 143,000 mi. It's bone stock except for a jet kit and 3.7 gal fuel tank (come on Suz 2.1 gal? pleez!)"
― Shannon L. Alder
Old 04-21-2013, 08:23 AM   #15546
jakeybob
Oddometer: 19
My Dr350 was hard to find neutral when I first got it. I pulled apart the clutch, removed the shift drum bolt and loctited it down (it was tight when I removed it), changed the thrust washers and retorqued my clutch baskets back down to 30ft lbs.
At first it seemed like neutral was pretty easy to find, but when it heats up it is very hard to find again.
I pulled it apart again today to see if i needed to clearance the clutch basket, but it appears to be good.
There is a slight amount of play in the outer clutch basket, and the inner clutch basket spins freely by hand with the plates removed.
Anyone have any ideas? am I correct in my assessment that my clutch basket doesn't need clearancing right now? (by the small amount of play in the outer and the free spinning inner?)
Everything seems good so I am a little perplexed.
jakeybob is offline   Reply With Quote
Old 04-21-2013, 08:47 AM   #15547
dav_dman
dav_dman's Avatar
Oddometer: 818
mine was like that. Turn it off and it's easy, so there is something in the rotating assemblies and spacing...might even be in the adjustment of the clutch cable and how much/little play. someone will chime in soon and let us know exactly.
I have a dr450 out at my brothers now in wash state but i've not ridden it yet (hurry up july when i go visit again) so i dont know if it has that issue or not....
Dave
dirt bikes, vstrom, cruiser, etc.
"what hurts, instructs" - ben franklin
dav_dman is offline   Reply With Quote
Old 04-21-2013, 09:13 AM   #15548
thump!
thump!'s Avatar
Oddometer: 1,273
I've had 6 or 7 DR350 bikes. The clutch dragged to one degree or another on all of them. I think it's a "feature" of this bike. FWIW, they removed this feature when designing the second generation DR650.
thump! is offline   Reply With Quote
Old 04-21-2013, 10:13 AM   #15549
Schneiderman
Oddometer: 13
Hey guys. I just picked up a 1993 DR350, that supposedly was a street model-turned-dirt, and I'm trying to bring it back to the street. I need to order a bunch of parts ASAP and hope to start working on it next week.
So far I know I need:
Rear brake rotor (it's shot!) and pads front and rear
Carb rebuild kit (more on this in a minute)
At least one mirror (ultimately I want two good mirrors but I just need one to get it street legal ASAP)
Street tires
First question: The carb. From what I have read, my bike should have a CV carb. But it looks like I have the pumper. The bike has been butchered by an amateur so someone probably just threw a pumper on there at some point in the past 20 years, but I don't even know if it is installed correctly. Can anyone identify this carb, tell me if there's anything noticeably wrong about the install, and what carb rebuild kit I need for it?
Next up... what do you recommend for a replacement rear brake rotor? I'm not really looking for an upgrade, just need a decent/cost effective replacement that will work and not get me killed.
And how about pads? Need front and rear.
Also, what tires for the street? I bought this bike to use as a city commuter bike. It will see no real dirt time. What street tires will work well on the stock rims?
I will also probably need guidance on rewiring the lights. The turn signals came in a box, it has Baja Designs headlight and taillight that are not hooked up. There are wires hanging loose behind the headlight so the wiring may hopefully be intact but I don't know yet....
Any help is greatly appreciated!
Schneiderman is offline   Reply With Quote
Old 04-21-2013, 02:04 PM   #15550
jakeybob
Oddometer: 19
You could probably buy any brake rotor and it wouldnt really matter. Get something off ebay, or if you want OEM go to bikebandit.com and order one up.
Get some sintered brake pads- HH or EBC or something. Buy a cheap mirror off ebay.
Can't tell for sure what carb you have from that pic. Looks kind of like a pumper.
http://www.thumpertalk.com/topic/716...readfor-a-350/
As far as tires, just buy whatever you feel like in the stock size. I bought shinko 244's cause they are cheap ($85 a set), but thats more of a 50/50 tire.
Old 04-21-2013, 02:18 PM   #15551
MrPulldown
MrPulldown's Avatar
Oddometer: 3,045
you might also try putting in a new spacer. the one between good to thrust washers. like the thrust washers this is a where item.
MrPulldown is offline   Reply With Quote
Old 04-21-2013, 02:57 PM   #15552
jakeybob
Oddometer: 19
Yeah shoulda bought that dumb spacer the first time I did things :P Didn't realize it could use replacing at the time.
I just buttoned stuff back up for now. May just ride/deal with it.
Old 04-21-2013, 04:25 PM   #15553
motolab
motolab's Avatar
Oddometer: 2,519
At over 100K miles, the slide guide, emulsion tube, slide and perhaps jet needle are pretty much guaranteed to be worn out. Emulsion tube wear causes a rich condition at the lower end of the rpm range.
You can determine whether it is a lean or a rich problem by checking if the problem gets better or worse as the engine warms up, and/or when you activate the cold start enrichment circuit.
If you determine that it's a lean problem, I don't necessarily think that would let you off the hook on the wear. The carburetor could have a combination of issues, such as clogged pilot jet together with the aforementioned worn out parts.
Regards,
Derek
motolab is offline   Reply With Quote
Old 04-21-2013, 04:31 PM   #15554
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,709
Make sure the clutch cable has almost no free play - particularly when the bike is all warmed up. May not be the problem, but it could be.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 04-21-2013, 04:52 PM   #15555
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,831
HH is a compound, EBC is a brand.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
